06-07-2012, 05:42 PM | #76 |
Tot Roddin'
Re: The Wagon and Pedal Car thread.
Lookin' good!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-07-2012, 09:52 PM | #77 |
GEARHEAD
I got an idea in my head about a year ago for a wagon I wanted to build. This thread got me to start putting it together. I have fabbed up every part so far except the wheels and tires. It's not done yet and I won't show the whole thing until it is, but here's a teaser pic:
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
06-07-2012, 10:37 PM | #78 |
Tot Roddin'
Ohhh... I like what I see so far.
06-14-2012, 02:00 AM | #79 |
But Found Her 25yrs Later!
This is what's left of mine from the mid 60's
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-15-2012, 08:13 PM | #80 |
Here are some more pics of mine. The pic without the wood is before spindles. Just trying to see how it was going to look. The other two are as a roller with everything burned in. When I take it back apart for paint I will take pictures of the the frame I built. Also there is one satin red wheel and thats how they all will look when done. It has just a slight amount of rake to it. I wanted more but the nature of the tires does not allow it. The axle is welded at the lowest point possible on the spindles. I wasn't crazy about the rear wheels and tires because I thought they were to big untill I got the fronts on and It made it proportional, now I think it looks awesome.
Bud |
06-15-2012, 09:39 PM | #81 |
GEARHEAD
Very cool.
06-16-2012, 07:48 PM | #82 |
GEARHEAD
I got a couple rod ends I had ordered so I could finish up my suspension. I made a couple brackets and now I have a track bar that functions perfectly, and it's adjustable. I also swapped out the springs because I found some bigger ones at the swap meet last weekend. Now it won't bottom out the trailing arms to the frame.
I'm still working on the wagon box part.
06-16-2012, 10:30 PM | #83 |
GEARHEAD
Not done yet, but I couldn't wait to share.
This is the bed for my "wagon". It's just roughed in at this point. I made it about 1/2 scale of a real shortbed, except narrower. The sides and rear panels are made with 3 layers of plywood. I just got the tailgate part roughed in tonight. Cutting that slot across it was the most challenging part of the build so far. The last parts to fab up are the wheel tubs. I haven't decided yet if I will shape them like the real ones or just make some round ones. I will blend in the contours and body lines with body filler, epoxy primer it all to seal it, then do the body work like a real truck. I plan on painting it to match my truck. The floor will be stained plywood with bed strips added (once I find a couple to cut up). If I find better wheels with slightly smaller tires later I will probably swap them. For now I think I will paint them with some chrome like paint I have and maybe try to add white lettering to the tires. I'm thinking about using a caster wheel under the front near where the handle will go. My wife has a craft paper cutter and I'll have her make me some lettering for the tailgate. Trailing arm... Attachment to the bracket I made... Crossmember for my spring support and to add some rigidity to the frame... Axle attachment to the trailing arm, with spring installed... Chassis...
06-17-2012, 11:12 AM | #84 |
Looks sweet!
Bud |
06-20-2012, 09:23 PM | #85 |
Here is some more progress on my wagon. All I have to do is thread the axle ends paint the frame and wheels, and polish the aluminum pieces going on it.
Bud |
06-21-2012, 01:58 AM | #86 |
Square
its coming along awesomely! is it pretty heavy?
Squarebody Syndicate |
06-22-2012, 09:08 PM | #87 |
Yes, if you are talking to me. I think it will be around 40 to 50 pounds without the kid in it. I could be way off but it gets old putting it on the welding table and then taking it back off every time I work on it especially with the wood in the bed.
Bud |
06-28-2012, 05:53 PM | #88 |
It is finished for this year. There will be modifications in the future. I would like to thank forum member SBORIS for giving me the wear strips for free including delivery from about an hour away while he was headed to work.
Bud |
06-28-2012, 07:51 PM | #89 |
GEARHEAD
Looks great! I hope mine turns out as nice.
06-28-2012, 08:27 PM | #90 |
6>8 Plugless........
It looks great Bud!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-16-2012, 08:23 AM | #91 | |
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
07-16-2012, 07:48 PM | #92 |
Anyone know anything about this one? I rode the wheels off of it as a kid, and never have seen another one like it.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-18-2012, 08:51 PM | #93 |
Square
I think black hornet is the brand. they made chain driven tractors also. I see those pedal cars every so often at antique stores but they always want way too much for them.
07-20-2012, 09:40 AM | #94 |
C10 Club Tennessee
Finished Lizzy's pedal stroller yesterday. Going to add a removable pole on the seat that I can stick an umbrella that I modified in for shade.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
07-20-2012, 10:25 AM | #95 |
GEARHEAD
I don't think I have ever typed the word 'cute' on this board, but, well, there it is.
07-20-2012, 11:07 AM | #96 |
Hey Bryan that steering wheel looks great, glad it worked out for you
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
07-26-2012, 01:03 PM | #97 |
C10 Club Tennessee
Thanks Graham
She finally got to use it this weekend at the Southeastern Truck Nationals. Here's a pic of my buddies that I saw at last years show and gave me the inspiration.
07-26-2012, 02:29 PM | #98 |
Turned out awesome Bryan. Looks like she had more fun than she could handle.
Bud |
08-05-2012, 05:30 PM | #99 |
Here is my BEER Wagon. I made it haul coolers full of beer for JITH http://www.jamboreeinthehills.com/
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
08-05-2012, 05:33 PM | #100 |
Some pics of the underneath
