Old 11-03-2013, 07:07 PM   #76
chad64chevy
chad64chevy's Avatar
Re: Project two tone.
sorry to hear about the carb! quick question, are your front fenders new? and if so, where did you get them? I've been thinking of buying new front fenders this yr.
chad64chevy is offline   Reply With Quote
Old 11-03-2013, 07:47 PM   #77
NEWFISHER
NEWFISHER's Avatar
Once switched from the single or 2 bbl carb to the 4bbl, did you always run a 600cfm or did you start with the 390?
NEWFISHER is offline   Reply With Quote
Old 11-03-2013, 08:08 PM   #78
clemdaddy
clemdaddy's Avatar
nice truck... gotta love that 292 torque monster. i've been thinking about the hei dist., that i see out there. do you have any experience with them?
clemdaddy is offline   Reply With Quote
Old 11-03-2013, 11:01 PM   #79
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Originally Posted by KroAutomotiveInc View Post
DAM that sucks i feel ya the first 2bbl carb i got for the 230 had striped out threads in the inlet line for the fuel and start spewing gas everywhere when i fired it up.
Yeah, before I got the 4 barrel I was running a 350 holley two barrel. Either I blew both the power valves or something else was srewed, cause sometimes it would work great and other times not.
WOW! WOW! I must be a good painter! HAHAHAHA!!! No they are oem off my 64 donor truck, funny though one of them has some rot out in the usual spot. Can't see it in the picture I suppose.
I started with a 350 cfm holley 2 barrel, then I went to the 600 cause I got the 4 barrel intake and headers.
A great hei is the Davis Unified ignition. You can purchase them at Precision Automotive Specialists. They run $300 I believe but deliver 50,000 volts!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-03-2013, 11:12 PM   #80
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I would find a set of nos or look for a same year donor truck with fenders that are in good shape. Reason is cause the re-pop fenders are made to fit the 60-66 chevy trucks. When I installed my oem fender from my 64 onto my 66 some of the holes were waaaay outta line. I would find fenders off a same year parts truck.
Old 11-04-2013, 08:07 PM   #81
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
So I put my new carb on today. Fire the truck up. RPM flies up to 2,500 rpm at fire up. Adjust the throttle and lower the idle and set it at 850. Has snappy acceleration and is slow back down to idle. Check all the vacuum lines and they are fine. SO I am thinking hmmm, if everything is sealed and lines are tight then why would it accelerate rapidly but slowly come down to an idle??? Well, it turns out this is the same issue I had with my first Edelbrock 600 before I got the replacement. And I believe through driving the carb started to learn the motor cause the slow de-acceleration back to idle was getting better. Not sure but it runs fine and pulls a hill without issue. Choked it while running and the engine died like it is supposed to when everything is sealed. I don't know...we'll see what happens down the road!
Old 11-04-2013, 09:37 PM   #82
4dranch
Shloooooong bed member #2
4dranch's Avatar
TJ,
This is Darrah.
Maybe I missed it, but what year is your truck ?
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 11-04-2013, 10:27 PM   #83
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Originally Posted by 4dranch View Post
TJ,
This is Darrah.
Hi Darrah, Mine is a 66. Like your truck! You have done a great job on it! It is nice to now I am not the only young buck restoring one of these!
Old 11-04-2013, 11:44 PM   #84
4dranch
4dranch's Avatar
Thanks T.J.
I'm Young but not a buck
David,
Daughters 66 truck:
Old 11-05-2013, 12:11 AM   #85
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thanks T.J.
Sorry! I should have said young person. But actually I am younger than you believe it or not!
Old 11-06-2013, 12:12 PM   #86
1963c-10
1963c-10's Avatar
Trucks looking great TJ....keep up the pics & progress
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-07-2013, 01:03 AM   #87
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thanks 63 c-10!
Well, sold the flatbed today that was originally on the truck when I got it! Now for a new set of valve springs!
Old 11-09-2013, 06:49 AM   #88
Dillon Rock
Hey T.J. just an update, leave dates got pushed. I'm takin 3rd of December till the 16th of December so a little more of an open window. Sorry to hear about the carb takin a crap on ya. Just one more thing, how old are you if you say "young buck"?
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
Old 11-10-2013, 09:08 AM   #89
64tantruck
64tantruck's Avatar
Just went thru you entire thread. Looking good. I realize after posting a few pics of our project in our thread, people's comments keep up focused and motivated. Keep up the good work.
Glenn & Cyndy
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 11-10-2013, 05:02 PM   #90
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Glenn & Cyndy
Thanks for the encouragement!
Old 11-12-2013, 11:04 PM   #91
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Small update. Well had a loooooong but nice cruise to Portland today, took care of some business then shot up to Keith's( 66farmer) and bought his side spare tire carrier! Thanks Keith! Enjoyed the visit! Can't wait to install everything!
Old 11-13-2013, 08:02 PM   #92
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Today I pull my non-cutout fender off and installed my longbed cutout fender to find that the tire I am using is to big to fit in the space. Reason is because the cut out is lower on a long bed fender then on a shortbed one. So I am on the hunt for a shortbed cutout fender. The longbed one will be posted on Medford Craigslist and is on Classic Parts Talk if anyone is interested.
Old 11-16-2013, 12:31 PM   #93
steveb64
Active Member
steveb64's Avatar
Here are some pics, let me know what you want to do.
I will send some more in a little bit.
steveb64 is offline   Reply With Quote
Old 11-16-2013, 12:54 PM   #94
steveb64
Active Member
steveb64's Avatar
TJ
Here are some more.
Old 11-16-2013, 01:24 PM   #95
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Steveb64, Here is a better picture...I'll take one of the rear dent in a bit.
Old 11-16-2013, 01:35 PM   #96
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
And here is one of the dent in the rear....not that big. And easily fixable. I am not a body person but if you want me to try and tap it out I can. Let me know what will work. T.J.
Old 11-16-2013, 01:39 PM   #97
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Well ya'all here is a picture of the carrier....Thanks Keith!
Old 11-19-2013, 12:36 PM   #98
1963c-10
1963c-10's Avatar
Very nice you got the brackets too. Hes a diagram to help out. I used a jaguar firewall grommet on the hole in the fender where the support rod passes through. Found it on ebay for like $3
Old 11-19-2013, 04:26 PM   #99
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thanks for the diagram! Looks like he forgot to give me a bracket.
Old 11-19-2013, 05:18 PM   #100
Ta2Don
Ta2Don's Avatar
Cataloging the Jaguar firewall grommet... need one for mine, Thanks!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
