Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Closed Thread
Old 12-20-2015, 10:08 AM   #76
b454rat
Re: HD relay conversion headlight harness available!
Head lights suck big time on my 99 Tahoe. I've done the relay thing in the past and makes a big difference. I prolly should read the post again, but only a couple sips into first coffee, but this does all 4 lights when the high are on correct? I'm gonna order new lights off evilbay, then want to get these...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
b454rat is offline
Old 12-20-2015, 12:18 PM   #77
gmachinz
Yes...my harnesses do include the 4-HI option. I see about 20% increase in light output with mine as measured with the increase of output voltage in the area of 1-1.5V @ the bulbs themselves.
gmachinz is offline
Old 12-21-2015, 12:08 AM   #78
b454rat
So how much and what's the paypal address? What's the lead time on them?
b454rat is offline
Old 01-19-2016, 01:47 PM   #79
jrsavoie
What happened? Haven't heard from gmachinz in a while.
It's reminding me of another headlight harness vendor.
Hope he's ok.
98 GMC Suburban 2500 6.5 4x4 235,000 mi, FS2500, 96 GMC 6.5 Suburban 1500 4x4 280,000 mi; Amsoil 95 Tahoe 2 door 4x4 6.5 280,000 mi; 91 international 4700 low pro, spicer 6 speed, DTA 360 with 18' van box 500,000 miles plus.1994 chev K3500 crew cab SRW 5 speed 4x4 245,000
jrsavoie is offline
Old 01-20-2016, 11:09 AM   #80
gmachinz
lol-oh no I'm not going anywhere.....I've got a lot going on but I'm pretty much up to date besides a few backordered connectors I've been waiting on directly from Delphi. You're modified/updated headlights have been shipped out-check your inbox for some updates on the kit!
gmachinz is offline
Old 01-20-2016, 01:56 PM   #81
jrsavoie
Good to hear your doing well!!!
jrsavoie is offline
Old 02-01-2016, 10:21 PM   #82
JPsChevy
JPsChevy's Avatar
I'd be interested in a set if you could pm me, I have a few questions.
Opportunity is missed by most because it is dressed in overalls and looks like work.
- Thomas Edison
JPsChevy is offline
Old 02-01-2016, 10:42 PM   #83
gmachinz
PM sent!
gmachinz is offline
Old 02-13-2016, 11:47 AM   #84
papacharger
papacharger's Avatar
I need a 4 hi HD harness for a 90 GMC (composite headlights). What other options are there? Thanx, Jeff
papacharger is offline
Old 02-13-2016, 12:04 PM   #85
gmachinz
Hello-I have plug n play kits with 4-HI for $146 shipped. These plug into your existing heaight connectors on one side and you simply need to mount the relay bank, attach the ground lead and that's it. Includes heat resistant looming (rated @ 275F) and all wiring is j1128 rated for use under hood using GXL crosslink wiring. Relays are rated @ 250,000 switching cycles.
gmachinz is offline
Old 02-13-2016, 12:21 PM   #86
papacharger
What is the difference between that one and the one in the first post ? Why is one cheaper?
Old 02-13-2016, 12:24 PM   #87
gmachinz
The first one is a splice kit using your existing wiring-most people opt to NOT want to cut up their wiring so they easily unplug this kit if they decide can go back to stock-I build both tho
gmachinz is offline
Old 02-13-2016, 12:43 PM   #88
papacharger
I hate to keep bothering you, but, on the splice in kit, if a relay goes bad can I just plug one of the original connectors on to get headlights? You know just to get home.
Old 02-13-2016, 01:08 PM   #89
gmachinz
Well, on the splice kit there is a relay input and output so what I can do is provide a jumper lead to use in such an event. If you use the plug n play kit, you would simply unplug the connectors and swap them.
gmachinz is offline
Old 02-13-2016, 11:10 PM   #90
papacharger
Please PM me, with details how to order the splice in kit with the jumper. Thanx alot for your patience and knowledge.
Old 02-14-2016, 06:25 AM   #91
jrsavoie
I am very happy with my plug and play kit.
The only minor problem was the ground eyelet was 5/16 and I needed a 3/8" eyelet to go to the 3/8-16x1 1/4" Allen screw I use for the battery bolt mod.
I was able to enlarge the hole with a Unibit.
jrsavoie is offline
Old 02-14-2016, 10:21 AM   #92
gmachinz
I'm glad it worked out for ya-I try to build them as people need them when possible!
gmachinz is offline
Old 03-14-2016, 07:01 PM   #93
papacharger
I received my HD 4 Hi harness on Friday (3/11). Installed it on Saturday. All I can say is the quality of materials and workmanship is excellent. It took about 2 hours to install, I like everything hidden. At the same time I installed GE NightHawk bulbs. Everything works like it is supposed to. I would highly recommend both the harness and the bulbs. Very well pleased. Thanx, gmachinz
Old 03-14-2016, 10:49 PM   #94
gmachinz
Hey thank you-if you're happy then I'm happy!
gmachinz is offline
Old 03-15-2016, 01:18 PM   #95
MalibuSSwagon
Whats your cost breakdown for the basic harness, then adding aux relay and delay?
MalibuSSwagon is offline
Old 03-15-2016, 01:37 PM   #96
gmachinz
PM sent!
gmachinz is offline
Old 03-17-2016, 11:36 AM   #97
likaroc13
Rollin' Old Skool
Can you PM me pricing info on your kit(s)? Thanks
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
likaroc13 is offline
Old 03-17-2016, 12:38 PM   #98
gmachinz
PM sent!
gmachinz is offline
Old 03-17-2016, 10:35 PM   #99
likaroc13
Rollin' Old Skool
PM sent!
Looks like it didn't come through.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-18-2016, 11:16 AM   #100
gmachinz
PM re-sent!
gmachinz is offline
Closed Thread
