Closed Thread
Old 02-05-2014, 09:57 PM   #76
pimpston65
pimpston65's Avatar
Re: What did you do to your truck today part II.
yup,$215 for two yards. plus $130 for the other vinyl,burlap,jute, hog rings, hog ring pylers and cardboard for the sunvisors. not to mention the $400 for the singer commercial table machine. plus i didnt get the 6" foam yet $75 plus $35 for the 2" foam for the back, but i got a quote from a few people and they wanted $1000 plus i buy material are you kidding me, i'll do it myself i can sew very well...
pimpston65 is offline
Old 02-06-2014, 01:45 AM   #77
66LSx
66LSx's Avatar
Test fit doug thorleys and mounted Drive-By-Wire pedal with 1966 linkage rod and using the existing pedal...
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline
Old 02-06-2014, 02:50 PM   #78
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
In the process of building a sidestep tool box for mine!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 02-06-2014, 03:49 PM   #79
pimpston65
pimpston65's Avatar
taking my $120 CL harrison rad to get worked on, got a few boo boo's
Old 02-06-2014, 07:48 PM   #80
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
In process of making a sidestep tool box fer mine! Still needs paint and I am gonna add some metal strips.
Old 02-06-2014, 08:25 PM   #81
pimpston65
pimpston65's Avatar
what kinda wood you using for the tool box? i got a question, does there exist a right side stepside cutout fender for a 65C10 for dual spares?
Old 02-06-2014, 08:28 PM   #82
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I have no idea....I think I am using pine and oak and whatever. lol. Just spare wood I had layin around. No, you would have to fabricate a fender to have a rights side spare.
Old 02-07-2014, 02:31 AM   #83
Slow Build
Slow Build's Avatar
Just a suggestion. What about mounting something like this on the step instead. It would look a lot better and probably hold up better too. The can in the first 2 pics might be useable mounted (might hit lid on bed rail though) and the third could be used as a removable tool box. I think these would go along with the theme of your truck better than a wood box. Just my 2 cents worth.
Amazon.com: Rampage 86622 Trail Can Storage Box:... Amazon.com: Rampage 86622 Trail Can Storage Box:...
http://www.4wheelparts.com/Exterior-...FYdgfgodRD8A3A
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 02-07-2014, 03:42 AM   #84
Rich 5150 69
Rich 5150 69's Avatar
You just got to find one....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 02-07-2014, 03:48 AM   #85
pimpston65
pimpston65's Avatar
wow, now thats a thing of beauty. ima search hig and low now for one. i was thinking to take the spare cutout section and graph it to the pass. side fender. is that your truck? guess i gotta get the spare tire holder as well, thks for the pic
Old 02-07-2014, 12:09 PM   #86
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Amazon.com: Rampage 86622 Trail Can Storage Box: Automotive
Thanks for the idea slow build! I like the cans. Bit spendy fer me at this time...so the box will do fer now. I'll look much better after I paint it and add my touches to it. Thanks.
I have a longbed spare tire fender for the driver's side.....I don't know if you could use it to cut the cutout out or whatever...
Old 02-07-2014, 12:13 PM   #87
pimpston65
pimpston65's Avatar
whats ur price? i'll give a go
Old 02-07-2014, 12:17 PM   #88
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Sent a PM.
Old 02-07-2014, 12:47 PM   #89
pimpston65
pimpston65's Avatar
found some correct"ish" glovebox and stricker plate screws the get tight on the oem J-nut so works for me
Old 02-07-2014, 12:51 PM   #90
pimpston65
pimpston65's Avatar
now gotta fancy em up
Old 02-07-2014, 12:56 PM   #91
pimpston65
pimpston65's Avatar
got my new hose clamps now just gotta paint em, and then noticed my 2yr old engine paint needed to be touched up
Old 02-07-2014, 04:54 PM   #92
LVPhotos
LVPhotos's Avatar
Playing in the garage. Porterbuilt Track bar mount tacked in, bar cut and welded to length. Some pie left overs from trimming fenders. The circle is schrader valve for bags. The black outline is stock shock mount for those looking to move to outside frame. Ground down the top of the pumpkin. Oh and installed the longer PB trailing arms.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 02-07-2014, 10:06 PM   #93
gimmy 64
if you do this you need to take pictures and document this for us to see. even if it does not turn out that good. but I hope it does.
gimmy 64 is offline
Old 02-07-2014, 10:23 PM   #94
pimpston65
pimpston65's Avatar
i will put up some pics of my process, i have something going on with this creation everyday. once i get a few days off ina row i will fire up my singer a take a ton o pics
Old 02-08-2014, 11:46 PM   #95
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Did some painting and added some diamond plating on my tool box fer my truck today! Almost got her done!
Old 02-09-2014, 12:08 PM   #96
pimpston65
pimpston65's Avatar
had every nut, bolt , washer and screw black phospated. what hell was i thinking. good thing i got a few books showing where these things go and tons o pics...
Old 02-09-2014, 08:28 PM   #97
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Got my tool box mounted today!
Old 02-10-2014, 01:09 AM   #98
MikeS.
MikeS.'s Avatar
I fired up both the 63 and the 66 and let them run for a half hour.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 02-10-2014, 01:48 AM   #99
NEWFISHER
NEWFISHER's Avatar
I tried to open the doors on mine and start it, but the ice is still too thick to get in, so I watched the icicles grow throughout the day.
GOD BLESS AMERICA!
NEWFISHER is offline
Old 02-10-2014, 11:21 AM   #100
speedy_steve
Bought a few parts and went to work polishing and porting the head.
speedy_steve is offline
Closed Thread
