Old 01-08-2013, 07:39 PM   #76
Gene
Gene's Avatar
Re: My 56 6bt 4X4 build.
Nice build! Love the old 4by's!
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 01-08-2013, 08:01 PM   #77
6BT 56
6BT 56's Avatar
not too much to report as of lately. The Toronto boat show is abt to open and we have tons of work to do. I work for the Largest Sea Ray dealer In Canada. so not too much extra time rite now. I plan to get the rad cradel mocked up to mount the rad . then I can pull it apart again . get the eng painted and a few things done , Get the frame boxed up front and then slide the eng back in to start to fab the mounts. who knows ..... Maby it will stay in next time ????????
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 01-14-2013, 11:05 AM   #78
SAVAGE-RIDER
Any more progress with the truck?
Looks awesome!
SAVAGE-RIDER is offline   Reply With Quote
Old 01-14-2013, 08:14 PM   #79
6BT 56
6BT 56's Avatar
I have been worken on getting the D60 fixed up, kingpin bearings , bushings. Brakes and such. The eng comes out tomorrow nite after the first fitment. Then the front axle can get some paint on and get bloted in. After that its on to frame boxing . spend a little bit of time everyday. Haven fun and moving fwd. Dosent get much better than that I guess
Old 01-19-2013, 10:31 PM   #80
6BT 56
6BT 56's Avatar
So lots of good progress to report. Got the D60 front all cleaned up . New king pin bushings , and lower bearings. Brakes and wheelbearings too. Got the 70 rear done to. Didnt do the brakes yet tho. Still at 50 % and Im thinking abt going to rear disk. No sence buying new drums and stuff at this point . Got all the stuff painted and installed. It was way too easy. Something has to go wrong here . Look at the pic of the rear shocks. the dodge lower mount and the 56 gm upper. Fit perfect.!! Added 4 leaves to the front to help with all that extra weight.
Now on to the dodge. going to cut out the front crossmember as I thik i can make it work guite easily. just as long as it dosent hanf too low and hit the front diff.
So enuf with this here are some pics.
Old 01-19-2013, 10:58 PM   #81
ryanroo
ryanroo's Avatar
Looks good! nice shop too
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 01-20-2013, 03:31 PM   #82
plummen
I had a 59 gmc 9600 series napco 4x4 years ago like a 2-2 1/2t truck,got stolen from the place it was stored.
Spotted it once but it was gone when I came back with the law.
plummen is offline   Reply With Quote
Old 01-20-2013, 09:56 PM   #83
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looking good, I would love to have that shop!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 01-20-2013, 11:40 PM   #84
Luther Grimace
Luther Grimace's Avatar
Man it is looking really good! Ready to see some tires on it!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 01-21-2013, 01:46 PM   #85
plummen
Looking good!
Old 01-21-2013, 10:14 PM   #86
6BT 56
6BT 56's Avatar
I was happy on the wknd. I went out and grabbed up the stock dodge steel wheel's and the 70's hub cas I got fit perfect. Now to decide what tires to use. Thinken tall and skinny . 235 85 . BFG. I wish the old style M/T was still available. The new Ta Km is too agressive looking. I may go with a A/T or possibly look elsewhere for a not too agressive M/T.
Have you got your fan yet? What speedo pickup does your T/c have? I have to find a mechanical for mine. Then a longer speedo cable .
Also trying to figure out what Im going to do with my clutch linkage. I am using the stock 56 pedals. I attached a pic. As you can see the pedal arm and the cross shaft are way off. Was thinking abt the stock dodge hyd stuff but there is no place that has a straight swing in the pedal area to push the master.
I took a better look at the dodge crossmember after you mentioned it. The gm frame is wider than it but after I box the front frame rails this will make it a perfect fit. Going to cut the rivets out this wknd. think I will take the dodge front shock mounts while Im at it.
Old 01-22-2013, 12:04 AM   #87
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work, can you flip your rear shocks though? It might help keep the surface on the rod clean and not damage the seals and prevent early failure.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-22-2013, 12:49 AM   #88
Luther Grimace
I haven't got my fan yet. I will prolly get it here soon. Hopefully it will fit. I am looking for a belt that I can use without the fan but I need to find the right length. I need to check on the speedo but I think it is mechanical I hope. Where did you get the long cable from?
Old 01-22-2013, 01:01 AM   #89
dmack91
dmack91's Avatar
Have you looked at LT255/85/16LT tires? They are getting hard to find, but I have run them on my 99 Dodge for 8 years and like the taller (33.5") but thinner profile.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 01-22-2013, 11:44 PM   #90
6BT 56
6BT 56's Avatar
Hey Luther . Are you taking the fan pulley off to? Im leaving mine so the stock belt works. Just unthreaded the fan from it. No I dont have a speedo cable yet . Was hoping you had figured it out and had a partnumber for me
As for the shocks diesel wrencher , I did want them mounted the other way as I am sure having all the fluids held in by gravity rither than the seal will make em last much longer. I got lazy tho cus the bushing from the dodge shocks was rusted on there . And that end of the new shocks had no steel insert in the bushing. Ta Da lazy mans answer.!! Upside down shocks!!
Ill get them flipped when you get your frame boxed !!!
Made a call today as I want to add powerbrakes. I had allready bought the new pedal mount and dual master and pop valve when I installed the first driveline. Now I have all this new stuff and it wont work with any booster I have found yet. Local guy wants to sel me kit with booster , pop valve and master. Thats going to make for a lot of extra hardly used parts.
May still try to make a hydroboost work. I have 2 complete in a milk crate ......somewhere....
Old 01-23-2013, 01:36 AM   #91
Luther Grimace
I want to not run it so I will have room for the fan motor but I don't know if I will have enough water pump pulley coverage. I think I will prolly buy a speedo cable from classic parts of america.
Old 01-23-2013, 09:33 PM   #92
Dieselwrencher
You better get on it, because next week I'm starting to box the frame and install my gooseneck..................
Ryan
Old 01-27-2013, 12:08 AM   #93
6BT 56
6BT 56's Avatar
So I was messin around a bit today and i thought Id better slip some tires on the 56 to see how it looks and to get some motivation before I pull all the front tin to make eng mounts and such easier . These are the 35's off the dodge. I dont want this big a tire just thought id snap a pic while it was in the air. i will post a few pics tomorrow of the GM steel wheels and the 70's hubcaps
Old 01-27-2013, 12:52 AM   #94
ryanroo
ryanroo's Avatar
gonna be a sweet looking truck!
72 K20 12v build
Old 01-27-2013, 12:55 AM   #95
Luther Grimace
Looking awesome! Did you figure out your clutch situation out yet?
Old 01-27-2013, 01:37 AM   #96
6BT 56
6BT 56's Avatar
Thanks guys. I just took the 35's off and put 4 235 85 goodyears I had on. Much better I think . Going for the 50's 60's work truck vibe and 35 M/T's were far from it . Lol. will post a few pics tomorrow.
No I havent figured out the clutch yet. I wont likely have that figured out till the eng goes back in for another test fit. That will be a few weeks yet.
Still looking to hear if anyone on here has used a hyd clutch setup with the orriginal 55 to 59 underthe floor clutch pedal. Any one ???????
Old 01-27-2013, 11:22 AM   #97
ryanroo
ryanroo's Avatar
i bet it wouldnt be to hard to make work. i would have to see a stock style clutch set up, but im sure it could be made to work
72 K20 12v build
Old 01-27-2013, 01:36 PM   #98
6BT 56
6BT 56's Avatar
Hi Ryan.
my main problem with going hyd is that the master need a fairly straight thro on the plunger. all of the 56 parts move in quite a arc. I will deffinately try tho as it would be nice to use the dodge master and hoze and slave .
Old 01-27-2013, 07:05 PM   #99
Luther Grimace
I would try to rig something up like the master cylinder linkage. Then use these to connect it. http://www.summitracing.com/parts/rus-640281
Old 01-27-2013, 10:57 PM   #100
6BT 56
6BT 56's Avatar
Here are the pics of the wheels im going to use . As well as my 70's hub caps.
These are just old goodyear 235 85 16 I had. i going to look for a nice square looking tire when I get close to being on the road.
I saw this 73 on here some time ago and love the look of it . I like the white wheels and all new lug and axle hardware for contrast. may considder the white wheels. i really want a set of hupcaps like i have but the chrome ones .
4x4, cummins, napco
