Old 07-14-2015, 04:28 PM   #76
solidaxel
solidaxel's Avatar
Re: My caster mod (with pictures)
Chevyrestroguy, Any updates on your truck!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-19-2015, 06:02 PM   #77
crakarjax
crakarjax's Avatar
I'm mocking my parts up to do this mod but it looks like my lca only has .5" before it will hit the saddle during travel. Tons of space everywhere else, just the part of the lca that kicks out will be hitting. Has anyone run into this? The suspension is stock '72 so far.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 07-19-2015, 06:11 PM   #78
crakarjax
crakarjax's Avatar
Another angle. This is slightly past stock bumpstop travel.
Old 07-19-2015, 06:52 PM   #79
SCOTI
SCOTI's Avatar
I shaved that inside portion of the arm to get clearance to allow moving the arm forward .750".
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-19-2015, 11:56 PM   #80
crakarjax
crakarjax's Avatar
Thanks, I guess I'll go for it. Trim until it fits seems to be the consensus in general...
Old 07-20-2015, 01:11 AM   #81
crakarjax
crakarjax's Avatar
Ok I just went and tried to drill my cross-shaft... what kind of drill bit are you guys using? I didn't even make a dent. I have new TRW cross shafts and they seem to be made of a metallic form of diamond.
Old 07-20-2015, 09:52 AM   #82
chevyrestoguy
chevyrestoguy's Avatar
When I had mine done, I took them to a friend's machine shop and we chucked them up in a lathe and used a flat bottom carbide end mill. A local machine shop would not charge you much to do this. A standard hardware store drill bit set isn't hard enough to drill the hardened cross shaft. Plus, using a mill is much more precise because you can lock the shaft in the mill and get the new pin locations located exactly.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-20-2015, 09:56 AM   #83
solidaxel
solidaxel's Avatar
So you trimmed the arm and not the cross member?
LS 3 4L70E
Old 07-20-2015, 09:59 AM   #84
chevyrestoguy
I have been working some insane hours for the past 6 months, but I have been working on the '64 whenever I have the time. I've gotten a lot of stuff done, mostly the tedious little jobs that drive you crazy. I'll post up progress pictures soon.
My build threads:
Old 07-20-2015, 10:59 AM   #85
SCOTI
SCOTI's Avatar
I did a little off both as I did not want to trim too much off the 'ear' of the arm.
I installed my modified arms & was able to achieve 100% suspension compression w/o contact but ultimately switched to Porterbuilt tubular arms for other reasons.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-20-2015, 07:14 PM   #86
racecougar
racecougar's Avatar
FYI, before you drill your new lower control arm shafts, verify that they match the stock hole position. Some aftermarket shafts come with the hole already moved a bit.
http://67-72chevytrucks.com/vboard/s...&postcount=237
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 07-21-2015, 12:45 AM   #87
crakarjax
crakarjax's Avatar
Thanks for the heads up, I did save one old shaft for reference so I'll check it out. One interesting thing I already noticed is that there's only one locating hole in the new shafts, because obviously only one is needed as stock.
That sucks that I can't drill the hole myself, I bought a set of reduced shank bits just for this purpose! What if I just angle grind a notch across the shaft? If I go the right depth it would still prevent the shaft from rotating.
Old 07-21-2015, 09:04 AM   #88
SCOTI
SCOTI's Avatar
The hole prevents fore/aft shift as well as moving in a L/R arc. A slot would only limit one of those twisting forces. Needs to be a drilled hole.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-21-2015, 11:28 AM   #89
crakarjax
crakarjax's Avatar
If the locating nub is sitting flat on a flat surface of the shaft, the shaft won't spin without the u-bolts loosening significantly or the shaft rounding out. I can't see either of those happening without some other problems going on, and in those cases a rotating shaft would be the least of my worries!
Old 07-21-2015, 12:00 PM   #90
SCOTI
SCOTI's Avatar
Then do it.
I'll stick w/doing it the way the engineers designed it. Seems safer to me.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-22-2015, 05:48 PM   #91
crakarjax
crakarjax's Avatar
Thanks for this, my new shafts were drilled 1/4" further already! My question now is -- if I can go 1" should I? I see that most people go 3/4" over from stock, ofc there will be more trimming but it looks like I'll have room.
Old 07-22-2015, 06:06 PM   #92
picklito
Can you please post exactly what you bought? For a stock rebuild this is a great way to get a couple easy degrees. Thanks.
picklito is offline   Reply With Quote
Old 07-22-2015, 06:15 PM   #93
racecougar
racecougar's Avatar
The ones in the link I posted above are Mevotech brand. Part number MK6147 on RockAuto.
Old 07-22-2015, 06:19 PM   #94
crakarjax
crakarjax's Avatar
Mine are TRW 13168A made in USA
Old 07-22-2015, 06:23 PM   #95
picklito
Thanks. I'd be interested to know how many degrees that adds.
Old 07-22-2015, 11:22 PM   #96
crakarjax
crakarjax's Avatar
Should be some basic geometry if you know the distance between the upper and lower balljoints, and the current angle.
Assuming 9" between ball joints and a currently vertical spindle,
3.14 * (4.5^2) = 64 (radius of a circle)
360 * (64 * .25) = 1.4 degrees (360 degrees in a circle times the fraction of the circle that is 1/4")
So 1" should net about 5.6*, 3/4" would be around 4.2* gain
Old 07-28-2015, 01:56 AM   #97
crakarjax
crakarjax's Avatar
I ended up grinding a small flat in the shaft and then drilling with a 5/8" masonry bit. I noticed in the process that I didn't need to sink the hole in the shaft at all on the sides because the locating pin sits flush with the seats as they slope upward -- I think grinding flats for locating would work just fine considering this, since a sunk hole is actually just removing material that doesn't need to be there. Using a cap screw might be a different story though depending on the head depth.
Old 07-28-2015, 12:30 PM   #98
gringoloco
A guy with a truck
gringoloco's Avatar
Anyone done this with CPP arms?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-28-2015, 01:57 PM   #99
SCOTI
SCOTI's Avatar
I would measure CPP's vs OE. Seems like they do this from the start & why they can advertise 'improved geometry'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-29-2015, 01:20 PM   #100
gringoloco
A guy with a truck
gringoloco's Avatar
Research has led me to believe they gain caster via the uppers, which would pull the wheel back further.
-Chris
