Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-24-2013, 11:56 AM   #76
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 1940 "project moonshine"
standard stamped steel.it comes with a grey coating on it.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-27-2013, 12:35 AM   #77
CHIZZLER
CHIZZLER's Avatar
few pics from today.got the motor and tranny back on the chassie.made another parts list.
61-crew cab D-max
Old 01-27-2013, 01:04 PM   #78
CURSED GEARS
Pretty cool build. Kind of makes me wish I had fenders on mine. Mine started out as just a cab though.
CURSED GEARS is offline   Reply With Quote
Old 01-28-2013, 09:43 PM   #79
CHIZZLER
CHIZZLER's Avatar
got the metal bed strips from mar-k today.used some 1x12 early 1900's barn wood i had to use on the bed floor.turned out pretty good i think.chizzler
61-crew cab D-max
Old 01-28-2013, 09:46 PM   #80
duallyjams
duallyjams's Avatar
Where did you get the barn wood from , I've been looking for some to do the bed also.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-28-2013, 09:49 PM   #81
CHIZZLER
CHIZZLER's Avatar
if you were closer i would offer some up.i scored about 1400 linear feet from a guy that had it stored for 20 years.i paid less than a $1 per foot.he was 2 miles from my house.
61-crew cab D-max
Old 02-03-2013, 04:20 PM   #82
CHIZZLER
CHIZZLER's Avatar
got the wnidshield glass and new seals in and put it back on the cab.also got the back glass in.
61-crew cab D-max
Old 02-04-2013, 10:52 PM   #83
Bomp
Bomp's Avatar
Gotta keep watchin'
Bomp is offline   Reply With Quote
Old 02-05-2013, 09:18 PM   #84
docrock
docrock's Avatar
looks great. Is there some trick to getting the windshield frame apart to put the glass in? I pulled all the screws and soaked it with PB rust and it still wont come apart. Your back glass looks great with the diecast on there
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 02-05-2013, 11:10 PM   #85
CHIZZLER
CHIZZLER's Avatar
we had to drill all the screws out and just pull the ends back and forth and use some penetrating oil.it took a bit to get it loose.we had the new glass cut locally and got all the seals at chevs of the 40s.everything fit pretty good.
61-crew cab D-max
Old 02-13-2013, 07:43 PM   #86
CHIZZLER
CHIZZLER's Avatar
few update pics.boss got the firewall and dash painted.put the dash all back together and put it back in the cab.put the side glass back in the doors.set the cab back on the frame.we used lime green flake on the firewall and dash.
61-crew cab D-max
Old 02-13-2013, 07:48 PM   #87
CHIZZLER
CHIZZLER's Avatar
something else i was working on was making the bed floor filler panel look a little more rusty.before and after.
61-crew cab D-max
Old 02-13-2013, 08:18 PM   #88
Scottshotrods
It is getting there !!!!
Justin
Scottshotrods is offline   Reply With Quote
Old 02-13-2013, 09:57 PM   #89
duallyjams
duallyjams's Avatar
That's a cool time lapse pic of the bed
dig the firewall n dash
James
IG duallyjams
Old 02-13-2013, 10:10 PM   #90
JRE
looking good. FYI we're having a get together on the 16th at stark street pizza at 2 pm.
JRE is offline   Reply With Quote
Old 02-13-2013, 10:27 PM   #91
CHIZZLER
CHIZZLER's Avatar
thanks all.its coming together nicely.
61-crew cab D-max
Old 02-16-2013, 11:05 PM   #92
CHIZZLER
CHIZZLER's Avatar
got some more done today.got most of the front sheet metal on.put the head lights in.more to come.thanks chizzler.
61-crew cab D-max
Old 02-16-2013, 11:54 PM   #93
Scottshotrods
Layed out killer !!!!!!
Old 02-17-2013, 12:14 AM   #94
CHIZZLER
CHIZZLER's Avatar
thanks justin.we have not set the bump stops to final till we get all the weight back on.but there is no problem puttin it on the ground thanks to a killer ifs and 4-bar.
61-crew cab D-max
Old 02-17-2013, 07:39 PM   #95
scotts72heavyhalf
scotts72heavyhalf's Avatar
Looking totally killer as expected, cant wait to see it in person, now if the weather permits Ill drive out with the boys.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 02-17-2013, 08:31 PM   #96
paintman
Hey Chizz, lookin schweeeeeet! If you don't mind me asking, what rear are you using? looks to be a bit narrow for a 1940 pickup.
paintman is offline   Reply With Quote
Old 02-17-2013, 10:45 PM   #97
youngrodder
youngrodder's Avatar
Looks killer Chizzler....what did you do rob the burb of its headlights..jk
Really like where you going with this one.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-17-2013, 11:10 PM   #98
CHIZZLER
CHIZZLER's Avatar
Originally Posted by scotts72heavyhalf View Post
looking totally killer as expected, cant wait to see it in person, now if the weather permits ill drive out with the boys.
thanks scott.
Originally Posted by paintman View Post
hey chizz, lookin schweeeeeet! If you don't mind me asking, what rear are you using? Looks to be a bit narrow for a 1940 pickup.
71 chevelle 12 bolt.running a 820-15 tire in the rear.
Originally Posted by youngrodder View Post
looks killer chizzler....what did you do rob the burb of its headlights..jk
really like where you going with this one.
Marc
THANKS MARC.USED THE SAME HEADLIGHTS AS THE BURB.
61-crew cab D-max
Old 02-18-2013, 09:02 PM   #99
paintman
[QUOTE=CHIZZLER;5895546]
So you are about 62 1/2" wide?
Old 02-20-2013, 11:56 AM   #100
CHIZZLER
CHIZZLER's Avatar
i have not measured it,but online sources say 61 1/4" wide.
61-crew cab D-max
