Old 05-21-2011, 08:31 PM   #76
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
Pic 1 One piece window kit arrived.
Pic 2 Packaged very nice.
Pic 3 The upper piece has been put together with parts from kit, rest of parts for other side.
Pic 4 Additional parts and the angled pieces for front of door.
oldman3 is offline   Reply With Quote
Old 05-21-2011, 08:34 PM   #77
oldman3
oldman3's Avatar
This is the angle piece that comes with the one piece window kit. It screws into the door A pillar. We decided to add this metal piece and weld to the post, to make a cleaner look, both inside and outside. If truck was painted this could not be done without repainting.
Old 05-21-2011, 08:37 PM   #78
oldman3
oldman3's Avatar
Pic 1 Clamped in place.
Pic 2 All welded with rolled edges, a little filler and it will look great. Their piece is sandwicked between the inter and outer pieces we installed.
Pic 3 This is the glass, which will be installed later.
Old 05-21-2011, 08:41 PM   #79
oldman3
oldman3's Avatar
Pic 1 Cutting out patch for bed stake area.
Pic 2 All removed.
Pic 3 All installed.
Old 05-21-2011, 08:44 PM   #80
oldman3
oldman3's Avatar
Pic 1 Another repair area.
Pic 2 Before capped.
Pic 3 After capped.
Old 05-21-2011, 08:47 PM   #81
oldman3
oldman3's Avatar
Pic 1 Where old chain latch was, can also see the added metal in upright.
Pic 2 Hole filled, added metal ground down for better look.
Pic 3 Another view, hole left here for later work.
Old 05-21-2011, 08:49 PM   #82
oldman3
oldman3's Avatar
Pic 1 Part of bed painted with encapsulator paint.
Pic 2 Left side of bed
Old 05-21-2011, 08:53 PM   #83
oldman3
oldman3's Avatar
Pic 1 With the bed up on it side you can see how the stake pockets are just tacked to the rail.
Pic 2 Second pocket.
Pic 3 Third pocket.
Pic 4 Were welded in solid on all three pockets.
Old 05-21-2011, 08:55 PM   #84
oldman3
oldman3's Avatar
Pic 1 With the welding done, under rail was painted with encapsulator paint.
Pic 2 Another view.
Old 05-21-2011, 08:57 PM   #85
oldman3
oldman3's Avatar
Tomorrow we post more pics of work on the bed, and some more mods.
Old 05-21-2011, 09:48 PM   #86
lil hoodlum
lil hoodlum's Avatar
I like the way you work!!! You don't mess around and get right to it and get the job done! You even do the job really well.
I can't wait to see more progress on this.
Good job!
Keith
lil hoodlum is offline   Reply With Quote
Old 05-22-2011, 07:41 PM   #87
oldman3
oldman3's Avatar
Good job!
Keith
Thanks for the kind words, but don't forget truck is done, and I'm just now posting the pics.
Old 05-22-2011, 07:42 PM   #88
oldman3
oldman3's Avatar
On with todays post.
Jimbo (owner) removing paint from original left front fender.
Old 05-22-2011, 07:46 PM   #89
oldman3
oldman3's Avatar
Pic1 One of the inner fender panels.
Pic 2 Inner fender panel scrapping tar,etc.
Pic 3 Another view, then ready for blasting
Pic 4 Inside of panel painted with encapsulator paint.
Old 05-22-2011, 07:49 PM   #90
oldman3
oldman3's Avatar
Pic 1 Where the upper and lower door pieces meet, this will be cleaned and welded.
Pic 2 Here it has been welded together on pass. door.
Old 05-22-2011, 07:52 PM   #91
oldman3
oldman3's Avatar
Pic 1 The inside part of the two pieces, this will also be cleaned and welded.
Pic 2 Bad pic, but will also be welded at the front part of door.
Pic 3 Getting cleaned up ready to weld.
Pic 4 Not a good pic, but inside of door weled together.
Old 05-22-2011, 07:56 PM   #92
oldman3
oldman3's Avatar
Pic 1 At the top of doors where the outer skin overlaps, all tacked and will be welded solid.
Pic 2 Close up view.
Pic 3 Welds ground down and a little filler added to door.
Pic 4 Another view.
Pic 5 Filler sanded and ready for primer.
Old 05-22-2011, 08:00 PM   #93
oldman3
oldman3's Avatar
Pic 1 One piece glass wedge with filler.
Pic 2 New right front fender, fixing up their spot weld areas.
Pic 3 Some body work on front of new fender.
Pic 4 Left front fender blasted inside of fender, and painted with encapsulator paint.
Old 05-22-2011, 08:03 PM   #94
oldman3
oldman3's Avatar
Pic 1 Checking gaps around the door and body, put encapsulator paint in the pitted area.
Pic 2 Body work on the top of cab.
Pic 3 Body work on the original right rear fender.
Old 05-22-2011, 08:04 PM   #95
oldman3
oldman3's Avatar
That's it for today, hope to see you tomorrow.....Jim
Old 05-22-2011, 09:20 PM   #96
flatbed51
flatbed51's Avatar
Jim you must have bought a drum of encapsulator paint.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 05-22-2011, 10:58 PM   #97
oldman3
oldman3's Avatar
Not a drum, but a couple gallons. I like using the stuff, easier that POR, and does a good job. You'll see a lot more of it before I'm done
Old 05-23-2011, 07:52 PM   #98
oldman3
oldman3's Avatar
Had a wild night here in Missouri, but my neck of the woods was OK.
Pic 1 Back to the bed again, showing banged up inside of bed.
Pic 2 Another view, here you can see the years of banging things around and how bad the panel is. This will be addressed later in the build.
Old 05-23-2011, 07:56 PM   #99
oldman3
oldman3's Avatar
Pic 1 Working on pass. side panel. Welding in metal on the rear stake pocket tailgate area.
Pic 2 This part of rail was super bad, so cut it out and replace.
Old 05-23-2011, 07:59 PM   #100
oldman3
oldman3's Avatar
Pic 1 Got exhaust tubing the same size and cut away part of circle to match old rail curve.
Pic 2 Add metal, tack together and check fit.
Pic 3 Another view, here you can see the exhaust tube, and the 1/8" metal welded to the tailgate area.
