Old 12-30-2012, 03:45 PM   #76
ole dollor
ole dollor's Avatar
Re: 1966 C20 LWB onto 1977 Suburban C10 Chassis
seats are a real pain , i took three and made one....looks like yours is coming along good. like what you have done..
ole dollor is offline   Reply With Quote
Old 12-31-2012, 04:07 AM   #77
Nopocustoms
Well after yesterday I was plenty frustrated with the slow progress, and mediocre results, I didn't expect pro-show-quality for my first attempt with amateur equipment - however it was slow, tedious and seemed like I overthought it.
Today, I hustled to the shop at the crack of Noon, and the lowe seat cover was waayy too far gone to use as a template, so I just went for it.
First it was peel it back to foam, then clean it up and paint the frame.
Then I just popped the main cloth down, traced it in chalk and cut it out 3/4 of an inch around it.
Nopocustoms is offline   Reply With Quote
Old 12-31-2012, 04:11 AM   #78
Nopocustoms
I decided to do a better step by step today, I just marked it right on the "edge" which was a little challenge - because it's rather gradual.
Then I cut it out with a margin, marked center and marked a center front aprin. and pinned it - I find that you cannot use enough pins, and keep it flat and straight.
Old 12-31-2012, 04:14 AM   #79
Nopocustoms
Next I measured the sides, it was 8" X 26 so I cut it HUGE - 10.5 x 34 To leave plenty of space, and did my level best to pin it a bunch and curve in one swoop.
Here is the basic lay out and flopped back over, I will have to come back to the seam where the side and front apron meet.
Old 12-31-2012, 04:18 AM   #80
Nopocustoms
After sewing sides on, and pulling over the front to my satasfaction, I had to find way to sew the sides to the apron. I ended up cutting back the apron, folding the side over itself and re-sewing the entire front edge. Then I just pulled in a bunch of slack from the sides and pinned and sewed the vertical seams.
Old 12-31-2012, 04:22 AM   #81
Nopocustoms
finally I tossed a piece on the back of the seat so I could pull it all taught - then I spent a half an hour getting it as good as it could be - , a few clips held it in place and then with some help, we straightened out the visible seems. When happy, I put the spring clips back on the new cover, and trimmed it -
Old 12-31-2012, 04:27 AM   #82
Nopocustoms
Pefect? No, Waaaay better than I expected - Yes Absolutley, Would it be way better, faster and easier next time, I think so and I will let you know...
Here is a before and after -
Would I do it again, Yes, it was fun - and I enjoyed the project. Cost effective for a resto or driver No. For material, and if I was paid my wages, at 11 Hours - A pro is cheaper!
Interior guys don't get enough credit - that was harder than rebuilding a 12 second Small Block - and I spend more time in my rides than under my hood...
Old 12-31-2012, 04:26 PM   #83
shok
Pretty impressive for a DIY type interior and I agree with what you learned next time will go even better.
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 01-01-2013, 12:07 PM   #84
50bomb
50bomb's Avatar
Awesome work! Love these old pickups
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 01-09-2013, 10:13 PM   #85
Bomp
Bomp's Avatar
You got skillz Man.
Switched frames and got the front bumper lookin' killer.
Then you (for next to nothing) whipped out an awesome seat. Dig it.
Bomp is offline   Reply With Quote
Old 01-28-2019, 09:07 PM   #86
Country705
Country705's Avatar
Any updates? The story just kind of stopped lol
And in the end, it’s not the years in your life that count. It’s the life in your years.” — Abraham Lincoln
Country705 is offline   Reply With Quote
Old 01-28-2019, 10:49 PM   #87
Nopocustoms
Solid point, I have a ton of pictures - and have done some other odds and ends, but still have a windshield to install and to repaint the interior. I've put quite a few miles on it since 13, I'll get back at it for the board!
Old 01-30-2019, 12:25 AM   #88
AJCK87
Awesome job! Just saw it hahaha. I’ll be giving the seat work a go here, soon x3. What type of sewing machine did you use and how think of thread? Just curious
AJCK87 is offline   Reply With Quote
