Old 11-19-2014, 07:36 PM   #76
Ronzo
Ronzo's Avatar
Re: GMC and Chevrolet VIN and Model Number Decoders with pics.
Anyone have an idea on what that might have been? From what I can gather, there were two 6 cylinder engines available in 1960.
And the guy who was the second owner can't remember what engine it had. He got it in 1988 at the age of 12. I know it had a manual transmission because of the high floor hump.
Ronzo is offline   Reply With Quote
Old 11-19-2014, 08:21 PM   #77
bruceman1968
bruceman1968's Avatar
Ronzo, It's got to be the 235 I6 Thriftmaster. The 261 I6 Jobmaster only came in the c60 and up trucks.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 11-19-2014, 08:45 PM   #78
Ronzo
Ronzo's Avatar
Thanks so much, I appreciate the help.
Old 06-27-2015, 05:52 PM   #79
chefk85
chefk85's Avatar
I know this thread is a couple years old but I am having trouble decoding my VIN. Its located inside the glove box and it reads as follows. Will also attach a pic. KE141S677566. Title says its a 72 but the rear view is the cab attached type not windshield mounted.
chefk85 is offline   Reply With Quote
Old 06-27-2015, 06:03 PM   #80
bruceman1968
Chefk85, Welcome to the board.
You VIN decodes as follows:
KE141S677566
K = 4wd
E = V8
1 = 1/2 ton
4 = pickup
1 = 1971
S = St. Louis assembly plant
677566 = Build Sequence Number. In 1971 all truck BSNs started at 600,000, so your truck was the 77,566th truck to be assigned a BSN at St. Louis in 1971.
Old 06-27-2015, 06:14 PM   #81
chefk85
chefk85's Avatar
You are so awesome. thanks bruce. Title says its a 72 but I knew it not to be so . Quick reply. I like it. the truck has VERY little rust and a 283ci out of a 68 pickup. almost all original and I picked it up for 1400.00 bucks. It is a welcome addition to our chevy family and I look forward to sharing picks and build progress with you guys.
thanks again,
chefk85
Old 06-27-2015, 06:23 PM   #82
bruceman1968
The title being off a year is very common as the truck model year was not the same as the calendar year. If you want start a thread on your truck and post some pics. We would love to see it.
Old 06-27-2015, 06:38 PM   #83
SS Tim
SS Tim's Avatar
More important is the door pillar number plate and the frame numbers, they should all agree. But the number provided is in fact a 71 production VIN. Its also among the last of the last built there in 71. The blue door sticker is probably dated 7/71.
SS Tim is offline   Reply With Quote
Old 12-29-2015, 12:28 AM   #84
Cmvcruiser
Cmvcruiser's Avatar
Wow. Great info. I'm a newby to this forum and it's amazing the amount of information and knowledge you guys provide.
Thanks so much
1970 GMC
Cmvcruiser is offline   Reply With Quote
Old 01-08-2016, 09:12 AM   #85
MikeCofield
Can some one decode this one
MikeCofield is offline   Reply With Quote
Old 01-08-2016, 09:53 AM   #86
Sklptrljay
Sklptrljay's Avatar
Look at the next to last decoder box.
2WD/I-6/1/2TON/PICKUP/1970/St. LOUIS/SERIAL NUMBER
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 01-08-2016, 12:42 PM   #87
MikeCofield
It's a blazer
Old 01-08-2016, 01:07 PM   #88
MikeCofield
And the frame matches too
Old 01-08-2016, 01:37 PM   #89
Sklptrljay
Sklptrljay's Avatar
Hmm. The VIN doesn't match the door placard.
Mistake? Or........?
Since everything else is the same I'm guessing it's just a mistake on the door.
Old 01-08-2016, 02:32 PM   #90
SS Tim
SS Tim's Avatar
Interesting 4X2 70 Blazer.
There is a conflict between the model designation on the VINs, the door pillar plate and the SPID. But everything supports the fact it appears to be an original vehicle with a production typo.
Both VINs should read CS180S156361.
The actual build and options generally break down as:
1970 Blazer 4X2 (CS10514)
250 cid 6 cyl engine (std)
3-speed, column shift, manual trans (std)
Base trim (std)
Driver and passenger HD utility bucket seats (AN3)
White hard top (Z58)
8.25-15/4RP highway tread, tube-type, tires rear and spare (RL2)
G78-15/B highway tread, tube-type, front tires (RL5)
Gold vinyl trim interior (690)
Medium Gold Poly exterior (526)
Painted bumpers front and rear (std)
In all a nice general use truck.
The Gold trim was a one year only option.
Old 01-08-2016, 03:04 PM   #91
Sklptrljay
Sklptrljay's Avatar
I had a feeling that you'd chime in Tim.
Old 01-08-2016, 03:08 PM   #92
MikeCofield
Thanks Tim and Bruce man
Old 01-08-2016, 03:54 PM   #93
bruceman1968
Anytime Mike, always happy to help.
Old 02-04-2016, 12:41 AM   #94
89AKurt
89AKurt's Avatar
Exactly why I joined this forum, great job, and thank you!
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-06-2016, 03:04 PM   #95
AirPenguinSkipper
Hi All,
I have acquired a chevy truck and I'm having trouble figuring out exactly what it is. I have some paperwork including the original maintenance log with the VIN stamped on the edge and the metal plate I believe originally located in the glove box. Here it is, can someone help me please?
CE338Z130550
Thanks!
AirPenguinSkipper is offline   Reply With Quote
Old 03-06-2016, 03:37 PM   #96
SS Tim
SS Tim's Avatar
Originally Posted by AirPenguinSkipper View Post
Hi All,
CE338Z130550
Thanks!
The VIN number itself is a fairly basic breakdown, but it does tell us:
C Chevrolet conventional cab truck 4x2
E V-8 engine (does not indicate size)
3 30 series truck, 1 ton
3 Chassis cab, no bed/incomplete
8 1968 model year
Z Fremont CA assembly plant
130550 sequence number of light trucks assembled a Fremont for the 68 MY.
To determine any more we need the SPID label inside the glove box door. That will list the model as manufactured and any RPO or fleet options as well as trim and paint codes
Welcome to the board!
Old 03-07-2016, 04:44 PM   #97
AirPenguinSkipper
Thank you Tim! I'll search for the SPID label.
Old 05-08-2016, 11:35 PM   #98
ChevyCheyenne71
Hi guys i just buy a chevy cheyenne 71 C30 dually with a 350 the wheel base is 157 why a cant find the model number in the chart my model number is CE31403
And my vin ce331z644044 sorry for my english im a french canadian
ChevyCheyenne71 is offline   Reply With Quote
Old 05-08-2016, 11:39 PM   #99
ChevyCheyenne71
Vin and model#
Old 05-09-2016, 12:58 AM   #100
SS Tim
SS Tim's Avatar
The chassis cabs were intentionally left off the decoder table since they apply to so few trucks.
Not sure what the question is though. Yes your truck decodes as a factory C/30 V8 157" wheelbase chassis cab. From the options I'd say it was a motorhome at some point, but definitely a Cheyenne/30
