Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 08-30-2014, 02:32 PM   #76
skorpioskorpio
Re: 13" and 14" Corvette Brakes for C10's
Yea, rotors are a consumable part was my point. Axles, hubs, wheels you buy once and it is what it is, rotors you'll need to have them drilled every time you need to replace them as part of routine maintenance and those heavy 20" wheels will make that more frequent.
Personally for me, this is the reason I went with Z51 brakes, far cheaper to deal with from a maintenance stand point and other than hard track use will function nearly as well, especially if you factor in that Z51s will let you run lighter 18s (barely) and Z06s push you into a heavier 19" wheel. Then again I run my brakes hard and run slotted rotors which if you want them to bite well are really doing a total brake job with rotors every, or at least every other, time you do them.
DBS slotted rotors and Hawk HPS pads will run you about $400 or so to change out, Z06s of the same type will run about $650, and Wilwood, Baer or Brembos will be closer to a grand if not over and stationary calipers with the padlets have to be done more often.
skorpioskorpio is offline   Reply With Quote
Old 08-30-2014, 02:48 PM   #77
low69chevy
low69chevy's Avatar
Post Re: 13" and 14" Corvette Brakes for C10's
I think I understand what your trying to say but on the rotors why would I have to get them redrilled every time they already come in a 6x5.5 bolt pattern as far as maintenance truck isn't going to be a daily driver actually it's hardly going to get used since I'm always working. Also I may be wrong but these rotors etc will last quite a while on my 06 ss clone it's got about 90k miles on it and still has the original rotors and it's always had 22s or larger wheels since day 1 when I bought it new in 06
low69chevy is offline   Reply With Quote
Old 08-30-2014, 03:04 PM   #78
low69chevy
low69chevy's Avatar
http://m.summitracing.com/parts/bae-6920962
this is the passenger rotor i believe
Old 08-30-2014, 05:24 PM   #79
slimneverdies
slimneverdies's Avatar
Do these come in the 5x4.75 bolt pattern?
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 08-30-2014, 09:41 PM   #80
skorpioskorpio
The rotors come drilled with the bolt pattern of the hubs, so 'Vette rotors are drilled for 5x4.75, any other bolt pattern requires the center to be drilled for the new bolt pattern. I suppose you wouldn't need to redrill if it's a 2 piece modular rotor, though when I looked at those for my application they were triple the price, again new hubs would be cheaper. Kore3 did custom milled hubs for me for way less than a set of 2 piece rotors with caps, bearings and seals and anodized. Not to say my brakes were cheap they weren't not by any measure, but they are cheap to maintain, for 13.5"F/13"R brakes and have integrated parking drums.
These are the type rotors I have, DBA T3 one piece:
Either side slotted, no holes.
Old 08-31-2014, 02:11 AM   #81
slimneverdies
I have z06 rotors which are 14" but I would like the 15" rotors. They seem to only come in the 6 lug for the later model Chevy trucks
Long live SLIM
Old 10-06-2014, 09:00 PM   #82
dkauffman05
dkauffman05's Avatar
Anything g ever come of the camaro or cts calipers on a cpp modular spindle ? Or what's the cheapes route to make them happen ? I plan on running 18" wheels.
dkauffman05 is offline   Reply With Quote
Old 10-07-2014, 02:22 AM   #83
DC43
DC43's Avatar
Are you still offering the kits? do you have a rear kit available? Pm me prices for a 5x4.75 if you still are. Thanks
DC43 is offline   Reply With Quote
Old 10-28-2014, 02:53 PM   #84
chase@ridetech
chase@ridetech's Avatar
I may have missed it, but do these work with our Ridetech modular C-10 Spindles?
chase@ridetech is offline   Reply With Quote
Old 10-28-2014, 04:14 PM   #85
skorpioskorpio
This is my setup for the CPP modular with the Z51 PBR sliders for 13 1/2" rotors. It required spot machining the spindles as the CPP spindles are only faced on one side and my dual sandwiched bracket and spacer setup needed flat parallel surfaces on both sides. A lot of this has to do with the increased offset distance my custom hubs and pin mount adapters needed. It pushed the caliper too far out from the spindle to deal with with spacers on brackets on one side only. I was worried I would introduce a lot of caliper shudder if not outright failure of the casting. These were custom made for me (along with custom milled hubs) by Kore3. Oh and they do clear an 18" wheel, well mine anyway, but only by about 1/8th of an inch.
Old 10-28-2014, 05:16 PM   #86
raic65
raic65's Avatar
I made a set of brackets for my setup. See post 5. I believe John Glenn (astronaut) is doing the same with his C10.
http://67-72chevytrucks.com/vboard/s...22#post5891322
raic65 is offline   Reply With Quote
Old 05-06-2015, 08:54 PM   #87
slammed48
slammed48's Avatar
What do you suggest using in the rear with this front set up?
Also, have you tried putting these on a Belltech dropped spindle?
slammed48 is offline   Reply With Quote
Old 05-07-2015, 05:38 AM   #88
skorpioskorpio
This is my rear setup 13" (Also from a Z51 'Vette) with integrated parking brake drums inside the rotor hat.
Old 12-06-2015, 08:46 PM   #89
ranger2339
ranger2339's Avatar
Are these kits sill available?
ranger2339 is offline   Reply With Quote
Old 02-27-2016, 05:29 PM   #90
G8DAN
G8DAN's Avatar
Bump. Are the kits still available? I may be interested in one within the next few weeks.
G8DAN is offline   Reply With Quote
Old 03-30-2016, 08:52 PM   #91
G8DAN
G8DAN's Avatar
Would you still be open to having us send you the CTSV rotors and calipers for designing of the bracket?
Old 11-01-2018, 10:38 AM   #92
chevyschevy
Anyone know if these are still available?
Looking to buy now.
chevyschevy is offline   Reply With Quote
Old 11-01-2018, 10:48 AM   #93
way2lo2
way2lo2
way2lo2's Avatar
Looking to buy now.
yes sir
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 11-01-2018, 10:59 AM   #94
chevyschevy
PM sent
Old 01-12-2019, 03:22 PM   #95
ChuckLee
Email sent. This looks like a no-brainer.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 03-17-2019, 11:56 PM   #96
siggyfreud
siggyfreud's Avatar
Still selling these? I PM'ed you a few weeks back but haven't seen anything.
siggyfreud is offline   Reply With Quote
Old 03-18-2019, 01:14 AM   #97
EVRLET
EVRLET's Avatar
Kore3 also specializes in Corvette brakes. I have the Z06 front and rear on my 67.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 03-18-2019, 07:25 PM   #98
siggyfreud
siggyfreud's Avatar
I got a reply to my PM, and have responded. Looks like they're still selling them, just have gone a little quiet on the thread perhaps.
