Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-08-2016, 02:09 PM   #76
First c10
First c10's Avatar
Re: Dream '69
I plan to use the stock AC controller for our trucks. so if I put the controller to defrost and the temp lever to warm the AC compressor will not turn on? is that due to a temp control that turns the Compressor off. and that is what the override is for?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-08-2016, 02:53 PM   #77
lawest
Re: Dream '69
Yes, the Old Air kit provides a bracket and microswitch that mounts to the back side of the factory controller that is activated by moving the temp slide control to the cold side. This is what activates the a/c compressor unless you add another switch to override the microswitch and allow the compressor to operate with the temp set to other than full cold.
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
Old 03-08-2016, 03:15 PM   #78
First c10
First c10's Avatar
Re: Dream '69
So the only thing that ativates the ac compressor is the temp lever in the cold position?
GO GO!!!
Old 03-18-2016, 01:03 PM   #79
lawest
Re: Dream '69
I got the new starter installed and wired up with new battery cables. Turned the engine over with the starter for the first time! Put in the coolant, tranny fluid, and gearbox lube. Ran the wire for the electric fuel pump and ordered a new GM HEI distributor, so as soon as I get that I can fire up the engine.
Old 03-31-2016, 12:39 AM   #80
60sIron
60sIron's Avatar
Re: Dream '69
Great build....... Subscribed.
60sIron is offline   Reply With Quote
Old 04-04-2016, 10:10 PM   #81
lawest
Re: Dream '69
So I got the distributor installed and started up the engine. Got it up to temp and set the timing, everything seems to be working good. Other than a leak at one of the radiator hoses there were no issues. I tried to upload a video but it didn't work, I guess it was too long or something. I am using the Joe Gibbs break in oil I bought at NAPA and its holding about 50 psi oil press. I have to get the rest of the truck together so I can drive it to finish the break in process so I don't want to run it too much, but will start it occasionally to keep the oil circulated until then.
Old 11-27-2016, 11:57 AM   #82
lawest
Re: Dream '69
I have been working finishing up the wiring and getting the dash finished. Also cut the holes in the speaker panels and finished up the stereo install. Ready for carpet.
Old 11-27-2016, 12:01 PM   #83
lawest
Re: Dream '69
I got the carpet kit from LMC installed. Not really happy with it but it will work for now. At some point in the future I plan to install a complete, custom interior once my new bucket seats are recovered. For now the stock interior will get me on the road.
Old 11-27-2016, 12:14 PM   #84
lawest
Re: Dream '69
The front wiring is done except for securing the wires after I get the fenders on.
Old 11-27-2016, 10:10 PM   #85
lawest
Re: Dream '69
I put the Old Aire glovebox in and added another 12V plug inside so I can charge electronics out of sight. The small plug is for a MP3 player to feed the stereo. Glovebox door is still at the paint shop along with the ashtray.
I also installed my new shifter boot.
I think the next project will be to install the steering wheel and the bench seat. Also need to get the glass guy out here to put in the windshield and back glass.
Old 11-30-2016, 11:15 PM   #86
mjensen
mjensen's Avatar
Re: Dream '69
This is looking awesome! Seems like I missed a lot during my little hiatus
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 12-03-2016, 11:30 AM   #87
lawest
Thumbs up Re: Dream '69
Thanks MJ, I haven't been the best at posting updates. I just forget to take pictures sometimes.
Old 03-22-2017, 08:19 AM   #88
lawest
Re: Dream '69
Thought I would post this link to my build thread in case anyone needs to replace your factory style windshield washer pump.
http://67-72chevytrucks.com/vboard/s...93#post7460293
Old 05-14-2017, 04:33 PM   #89
lawest
Re: Dream '69
It's been a while since I posted any updates. Lots of little details and just waiting for the bed to get painted. Installed the steering wheel(finally got the horn to work!), and installed the stock bench seat.
Also finished the underhood wiring, secured everything and installed the hood hinges. I have to wait until the cowl cover gets painted before I can install the hood. Installed the windshield with new trim and seal.
Got the inner door panels painted and installed with all new regulators and window and door handles.
Old 05-14-2017, 10:23 PM   #90
quadzero
quadzero's Avatar
Re: Dream '69
Interior looks like a million bucks.
quadzero is offline   Reply With Quote
Old 05-15-2017, 08:52 AM   #91
lawest
Re: Dream '69
Thanks quadzero. Not bad for a stock interior, some spray paint and a few repop parts if I do say so myself.
Old 06-04-2017, 10:18 PM   #92
lawest
Re: Dream '69
Well, the truck actually ran down the road under it's own power today. The bed is painted but not on the truck yet. I need to replace my steering shaft, or at least the slip coupler. Any recommendations?
Old 06-10-2017, 11:27 PM   #93
lawest
Talking Re: Dream '69
Tinted bedliner on the bottom of the bed floor.
We put the bed together today.
And put it on the truck, it's finally in one piece againhttp://67-72chevytrucks.com/vboard/images/icons/icon10.gif
Old 06-11-2017, 10:12 PM   #94
quadzero
quadzero's Avatar
Re: Dream '69
Amazing work. What product did you use for the bedliner underneath?
Old 06-13-2017, 07:04 AM   #95
lawest
Re: Dream '69
U-pol
Old 07-23-2017, 12:10 PM   #96
lawest
Re: Dream '69
Finally got the decals for the tailgate in and thought I would post some pics with it all together. Still have a few minor details to finish up in the interior and engine compartment, but it is basically done.
Old 07-23-2017, 06:21 PM   #97
rgunlock
rgunlock's Avatar
Re: Dream '69
Wow! You should be proud - looks great!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 07-25-2017, 04:41 PM   #98
lawest
Re: Dream '69
Thanks, I looked at your build thread too, I can't get enough of these 4X4 build projects. There are a lot of them on this site and I have learned a lot from everyone. I Can't wait to see your '59 project start coming together. I have some ideas about my next project as well. I still have the 283/SM465/Rockwell T221 set up I removed from this '69 sitting on the floor. I am thinking about a 65/66 SWB roller to convert to 4wd, or even starting with a long bed and cutting it down. What do you think?
