Old 04-26-2011, 09:19 AM   #76
76kcfdeng
Re: Jeffs70's Custom C-10 Build
The dash looks really good, looking forward to seeing it finished. Can't wait to get too the body on my truck. I think I am going to have some of the same issues with my bed. Keep after it.
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 05-01-2011, 06:24 PM   #77
Jeffs70
Jeffs70's Avatar
Hey 76kcfdeng, Thanks It surely is fun to do some different things to these trucks and working on it alot is the trick to getting it finished. Yeah the bed is a bit of a pain but if one sticks to it then it will turn out good
Jeffs70 is offline   Reply With Quote
Old 05-01-2011, 06:26 PM   #78
Jeffs70
Jeffs70's Avatar
Today I scored a set of Low Back Buckets for FREE so I am very happy. they need some work but how can I complain for FREE right? and I still am not sure if I will use these or my other seats I have orinally planned to use on this build. Also I am not to sure what these Low Backs are out of.
Old 05-01-2011, 07:28 PM   #79
Jeffs70
Jeffs70's Avatar
Here is some pictures I took after installing 3 of my air bags. I would have the last one installed but I screwed up one of the fittings that goes into the bag so I am holding off till I get more. Not a big deal just waiting time again. also going to wait to get the compressor and valves for the moment.
Old 05-01-2011, 07:30 PM   #80
Jeffs70
Jeffs70's Avatar
Old 05-02-2011, 09:05 AM   #81
67cheby
67cheby
67cheby's Avatar
nice WORK...KEEP IT UP
67cheby is offline   Reply With Quote
Old 05-02-2011, 10:33 PM   #82
Jeffs70
Jeffs70's Avatar
Thank you cheby
well here is a huge positive for me, I sold another 71 c-10 I had for sale for months so that money is going into this truck and some other things i have to take care of. looking forward to purchasing the rest of the air ride for starters.
Old 05-03-2011, 04:11 AM   #83
slick copper
slick copper's Avatar
Nice build! Subscribed! I'll be a watchin'!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 05-10-2011, 12:06 AM   #84
Jeffs70
Jeffs70's Avatar
Thank you slick copper.
Old 05-10-2011, 12:08 AM   #85
Jeffs70
Jeffs70's Avatar
Well today is the day I finished with the most difficult part of my Shaved Rain Gutters. I have them finished and started to lay a light layer of bondo to get it as smooth as I would like.
Old 05-10-2011, 08:40 AM   #86
Slick67
Sofa King Crazy!!
Slick67's Avatar
Dude! Your truck is going to be sick! This is a great project, and it has really changed that truck into what it should be. Great work Jeff.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-10-2011, 09:29 AM   #87
67cheby
67cheby
67cheby's Avatar
nice work , looking good
Old 05-10-2011, 01:15 PM   #88
Jeffs70
Jeffs70's Avatar
Hey Slick, Thanks. This was one huge job just doing the shaving of the rain gutters lol. I dont think I will ever attempt it again. but least the truck will be the way I want it now, so I can not complain to much.
Hey Cheby, Thanks, Alot of cusstumizing as ya go LOL
Old 05-10-2011, 01:54 PM   #89
dnd1978
dnd1978's Avatar
Your truck is looking good. What was the hardest part of doing the shaved drip rail? any tips? I will be doing mine soon.
Later
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 05-10-2011, 03:05 PM   #90
Jeffs70
Jeffs70's Avatar
Later
Hey dnd Thanks,
well I would have to suggest a few things when you do yours. cut the drip rails/gutters around the doors flat to the side of the truck and do not rip the metal out that keeps the door gaps, like I did. I only had to replace it lol. also the corners of the roof seemed to be the harder area' because you have to modify them quit a bit and remove sheet metal and add again but it all depends on your preference too. I also started out removing to much and had to do nothing but add it back...after you get around the corners It is alot easier and less removing and adding. just a slit here and there and tapping with a hammer to get the nice curve you want. also there is a seam on each corner. I welded mine pretty well and added a few pieces there..when you dig into it you will see what im talking about. but mostly its all about starting from one end and working to the other.
and the Corners are definately the hardest part of it all.
Old 05-10-2011, 03:24 PM   #91
Jeffs70
Jeffs70's Avatar
Here are some pictures of what I did on the corners. that may help you.
most of it is using a grinder and cut off die grinder to get the shape i had in my head. and adding pieces of sheet metal back where it needed to be.
Here is the lip that hangs over I had to clean up under it and around it to weld up. I noticed a bit of surface rust I had to get rid of also.
Old 05-10-2011, 03:37 PM   #92
Jeffs70
Jeffs70's Avatar
more pictures
Old 05-10-2011, 03:39 PM   #93
Jeffs70
Jeffs70's Avatar
everyones probably wondering why I left the windshield in and that is because I have not taken the time to take apart my steering column, I will Redo the Column Later due to the Parts where used any how but the windshield was trash any how so saved me from getting all that crap in the cab lol.
Old 05-11-2011, 04:42 AM   #94
slick copper
I would've done the same thing!
Raymond
Old 05-11-2011, 07:06 PM   #95
dnd1978
dnd1978's Avatar
Jeff,
Thanks for pics. I have seen it done a little different around the corner. I here when you cut the drop rail around the corner the roof pops up?
Would this have helped? Cutting along the orange line this way the roof will lay down and the gap is easier to fill. Then weld the orange line up after you finish the corner. What u think?
Old 05-11-2011, 07:15 PM   #96
Jeffs70
Jeffs70's Avatar
Jeff,
Hey dnd. you are absolutely correct. I did have to cut along the orange line just like that to get it to be more a smooth corner after not known any different when doing it like the picture shows. but got to working with it and cut that area and it worked perfect.
Old 05-13-2011, 06:28 PM   #97
dnd1978
dnd1978's Avatar
Thanks Jeff,
It looks like a lot of work but i think its worth it.
Old 05-14-2011, 01:14 AM   #98
Jeffs70
Jeffs70's Avatar
Thanks Jeff,
Hey dnd, Yes its alot of work but totally worth the effort of a great look. took me working on it off and on for 3 weeks. but if i would have kept working on it straight time it would have taken maybe 2-4 days for the sheet metal work.
Old 05-15-2011, 03:28 PM   #99
1970TokyoMaterSS
1970TokyoMaterSS's Avatar
Repost
1970TokyoMaterSS is offline   Reply With Quote
Old 05-15-2011, 03:41 PM   #100
1970TokyoMaterSS
Diggin the build! Havent been on here before and really explored. You have some awesome creative ideas.
Had my truck for 8 years and havent been able to restore it or even get started. Now the Army is moving us to SA, Tx hopefully Ill get started soon.
Definitely a Subscriber!
70 C10 SS Clone Pickup Project
No Build Thread yet
Bowtie or DIE!
67-72 chevy, build thread, chevy c10, chevy truck, custom hot rod
