Old 10-09-2011, 04:24 PM   #76
Steve Hafner
Steve Hafner's Avatar
Re: Project "My Happy Mess"
I'm enjoying following your project, it wasn't THAT long ago that mine was as APART as yours is now.
I'll have better pictures of mine as soon as the rear gears are installed this week and it can FINALLY come HOME !!!
Steve Hafner is offline   Reply With Quote
Old 10-09-2011, 04:35 PM   #77
VA72C10
VA72C10
VA72C10's Avatar
Nice!!! Grill looks great!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-09-2011, 05:48 PM   #78
litew8
litew8's Avatar
Thanks! The grille surround came out shinny, but there are some lower spots on it from sanding out deep pits/scratches. I don't care so much - it'll give it a little bit of character (not too easy to spot, from a distance) and I'll say, that messed up part is from my hard labor!
Next up - putting the engine together (will take one night). Slap the tranny on the engine, paint the rest of the frame. After, will put new front pre-bent brake lines (in transit, maybe arrive Wed. morning) on from The Right Stuff Detailing in Ohio, then drop the engine/tranny. Also waiting on the parts that are getting cleaned up (sand blasted). Should be done Wed. also, if not sooner.
Here's the top end kit I'm using - Edelbrock 2097, in conjunction with these pistons.
I've bounced back and forth with the idea of building a 383, but in the end we decided to go with building a stout 355.
Rear suspension will be done soon after, it's easy enough it can wait.
Thanks Steve. I'm with you man, can't wait to get my truck back - together!
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 10-09-2011, 06:46 PM   #79
oldman3
oldman3's Avatar
Still following after day one, grill looks nice, front end look great after new parts installed and painted, I will continue to follow as long as you update.....Jim
oldman3 is offline   Reply With Quote
Old 10-09-2011, 10:18 PM   #80
litew8
litew8's Avatar
Thanks for looking Jim. I'll prob. be posting more updates this week and next at a more constant rate (hopefully). Got the TH350 transmission back tonight also.
Rebuilt with a different torque converter installed. Not sure of the specs, though it should align better with the engine's build.
Old 10-12-2011, 09:13 PM   #81
litew8
litew8's Avatar
Out of all the items I've ordered over the internet, the FIRST mishap happens durring my build.
Things were going so good until today. The Right Stuff Detailing shipped my brake lines and tranny cooler lines to NJ instead of IA.
Somehow they managed to change my shipping information from what I had entered when ordered. Same first and last name, different address.
This will set me back a few days (or more)
I have new pics I'll try and post late tonight.
Old 10-12-2011, 10:52 PM   #82
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great progress! It is looking great. One thing I'd recommend how ever, I saw where you said you're going to reuse the window gaskets? For $65-$70 I'd not fight the old hard shrunk seals and install new ones. But that's just me.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-12-2011, 11:37 PM   #83
litew8
litew8's Avatar
Thanks Ryan. My window guy suggested reusing them and said you cannot find that quality any more.
I think the window was replaced in the late 90's, and most likely the seals also.
Old 10-13-2011, 12:57 AM   #84
Dieselwrencher
I can't imagine why the quality isn't any good in his opinion. You don't even know what brand the ones you have are. Art Cunningham can hook you up with some. That's where I got mine and they fit and look sweet.
Ryan
Old 10-13-2011, 02:05 AM   #85
litew8
litew8's Avatar
I'll ask him for you.
Old 10-14-2011, 01:51 AM   #86
litew8
litew8's Avatar
This is another poster's (can't find the thread) picture that looks nearly identical to my engine build.
south side!
Old 10-14-2011, 04:22 AM   #87
litew8
litew8's Avatar
Meanwhile, back at the ranch... putting the HD camcorder to work!
The front end pictures I hadn't posted before.
Upper control (a) arm shaft replaced w/new.
Detailing -
TH350 rebuilt w/hd torque converter -
Cleaning the frame; blue and yellow paint exposed. Odd
Old 10-14-2011, 04:24 AM   #88
litew8
litew8's Avatar
Looking around, this is obvious. Someone smeared the numbers 441 on the firewall with paint. I'm assuming it is a paint code. My back bed panel also has 441 written on it (with soap?) with a few more characters.
Authentic 1971 Chevy Factory assembly line markings. Very cool/rare!!
My SPID shows my color scheme as # 551. That's probably because of the White addition.
Moving along... here's the block on the engine stand.
This block comes equiped with two holes (L or R) for a dipstick. One plugged.
Old 10-14-2011, 04:24 AM   #89
litew8
litew8's Avatar
Prepping the block for assembly. Cleaning. Tapping to clean.
Next up, a couple good once overs... "Dawn takes grease out of your way!"
Air drying -
Followed by a coating of...
Old 10-14-2011, 04:25 AM   #90
litew8
litew8's Avatar
Painted w/freeze plugs installed -
It's been a quick week.
Reading material: http://www.superchevy.com/technical/...8/viewall.html
Old 10-14-2011, 04:26 AM   #91
litew8
litew8's Avatar
Time for assembly -
Other products used during assembly -
Roller lifters/rockers; installation.
Push rod, checking clearance.
Positioned, roller rocker, adjusting.
Old 10-14-2011, 04:26 AM   #92
litew8
litew8's Avatar
Old 10-14-2011, 04:51 AM   #93
litew8
litew8's Avatar
Old 10-14-2011, 09:29 AM   #94
oldman3
oldman3's Avatar
Looking real good....Jim
Old 10-14-2011, 10:22 AM   #95
mightymouse
mightymouse's Avatar
looking really good litew8
mightymouse is offline   Reply With Quote
Old 10-14-2011, 11:21 AM   #96
Steve Hafner
That 441 is probably the build sequence or job number.
Mine had a 635 inside the right fender and on the firewall ( in grease pencil though )
I've never seen them written in paint !!!
Old 10-14-2011, 01:27 PM   #97
VA72C10
VA72C10
VA72C10's Avatar
Nice work and progress!!!
Old 10-14-2011, 09:13 PM   #98
litew8
litew8's Avatar
Thanks everyone! It's a relief to finally see things come together.
Sorry if some of the steps/pics are out of order. I tried to keep them straight.
@mightymouse, good to see you.
@Steve, tomorrow if I remember, I'll take a pic of the bed back #'s.
There are additional characters you'd prob. enjoy seeing
I've got more pics to try and post late tonight.
Got the brake/trans. line issue sorted. They've already resent another order, in IA already.
Going to try and get the tranny and oil pan (reusing old) painted next.
I HAVE got to get the rest of the (front) frame/suspension painted Saturday.
Might be one of the last days of warmer weather left!
Old 10-14-2011, 11:27 PM   #99
oldman3
oldman3's Avatar
litew8, thanks for the note on my build, I always like watching what other's are doing, might learn something new. Your doing great.....Jim
Old 10-15-2011, 11:30 PM   #100
litew8
litew8's Avatar
Me right now > Will post more pics tonight.
