Old 11-22-2013, 09:24 PM   #76
jimcaf
jimcaf's Avatar
Re: power window regulators on the cheap
Originally Posted by 70STOVEBOLT View Post
Jim, that was my intention. I don't have my motors yet so I can't drill the mounting holes.
What did you cut the big round hole with, a hole saw?
Mark ,,I used a hole saw
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION
Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed
The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10
jimcaf is offline   Reply With Quote
Old 11-22-2013, 09:26 PM   #77
jimcaf
jimcaf's Avatar
I just got my Ebay switches wired,,there real nice!! great deal on those,My local ecology pick a part wanted more $$
Old 01-21-2014, 04:11 PM   #78
70STOVEBOLT
70STOVEBOLT's Avatar
How do you remove the spring from the regulator?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-21-2014, 07:06 PM   #79
bonnieclyde100
put the regulator in the up position and pry it off carefully. it might help to put a towel over it while prying off.
bonnieclyde100 is offline   Reply With Quote
Old 01-21-2014, 07:42 PM   #80
Chrysis
Chrysis's Avatar
Well, looks like I have a winter Project! I had been thinking about doing this.
Chrysis is offline   Reply With Quote
Old 04-23-2014, 10:44 PM   #81
colgad
colgad's Avatar
I finished mine a while back but just got around to installing them now that the doors are painted. They work great the window goes up nice and quick. No issues at all.
Thanks so so much for this great tip. Glad I found it on YouTube and then the pattern on the forum.
thanks again
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 04-23-2014, 11:22 PM   #82
bonnieclyde100
glad it worked out for you to.
thanks again
Old 06-23-2014, 08:20 PM   #83
55dude
55dude's Avatar
great write up! ford taurus (95) has 9 tooth gear also. work great for AD truck conversion. those 91 motors are cheap $16 rockauto!
55dude is offline   Reply With Quote
Old 06-23-2014, 08:46 PM   #84
fastlane
fastlane's Avatar
sweet! defiantly doing this!!
1969 Chevy C/10 Stepside, Short Box. LQ4/4L80E swap in progress! (Donations being accepted!)
fastlane is offline   Reply With Quote
Old 06-23-2014, 10:53 PM   #85
Zeroman
Zeroman's Avatar
I cannot wait to do this mod.
Subscribed.
Zeroman is offline   Reply With Quote
Old 06-23-2014, 10:58 PM   #86
CG
BlahBlahBlah
I was messing around with one of these power regulators out of an Astro van, be careful of those springs. I cut the heck out of my hand when it caused the arms to scissor on me .... sorry no pics =)
Old 06-24-2014, 12:06 AM   #87
69chevytrucker
69chevytrucker's Avatar
at princess auto they have surplus motors im going to go buy a couple and do this
nice post love it anyway to get away from full retail im in lol
69chevytrucker is offline   Reply With Quote
Old 06-24-2014, 12:43 AM   #88
70blackfish
VERY KOOL! need to save this info
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 07-03-2014, 12:21 PM   #89
70STOVEBOLT
Originally Posted by snipescastle2 View Post
So, has anyone adapted a factory power window harness for control of the passenger window as well as the driver side from the driver's door switch?
I know there are aftermarket kits for these, but trying to keep with the "On the Cheap" Theme here.....any ideas?
Thanks!
Ben
Ben, that is my plan. I got a harness and switches from a square body from Krazy Ray on the parts board and I am going to use them. If you do the same, make sure you get motors that have the connector facing the rear of the vehicle, not the side. Otherwise you will have to modify the plastic end connector on the harness to fit the motor. I got the wrong motor the first time, but it was only $17 so no big deal. Still cheaper than the alternative.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 07-05-2014, 11:15 PM   #90
snipescastle2
snipescastle2's Avatar
Talking Re: power window regulators on the cheap
Thanks for the update, I'm working on a window switch that will allow you to keep the factory window crank in the same hole it was originally (like the aftermarket version currently available, but on the cheap, keeping with your theme ) I am using the broken door actuators from a set of doors I bought and using some micro switches, I'm attaching a few pics, but it's a work in progress, but hopefully it will give you all some inspiration to make a set and save some big money all the while looking "Stealthy"
Here are a few pics:
snipescastle2 is offline   Reply With Quote
Old 07-06-2014, 12:11 AM   #91
IADC43
IADC43's Avatar
Great idea here. Thanks for reviving the thread or I'd have never seen it
This should help on the wiring ideas:
Matt
43
IADC43 is offline   Reply With Quote
Old 07-06-2014, 05:30 PM   #92
69chevytrucker
i did it too just finished this mod is awsome
Old 07-06-2014, 05:34 PM   #93
69chevytrucker
another trick for the spring i clamp in vise cut tab with air hammer
release from vise
Old 07-06-2014, 08:55 PM   #94
69chevytrucker
just did my other one figured out how to get the guide to work a little better in the pic below you will see that if you cut the guide out like below you can put it in the vise and flatten it a little only needs to be flattened the thickness of the metal then it can be put over the gear and tacked in place.. also i welded studs to the metal instead of grinding the bolts
btw i really love this mod
i hope as guys figure stuff out with this mod they keep posting it one guy came up with this and as a team we are making it into a great mod go team go
Old 07-06-2014, 09:11 PM   #95
69chevytrucker
oops i see someone else beat me to the welding stud thing
Old 07-06-2014, 09:50 PM   #96
LSUMurse
LSUMurse's Avatar
I haven't had time to try (nor does it look like I will) this mod. I was thinking when I try it about using this switch and somehow affixing a stock handle to it instead of the switch handle that's there. I don't have anything to mock up with, so there may be clearance issues, etc. However, it seems a possible way to keep the stock look.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 07-13-2015, 09:07 AM   #97
Bombero412
Finally did this mod. Followed all instructions. Followed video on how to make a relay so you don't prematurely burn up the switches. Also got inspiration on the micro switches to keep the stock look. Here's a pic. It works great.
Bombero412 is offline   Reply With Quote
Old 07-13-2015, 09:14 AM   #98
Bombero412
Notice the springs keeping the unit centered. In the picture above.
Old 07-13-2015, 11:33 AM   #99
70STOVEBOLT
Do you have a schematic for wiring the relay?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 07-18-2015, 08:55 AM   #100
Bombero412
I actually used the schematics from the youtube video IA DC posted above and instead of going to the standard window switch it went to my home made switch. I will post a drawing of that. Check this video.... https://youtu.be/dLKuZeUe6is
