Old 11-06-2012, 11:31 AM   #76
1963c-10
1963c-10's Avatar
Re: Hood & fender emblems
One cool fire truck there. I light the high mount spotlights. And thanks for sharing the emblem
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-29-2013, 10:50 PM   #77
sodly
sodly's Avatar
Does anyone know if a 66 Custom Camper will interchange with a 66 C20 emblem? Are the holes the same?
sodly is offline   Reply With Quote
Old 04-29-2013, 11:17 PM   #78
rideblue00
rideblue00's Avatar
yes they will. i just compared them both.
rideblue00 is offline   Reply With Quote
Old 05-27-2013, 01:34 PM   #79
1964jmarc
Hello, I bought a 1964 C-10 Custom Suburban, and it has 3 holes on the side of the hood near the front tires, its a 3 hole triangular pattern and I can't seem to find an emblem that goes there, thinking the hood may be off of a GMC, but the V6 emblems I see only have 1 prong, not 3? Anybody have a similar hood?
1964jmarc is offline   Reply With Quote
Old 05-27-2013, 04:26 PM   #80
MusicMan70
MusicMan70's Avatar
Which year would these be from? I also have a set like this minus the "Magnum" script and lightning bolts.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-29-2013, 12:30 PM   #81
creep
Registered Loser
creep's Avatar
Are your turn signal lights rectangle or does the inside edge angle up? May not have been badges there, could have been something else a P.O. installed.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-29-2013, 09:29 PM   #82
1963c-10
1963c-10's Avatar
are the holes on both sides or just one? might have been a turn signal mount. i have seen them installed on the hoods and fender extensions
Old 06-01-2013, 12:09 PM   #83
1964jmarc
nope, holes on both sides,
Also, turn signals are rectangle....looking at the web pics, looks like GMC's turn up, I see what your getting at, can't be a GMC hood, I learn something everyday on this site! Thanks...
Old 06-01-2013, 03:25 PM   #84
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
looks like 66-68, that does not have the big angle to it like a 60-66, it looks flat, so I am thinking 67-68?
here is some info:
The 477.7-cubic-inch (7,828 cc) 478 was one of the largest V6 engines ever built. Gross output was 235 hp (175 kW) at 3200 rpm and 440 lb·ft (597 Nm) at 1400 rpm. Bore was 5.125 in (130.2 mm) and stroke was 3.86 in (98 mm). It was introduced in 1963 in the 6500 series trucks.
It was superseded by the 1966 478M "Magnum" series, and production ended by 1974. Gross output was now 254 hp (189 kW) at 3700 rpm and 442 lb·ft (599 Nm) at 1400 rpm.
also:
http://www.6066gmcguy.org/Jolly-401v6.htm
Old 06-13-2013, 01:57 PM   #85
1963c-10
1963c-10's Avatar
Ok, have a new addition. The 1960 & 61 hood jets (ornaments). Here are a few pics from different threads and a few from one that I just got. The shorter nose is the GMC and the longer nose is the Chevy version
Old 06-13-2013, 01:59 PM   #86
1963c-10
1963c-10's Avatar
Heres a few more and a pic of where i've mocked up to install. If someone has a nice installed pic of a GMC hood jet, please post the pic for us.
Old 06-13-2013, 02:25 PM   #87
vin63
It's Better With Nitro
vin63's Avatar
Here's a thread I started a few years back regarding an emblem I milled that was based on the Apache 10 script from the 1960 hood emblem.
http://67-72chevytrucks.com/vboard/s...d.php?t=354378
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-13-2013, 02:37 PM   #88
1963c-10
1963c-10's Avatar
very cool, we'll have to post a pic of it here
Old 06-13-2013, 02:46 PM   #89
vin63
vin63's Avatar
Here you go...
Old 08-14-2013, 11:27 AM   #90
1963c-10
1963c-10's Avatar
Any new additions?
Old 08-14-2013, 06:05 PM   #91
bhc41051
bhc41051's Avatar
I wonder how hard the "Diesel" badges on the hood are to find?
bhc41051 is offline   Reply With Quote
Old 08-14-2013, 09:10 PM   #92
1963c-10
1963c-10's Avatar
ive never seen one personally. may also be an item they used for advertising or concept that never made production. now the search begins to see if anyone has a pic or has ever seen one in person. very cool though.
Old 08-14-2013, 10:48 PM   #93
Lugnutz65
Lugnutz65's Avatar
The 3 guys in the picture are smiling waaaaay too much for that same picture to be used in any advertising these days.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-15-2013, 12:00 AM   #94
spacedebris
I WANT IT!!! Damn, now you've given me another thing to start looking for.
spacedebris is offline   Reply With Quote
Old 08-15-2013, 06:59 AM   #95
eglide78
My 64 C10 has perfectly aligned holes on left and right side cowling(s) but I have yet to come across what emblem may have been there. Somewhat new to this so go easy.
1964 C10... work in progress
1971 GMC 2500 Sierra Custom Camper
eglide78 is offline   Reply With Quote
Old 08-15-2013, 07:03 AM   #96
eglide78
We would come up to a stop years ago riding 3abreast like that and me being in the passenger seat I would bend down like I was tying my shoe and it would look like driver and pivot man were sitting cozily next to each other.
Old 08-15-2013, 08:18 AM   #97
bhc41051
bhc41051's Avatar
The truck is a General Motors Argentina D-200. My Spanish isn't that good but as far as I can tell, It's a 1/2 ton short stepside, BBW with a 4 cylinder diesel. 4 speed transmission, 16" wheels and 2 batteries. The only options I see are a radio, heater and locking rear end or "steering lock" not sure. I have the brochure scanned. I can't seem to shrink it down enough to post. If anyone would like it just PM me with email address and I'll send the pdf.
Old 08-15-2013, 08:43 AM   #98
1963c-10
1963c-10's Avatar
Sounds to me like you have cowlings off of an earlier model that had emblems placed higher. The cowlings can be swapped from 60-66. Also there were a lot of dealers that installed dealer emblems in these locations.
Old 08-15-2013, 11:15 AM   #99
1963c-10
1963c-10's Avatar
I thought D-series was a dodge designation even in the foreign trucks.
Old 08-15-2013, 02:19 PM   #100
piratexpress1369a
piratexpress1369a's Avatar
pm sent
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
