Old 08-18-2013, 09:34 PM   #76
brimc
brimc's Avatar
Re: 86 Silverado K20 12V CUMMINS Build
Got a bit done today. Fuel tank, supports all cleaned up and mounted with a 2" lift to match the Body lift.
One step closer!
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 08-31-2013, 10:13 PM   #77
brimc
brimc's Avatar
Well got only a small amount done to the truck this last week. Very Hot and Very WET.
Sending unit cleaned up in the glass bead cabinet and some fresh por15 to finish it off. I also modified the pickup tube to sit just about the bottom of the tank after I removed the filter/sock.
I think it will work just fine. Just need to get some good lines, fittings and clamps.
BRIAN
Old 08-31-2013, 10:47 PM   #78
brimc
brimc's Avatar
So since I can't do anymore on the fuel side until I go shopping, I decided to work on the air side for the time being. Started by pulling out the core support.
The support is in rough shape but I figure why cut up a good one? I can weld up the cracks and reinforce it better than new!
Then semi cleaned the inter cooler and taped up some cardboard to protect it during the mockup process.
I will be using the dodge rad for ease of use and buying easy replacement parts like hoses etc. I have to buy a new rad, this one is toast. I will just use this one for hacking up the rad support and mockup.
Now I plan on keeping the Mech. fan. I want to run this truck with as little electrics as I can. Also, I ran without a fan for several years and just installed it when needed. Takes 2 min. with the top of the shroud cut off as seen on the picture. If I cannot make it fit, ie: fan-rad clearance, I will go electric. For 95% driving this engine needs no cooling fan unless pulling and in traffic based on my previous 5 or 6 years experience pulling our 8000lb 26' trailer.
Hopefully more work and updates on the truck after this long weekend!
BRIAN
Old 10-27-2013, 08:32 PM   #79
881ton
881ton's Avatar
Nice job!, your truck is coming along really nice!
ROB
881ton is offline   Reply With Quote
Old 11-02-2013, 08:42 PM   #80
brimc
brimc's Avatar
Wow, long time no update. 2 months really?
Anyhow here we go. The rad support was in really bad shape. Aftermarket thin cheap tin crap. I went nuts with the cut off wheel and ended up with this,
Then ended up with this, a big old hole with a bunch of new metal tacked in place.
I used part of the dodge support and the holders for the IC. Little cutting, welding and the IC and Rad fit like a glove. I then decided I needed to test fit the entire cab and front end. So I did. First time Cab was back on the frame since I pulled the plug on the old 350 and pulled the trigger on parting the dodge.
I got a 1 inch body lift in there right now and I got the fenders/hood fitting, and open-close good as before, maybe better.
The IC and rad fit perfect behind the rad support, so there will be no issues with the grill or lights etc.
Just enough room for electric fans. Mech fan just touches the rad so I tossed it out back in the pile. Didn't really want it anyway.
Tons of room between the firewall and the block/head and the modded 2nd gen exhaust pipe.
What I really notice is that I think I have the engine sitting really low compared to others I have seen. I hope that works out to be better in the end because I am not moving it. haha
So then I ripped the front end all apart again and finished welding the core support and gave it a good coat of POR15.
Also got the IC cleaned up and put a fresh coat of paint on it as well.
Little bit closer.......
BRIAN
Old 11-02-2013, 11:43 PM   #81
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work and it's looking like a truck again!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-03-2013, 03:57 PM   #82
881ton
881ton's Avatar
Real nice work especially the fab work on the x member! keep it up .
ROB
Old 11-03-2013, 05:31 PM   #83
brimc
brimc's Avatar
Thanks Guys !!
Today I got the rad support mounted on the frame.
It really should have had a 2nd coat of paint but I ran out. Then I got the IC mounted using factory hold downs.
One thing I was really going for was to be able to replace hoses and belts with OEM parts off the shelf. This one made me feel good after confirming that it will work. IC boots and rad hoses fit perfect. I had to cut about an inch off one end of each IC tubes and will need 1 inch taken out of the rad hoses due to the engine being closer to the rad compared to the old Dodge.
Little by little. Sure wish time went as slow at home as it does a work !!
BRIAN
Old 11-03-2013, 06:52 PM   #84
red87gmc
looks good Nice fab work !
red87gmc is offline   Reply With Quote
Old 11-10-2013, 06:31 PM   #85
brimc
brimc's Avatar
Thanks.
Not got anything more done this week other than try to spray on a Cummins Logo on my IC. It will mostly be hidden but it looks ok. I got some other ideas for down the road as far as logos and name plates go.
BRIAN
Old 11-10-2013, 07:22 PM   #86
legendman
legendman's Avatar
Looking good!!
What are you doing for a fan setup?
I found out the hard way there isn't enough room between rad and stock metal fan on my setup.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 11-10-2013, 07:57 PM   #87
6BT 56
6BT 56's Avatar
My 56 ran all summer with no fan . I installed a electric slim fan I got from summit as I know I will need it some time . I never even got around to wireing it tho. The truck has never even moved a few deg off what it levels out at when the t stat opens. Even going thru the tim's drivethru on a hot day. My rad is it crummy condition as well. It's amazing how much water these things must move to be able to stay cool .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 11-11-2013, 03:57 PM   #88
Dieselwrencher
These things move a lot of water in the cooling system. They move so much that when you start running over 3k the water pump can over pressurize the cooling system and usually the rear most block freeze plug will blow out. I've clipped 2 fins on 6 fin pumps before to help, but then it doesn't cool the same if you hot lap it. So I just use billet freeze plugs and a by pass if it's going to be over 3k a lot.
Ryan
Old 11-11-2013, 05:30 PM   #89
brimc
brimc's Avatar
I am going to install a used electric fan from (?) at the scrap yard. I am thinking I will not need much just as "56" has mentioned. I also ran this engine for a few years without any fan with no issues. As far as running over 3K, only once did I even have it up anywhere near that. But that's another story.
Thanks for all the interest guys, I'll try and get some more work done to it so I can update.
BRIAN
Old 11-11-2013, 09:06 PM   #90
6BT 56
6BT 56's Avatar
Is your shop heated brimc? This time of year sure slows down the progress. I have a propane radiant tube in my shop i leave on all the time set at 40. When it gets colder I heat my home and shop with my outdoor wood boiler.
Old 11-11-2013, 10:20 PM   #91
brimc
brimc's Avatar
Ya unfortunately the weather plays a big part in "build" time and no heat in the garage slows things down a lot. The house wood stove is just inside the door tho. I have a large portable electric radiant heater I use if I need it just to take the edge off.
BRIAN
Old 11-12-2013, 12:16 PM   #92
6lcummins
Only time I have ever needed fans with either of my trucks has been when using the A/c. The Chevy lived in TX for 8 months and never got hot in DFW in aug-sept when its really getting hot in TX.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 11-12-2013, 10:23 PM   #93
brimc
brimc's Avatar
We'll it is defiantly colder up here compared to Texas!! Good to know. Maybe I will hold off of the fan until after a few good test drives.
BRIAN
Old 11-13-2013, 08:46 PM   #94
Dieselwrencher
I say put a fan on it now because as soon as you pull it out of the garage, it's highly unlikely to put it back and want to quit driving it.
Ryan
Old 01-26-2014, 10:39 PM   #95
spgill2000
Question Re: 86 Silverado K20 12V CUMMINS Build
Updates?!
spgill2000 is offline   Reply With Quote
Old 01-27-2014, 12:22 PM   #96
brimc
brimc's Avatar
Originally Posted by spgill2000 View Post
Updates?!
Thanks for asking!
I planned on updating by now, just haven't got to it yet. It has been one of the coldest with the most snow in a long time. (years) Hit-35 last week one day. Needless to say not much shop time.
I did get some neat emblems for Christmas.
I did start working on the engine bay wire harness. going to piece together the chev and the cummins from the doner to try and make it look somewhat clean and "factory" looking. (inside the house, not the garage )
I also have it narrowed down pretty close on the gauges. About 75% sure. Just have to convince myself it is worth the money. - about $900 for complete set. Here is a sneak peak.
As soon as winter lets up it will be full steam ahead on the cab and box. Really want to have it painted in the spring! We'll see.
BRIAN
Old 01-27-2014, 03:44 PM   #97
Dieselwrencher
Nice emblems and nice gauge. I like that it has a 4k tach instead of the typical 6 or 8k unit.
Ryan
Old 01-28-2014, 01:37 PM   #98
arrover
arrover's Avatar
Thanks for posting the Speedhut gauges. I had never heard of them but they make some really cool stuff. Appreciate the info.
1982 GMC Crew Cab 4x4 - "River Truck" build thread
1973-1987(91) Chevy/GMC How-To Videos
arrover is offline   Reply With Quote
Old 01-28-2014, 02:47 PM   #99
brimc
brimc's Avatar
Ya I really like them. You can customize them almost anyway you want.
Not sure about cost. I am still shopping. I worked out a complete set just over $900. I would still have to ship them to Canada too.
BRIAN
Old 01-29-2014, 12:37 PM   #100
brimc
brimc's Avatar
So let me say first off, it is fricken COLD. I have a small project going on inside with the engine wiring harness. I decided to try and add a "W" terminal hookup for a tach. I started with taking the back cover off.
Then I picked a terminal that looked to have the most room for clearance etc.
I drilled two access holes. One for a screwdriver, and one for the wire.
Made a new wire. Double heat sink cover.
This is what it looks like all back together. I am going to use the original alternator wires, which I cut out of the dodge, and run them to the battery, ground and voltage regulator.
Has anyone used this method for the tach signal? I have only read about it and have not tried it. Any and all feedback is greatly appreciated.
BRIAN
