Old 04-14-2009, 07:00 PM   #76
factorystock
factorystock's Avatar
Re: well, I'm excited!
Think of it as a beauty treatment to the eyes, like when women wear eyeliner and mascara.
factorystock is offline   Reply With Quote
Old 07-26-2009, 06:23 PM   #77
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I'll get some new pics up we did a quickie blue paint on the doors, looks much better all one color. we did one dump run with it , got back and the right rear wheel was almost off, all the lugs were 1/2 off...my fault for not tourquing them down.
then yesterday the master cylinder failed, luckily in the yard..and this thing is so low geared it practically stops if you let off the gas...
so lotws more maintenence...but still cheaper than a new truck payment, and looks better too!
Old 10-21-2009, 09:02 PM   #78
jonzcustomshop
1961 crewcab
3/4 ton rear questions
I just got the rear brakes off my 63 3/4 ton 4wd, and the drums are shot, is the interchange all chev and gmc 3/4 ton 60-66?
what will work?
it is a factory gm 4wd, not a napco.
should be some pics in the link in my sig-
Old 10-21-2009, 09:04 PM   #79
jonzcustomshop
1961 crewcab
Re: 3/4 ton rear questions
... I forgot this part, the e-brake cables are gone, so while I am in there I am thinking of hooking them back up. will the cables out of a 1/2 ton work, or are they 3/4 ton only?
Old 10-21-2009, 09:47 PM   #80
LILRED66
LILRED66's Avatar
The 4x4 hubs have a raised area at the bolt circle and the 2wd hubs are flat across the face. Also, the 4x4 e-brake cables at the backing plates are different than their 2wd counterparts, so you will need rear e-brake cables, specific to the K20.
LILRED66 is offline   Reply With Quote
Old 10-21-2009, 10:01 PM   #81
jonzcustomshop
1961 crewcab
thats bad news... any idea on interchange..?maybe up into the 70's ?
Old 10-22-2009, 12:46 AM   #82
Captainfab
60-66 Nut
I'm assuming what you have is the Eaton HO52? If so they were used up thru about '70 I believe. I have also heard that the Eatons have the same backing plate flange as the 14 bolts. Some of the off road guys use the disc brake conversion for the 14 bolt on the Eatons. So common sense tells me that you might be able to swap some 14 bolt brake assemblies onto that Eaton. I'm thinking of trying that swap on the Eaton I will be using in my '68 K20, but that won't be happening anytime soon.
Old 10-22-2009, 07:48 AM   #83
jonzcustomshop
1961 crewcab
here is what it looks like:
Old 10-22-2009, 11:21 PM   #84
Captainfab
60-66 Nut
Yup! that's an Eaton HO52
Old 10-23-2009, 12:29 AM   #85
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
I say throw a dana 60 in it so you can get parts.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 10-29-2009, 11:32 PM   #86
jonzcustomshop
1961 crewcab
I am going to try and get the drums turned, but the guy can only find specs that go back to '76, anybody know the specs, or where I can find the old info, he says if I can find out he will try and turn them for me.
they would be for a 63 k20 12X2 brake drum.
Old 01-12-2010, 06:28 PM   #87
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Very cool truck!
LOW DOUGH is offline   Reply With Quote
Old 01-12-2010, 06:36 PM   #88
BigRedTruck
Congrats on the $400 deal. Got myself a $500 deal on a C-15 Fleetside in 2006. I'm restoring it and its just about finished. Will post many pics once I've completed it.
BigRedTruck is offline   Reply With Quote
Old 01-16-2010, 10:53 PM   #89
jonzcustomshop
1961 crewcab
Re: jonz 63 K20 build
well here is a status on the worlds longest brake job!
I started in october.. and should have it done this week..haha.
lmc truck does carry the correct wheel cylinders, and was able to get the shoes (pr) at the parts store, all 3 pieces were $150.00! ouch!
Out of curiosity I checked an 80's 3/4 ton 2wd suburban that we have to see if the emergency brake cables would work. where they entered the backing plates was the same, so I might have to transfer some of the hardware from the frame to mount them, but I will be able to have e brakes.
my drums were too worn to turn, but with the amount that I will be ysing this truck, we decided that they should be ok af ter a goos scuffing with some 180 grit.
Old 05-05-2010, 01:29 AM   #90
jonzcustomshop
1961 crewcab
took this shot in feb. forgot to post it... painted the doors, useable wheels and tires.
I found a set of original 8 lug non split 17.5's is there a modern tire that will fit/ before I go buy them?
next on this is putting together a set of original mirrors, the original driver door to this truck came with the bracket,I found a bent up arm, hopefully i can straighten it, and I just need to find a passenger side setup, or I might copy the driver side setup and fab my own bracket for the passenger side.
(second pic shows thistype)
Old 05-31-2010, 04:10 PM   #91
jonzcustomshop
1961 crewcab
I just found out this truck came with a fawn custom comfort seat!!
there are 2 covers over the original material, a walmart style cover, and then a thick red cover under that. I noticed when I folded the seat forward, that there was the original houndstooth material in the crack....
I don't want to take the covers off yet to see if the drivers side has a hole worn in it...seems like they all do...
Old 05-31-2010, 05:51 PM   #92
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Jonz houndstooth refers to the design on the camaro seats like an oversized comma,,,,,, Houndstooth was also printed on womens clothing. This upholstry is for the deluxe early sixties Chevrolet truck. A little sensitive about this point, I'm sorry.
Old 05-31-2010, 06:51 PM   #93
LILRED66
LILRED66's Avatar
Here are some photos of a nice original seat with the hounds tooth pattern.
Old 05-31-2010, 07:02 PM   #94
aerotruk63
aerotruk63's Avatar
Houndstooth
Old 05-31-2010, 08:02 PM   #95
jonzcustomshop
1961 crewcab
the pic that lilred posted is the pattern I saw, color too!
Old 05-31-2010, 08:16 PM   #96
aerotruk63
aerotruk63's Avatar
I could be wrong. All the info I have for 63 shows the IIIIIIIII pattern for the seat. Vinyl came red or fawn depending on the color of the truck . My 63 had this pattern when I bought it.
64-66 had different material and seat layout of the white banding than 63. Perhaps the seat was changed out at some point.
Does you truck have the rest of the Comfort Options?
Old 05-31-2010, 08:24 PM   #97
jonzcustomshop
1961 crewcab
I'll try to get a pic of the pattern next time i am out there..
and no on the options, I will have to double check on the armrest, 'cause the doors were changed, but I still have the originals.
but it only has one visor, and cig lighter blockout.
there is a good chance that the seat is out of a 64 up... the dash has a 64-6 radio installed so clean ,it looks factory... found out the other day it is not hooked to the ignition, left it on with the volume off for about a month= dead battery
Old 05-31-2010, 08:44 PM   #98
aerotruk63
aerotruk63's Avatar
LOL. Wait till you install the clock, Battery killer as well!
Old 05-31-2010, 09:14 PM   #99
aerotruk63
aerotruk63's Avatar
Bostrom Viking T-Bar seat was an option as well. You could find a pair locally.
Old 08-03-2010, 12:32 AM   #100
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very cool truck, good deal too!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
