Old 07-22-2010, 08:25 PM   #76
ratty 46
Re: 1963 C10 SWB Big Window Build
Looking good.
I can't wait to sell my '87 crew & pick up a '65/6 short wb/b truck.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 07-23-2010, 09:53 PM   #77
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Converted the stock column steering shaft to a 3/4 DD. It turned out great with no slop and a tight fit.
I'm running a 3/4DD-3/4DD to 3/4DD-9/16 26spl. on the FR1503 manual rack.
DRTYRAT30 is offline   Reply With Quote
Old 07-30-2010, 07:39 PM   #78
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I got the steering all hooked up and motor mounts in. Pushed the truck out turned it around and pushed it back in for the rear now.
Old 07-30-2010, 10:23 PM   #79
ratty 46
Ah .... the ass-end. If it turns out as well & as clean as the front .... I building one of these too!!
You guessing on the steering right now or have you mocked up a block, head & exhaust??
Nice job so far.
Ratty 46
Old 07-31-2010, 01:20 AM   #80
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I'm good on the block & head. With the headers i might have to make some room. I have Flowtech's that dump in the rear.
Old 07-31-2010, 08:42 PM   #81
64shortc10
64shortc10's Avatar
Looks SWEET! Do you plan on removing the trailing arm crossmember with the cab on? Those rivits on the top are gonna be fun with the cab mounted! Good luck and keep going on the progress! I hope to be ordering my trailing arms here shortly! Again very nice build I'm jealous!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 08-01-2010, 01:40 PM   #82
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Well i hope i can knock them off with a air hammer. well see how it goes.
Old 08-01-2010, 01:57 PM   #83
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
It's been a while since I checked in. Beautiful work and great progress!!
Alan's Classic is offline   Reply With Quote
Old 08-04-2010, 10:31 PM   #84
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Thanks all.
Well i got started on the rear half and let me tell you those 4 little rivets on top of the trailing arm crossmember are a pain in the A$$. It took me 2 hours of grinding, air hammer and BFH to get that crossmember out of there. But its out and on to the next phase
What worked best for me was to grind off the heads on the inside of the top rail (4 rivets) and use the air hammer to punch them threw the top from the inside. Never had to try and get between the cab and frame. once the crossmember was out i grinded what was left of the top rivets and air hammered them the rest of the way out with a punch bit.
Old 08-04-2010, 10:49 PM   #85
ratty 46
Oh ... that looked like as much fun as me removing the center X member in my '46 frame!!
Keep us posted on the progress.
Ratty 46
Old 08-04-2010, 11:34 PM   #86
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
looks great
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 08-05-2010, 06:19 PM   #87
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Thanks guys. I got a lot more rivets to go
Old 08-10-2010, 02:01 PM   #88
64shortc10
64shortc10's Avatar
Any updates on this SWEET project?
Tony from Norcal
Old 08-10-2010, 04:17 PM   #89
franky69c10
chevy runs deep
franky69c10's Avatar
Originally Posted by 64shortc10 View Post
any updates on this sweet project?
x2
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 08-10-2010, 05:12 PM   #90
doublebeetx
Quick question . The previous owner of my frame , '65, decided to take out the crossmember. It was halfway done so I had to finish removing the rivets. So, here I am to put it back in. The holes are 7/16. Does your PB use 1/2 bolts to mount the new crossmember and drill the frame? I figure since I have it out,I will also compensate and center the rear wheels. Thanks, don't mean to take over. Awesome work !
doublebeetx is offline   Reply With Quote
Old 08-10-2010, 08:24 PM   #91
creep
Registered Loser
creep's Avatar
Man, That's just so cool. Lotta nice looking builds going on around here. The silver came out beautifully.
...and nice HPI Baja and Losi Mini Crawler.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 08-10-2010, 08:48 PM   #92
1LoC10
Insert Title Here
1LoC10's Avatar
awesome rides... i would of had a hard time selling that 54 though...lol
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-10-2010, 11:21 PM   #93
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Thanks guys. Well i have just been doing a lot of prep work on the frame. I sanded, primed & painted it today.
Old 08-11-2010, 12:37 AM   #94
DRTYRAT30
Jesse
DRTYRAT30's Avatar
The PB Adjustable Trailing arm cross member use's 7/16" bolts, Thanks
Old 08-11-2010, 10:46 AM   #95
REDNOSE65
REDNOSE65's Avatar
Man!!! It's looking awsome. Keep up the good work.
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 08-18-2010, 12:56 AM   #96
DRTYRAT30
Jesse
DRTYRAT30's Avatar
I got my Trailing Arm X-member, Notch & Bridge installed.
Old 08-18-2010, 11:57 PM   #97
GVizzle
GVizzle's Avatar
Get that thing on the ground!!
Looks sick, and I like your pace!!!
GVizzle is offline   Reply With Quote
Old 08-19-2010, 09:06 PM   #98
ratty 46
No welding on the rear section?? I know the bolts will probably hold it but .... I'm so much happier when things are welded on vs. bolted.
Looks good.
Your thoughts??
Ratty 46
Old 08-19-2010, 10:50 PM   #99
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Looks good.
Your thoughts??
Ratty 46
Being all Porter Built parts, I would have no worries about being bolt together. Heck the original frame is only held together by a couple dozen rivits.
Looking good!!!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-20-2010, 06:16 PM   #100
DRTYRAT30
Jesse
DRTYRAT30's Avatar
This thing is rock solid with 64 grade 8 bolts and nylocs. But i am going to do some welds on the inside bottom of the notch to frame area just to complete the box. Was waiting till i weld on the bag mounts to do it. Mocking up the 12 bolt rear now. Added a picture of my scrap pile.
