Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 06-28-2014, 12:29 AM   #76
Captainfab
60-66 Nut
Re: '60-'62 Power Brake Booster Adapter Bracket
Looks good
Thanks for posting pics
Old 08-08-2014, 11:00 AM   #77
blown240
blown240's Avatar
I got mine in the mail yesterday. It sure is a nice piece!
Thanks again Captainfab
blown240 is offline   Reply With Quote
Old 08-08-2014, 10:35 PM   #78
Captainfab
60-66 Nut
Thanks for the compliment.......I appreciate the business
Old 10-28-2014, 08:18 PM   #79
62BlueBetty
Hi Captainfab, I'm an admirer of your work, and would like to order a booster bracket for my '62 automatic and would also like it in the black powder finish. Thank you in advance.
62BlueBetty is offline   Reply With Quote
Old 10-28-2014, 11:27 PM   #80
Captainfab
60-66 Nut
I'll send you a PM with payment info.
Old 11-03-2014, 11:46 PM   #81
62BlueBetty
I received my booster bracket and am very pleased with the speed of shipment, packaging (well-protected in box, and finish further protected with vacuum packaging), the mounting hardware, and the quality of the product. Thank you, CaptainFab: your workmanship and attention to detail is excellent.
Old 11-04-2014, 01:39 AM   #82
Captainfab
60-66 Nut
Thank you for the compliments. I appreciate it and the purchase
Old 05-14-2015, 08:50 PM   #83
63Ton
I'd like to order a 60-62 booster bracket powder coated.
Mark
63Ton is offline   Reply With Quote
Old 05-14-2015, 11:34 PM   #84
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Mark
Old 05-18-2015, 04:20 PM   #85
runningiron
runningiron's Avatar
I got my 60-62 Power brake booster adapter bracket today. Another satisfied customer. It is very nice and I will recommend your work to others. Thanks Captainfab.
runningiron is offline   Reply With Quote
Old 05-19-2015, 12:33 AM   #86
Captainfab
60-66 Nut
Thank you I appreciate it
Old 06-18-2015, 06:38 PM   #87
short62
Hi Capt I want to buy your 60-62 power booster bracket for a automatic truck please send me info on how to get one
short62 is offline   Reply With Quote
Old 06-18-2015, 11:46 PM   #88
Captainfab
60-66 Nut
I will send you a PM.
Old 07-31-2015, 01:10 AM   #89
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
which one will I need for a 60-62 firewall that was set up for hydraulic clutch, but is now a standard (63-66 style) clutch?
getting ahead of myself here , but I am not sure if I will have to change out the pedal support from 61 to 63-66 with the clutch change as well....not sure if that will make a difference with the bracket or not?
also not sure if I am going with hydro boost , or regular power brakes, with your bracket(s) do either of them still need the rod from the pedal to the booster shortened/lengthened?
thanks.
Old 08-01-2015, 01:06 AM   #90
Captainfab
60-66 Nut
Well, this booster bracket is designed to not only bolt up to existing holes, but also cover the no longer needed clutch master hole. However I'm sure you could easily take care of that extra hole another way. As for the pedal bracket, I do not know if you could simply change just the clutch pedal and the arm on the end, or not. If that won't work, you will have to change the entire pedal bracket to a '63-'66 unit. Ultimately the booster bracket to use will be determined by the pedal bracket used.
Old 12-09-2015, 04:03 PM   #91
Budman56
Budman56's Avatar
I need one capt for a 60-62
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 12-09-2015, 11:50 PM   #92
Captainfab
60-66 Nut
I replied to your email.
Old 12-09-2015, 11:53 PM   #93
Budman56
Budman56's Avatar
Paid thank you again captainfab
MY 65 C20 BUILD
Old 12-10-2015, 12:48 AM   #94
Captainfab
60-66 Nut
Payment received. I will ship your booster bracket tomorrow as promised. Thanks for the purchase
Old 02-01-2016, 10:15 PM   #95
Cletus1960
Thanks Capt,
Packaged way better than anything else I've been shipped. Can't wait to install it when the weather clears up. Thanks again!
Josh
Cletus1960 is offline   Reply With Quote
Old 02-02-2016, 01:39 AM   #96
Captainfab
60-66 Nut
Thanks for the purchase and the compliment
Originally Posted by Cletus1960 View Post
Thanks Capt,
Josh
Old 03-13-2016, 09:08 PM   #97
harleychop
Here is the newest version of the power brake booster adapter bracket that I've been making since 1993. This bracket is fabricated from laser cut 10ga mild steel and fits 1960-62 Chevy and 1960-63GMC Pickups, Suburbans and panels and is 100% bolt on using holes already in your firewall. The booster side of the bracket has a 3 3/8" x 3 1/2" hole pattern. Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998. You can also find compatable boosters on early to mid 70's Impala's. Of course you will have to join the booster pushrod to your stock MC pushrod that attaches to your brake pedal. This can be done by either threading both ends and using a coupling nut, or by just welding them together once you determine the correct length.
I have had the original version ('63-'66) of this bracket on my '66 Suburban and have driven over 120,00 miles with no issues. I have also installed these on a couple of local pickups with good results as well. If you are wanting to add hydroboost to your pickup, Suburban or Panel I also offer a mounting plate for the hydroboost HERE
The price on the bare steel brackets is $55.00 plus a flat $12.35 shipping in the US. If you are located elsewhere contact me for shipping charges. You can also get this bracket in a satin black powder coat for an additional $6.50. Mounting hardware is included.
harleychop is offline   Reply With Quote
Old 03-13-2016, 09:14 PM   #98
harleychop
Originally Posted by harleychop View Post
Hello, I would like to order your bracket for the brake booster. I am running a th350 trans, so I don't need the clutch version. I need your PayPal info so I can pay you. Thanks. I guess you can message me here or my email: markdelatin@yahoo.com
Old 03-13-2016, 11:16 PM   #99
Captainfab
60-66 Nut
I will send you an email since that is quicker.
Old 03-30-2016, 06:33 PM   #100
harleychop
Anybody have pics to show hoe you mated the brake pedal pushrod to the power booster?
