Old 05-27-2014, 12:54 PM   #76
doo142
doo142's Avatar
Re: What did you do to your Blazer/Jimmy today?
Got a little anxious to get my 70 frame off done so instead of rushing I bought a 2 wd ,so I can cruise again. Love it , it has been a blast!!
doo142 is offline   Reply With Quote
Old 05-30-2014, 09:18 PM   #77
iambigfattony
Tested out soft top in the rain. Surprisingly dry!!
iambigfattony is offline   Reply With Quote
Old 05-30-2014, 11:59 PM   #78
amashal
amashal's Avatar
New wheel cylinders, shoes, and drums. Had to stop working on it early to go to a graduation. Hope to get it bled and put back together tomorrow.
amashal is offline   Reply With Quote
Old 05-31-2014, 07:14 PM   #79
asolde
asolde's Avatar
Been working on my foor. Installed the rear carpet and seat/seat belts. I sill need to put in the front floor and seats.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 05-31-2014, 07:22 PM   #80
Dale99
Which carpet is that? Please post pictures of the front when its done. I'm debating on rubber/carpet.
Dale99 is offline   Reply With Quote
Old 05-31-2014, 07:55 PM   #81
amashal
amashal's Avatar
Got the rear brakes done. Also got up in the attic and built my one man top removal contraption.
Old 05-31-2014, 09:02 PM   #82
asolde
asolde's Avatar
Here you go http://www.accmats.com
Old 06-01-2014, 06:37 AM   #83
grillzy
Asolde- interior looks great!
grillzy is offline   Reply With Quote
Old 06-02-2014, 09:27 AM   #84
Wasted Income
Boosted Member
Wasted Income's Avatar
I like it!
I pulled my top off on Friday night with my top removal device
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-02-2014, 01:25 PM   #85
Dale99
Cheater
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Old 06-03-2014, 09:22 AM   #86
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Dropped off a pile of parts to be phosphate coated (Parkerized) just like GM did. Hood hinges, hood latches, door striker plates, 72 front hooks, bags of bolts/screws, tie rod bracket, etc. For these parts it's an authentic redo that's cheaper and more durable than powdercoating or painting. $180 for the all shown to be cleaned, bead blasted, and Parkerized at a local facility that does 15k gun barrels monthly for the Ruger Co.
Old 06-03-2014, 11:30 AM   #87
jaros44sr
jaros44sr's Avatar
Great idea, post up pics when done. I want to have my m/c cover done....heck, maybe even my non-extreme bend tow hooks
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 06-03-2014, 11:52 AM   #88
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Will do! For now, here are pics of a used door striker I had re-done in NM (pardon the finger prints - the finish is actually nice and uniform). I was so pleased I actually re-parkerized a set of NOS strikers that had shelf ware for use on my K20 resto. You wouldn't believe how good the hood hinges and bolts look - honestly, they appear brand new and the hinges work beautifully cleared of all that dry, old lithium grease.
For brackets and bolts that get wrenched on it's the best way to go - good to do pulleys also.
Old 06-03-2014, 12:56 PM   #89
jaros44sr
jaros44sr's Avatar
Man they look great! Sounds like it would hold up well against wear and tear....thanks for the info.
SAFETY FIRST
AS usual, off topic
Jim
Old 06-03-2014, 08:32 PM   #90
freakshow108
freakshow108's Avatar
Took it apart and cut some rest out!
freakshow108 is offline   Reply With Quote
Old 06-03-2014, 08:38 PM   #91
freakshow108
Another
Old 06-03-2014, 08:41 PM   #92
freakshow108
One more
Old 06-04-2014, 07:54 PM   #93
asolde
asolde's Avatar
I put in my heat/sound damper and laid the front carpet in place. I still have a lot to do with it like find all the bolt holes, shifter boot, seat belts, door sills etc. It will take me a whole day or more to get everything fitted in there. Oh and I did my roof rail seals to.
Old 06-04-2014, 08:02 PM   #94
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Very nice job Alex! I just cut my rear carpet off at the front chrome trim strip...
Old 06-04-2014, 08:13 PM   #95
asolde
asolde's Avatar
To tell you the truth I did not know how it came from the factory. So I thought it would look better with the carpet folded over the edge and glued down to the vertical wall. Then I cut it along the floor line.
Old 06-05-2014, 09:02 AM   #96
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
This is a much better looking idea. What brand carpet kit is that?
Tom Vogel is offline   Reply With Quote
Old 06-05-2014, 10:20 AM   #97
warrpath4x4
got my mirrors and ignition stuff lastnight so today after work ill put all that together and change the oil.
1972 K5
warrpath4x4 is offline   Reply With Quote
Old 06-05-2014, 12:28 PM   #98
fun in dirt
fun in dirt's Avatar
Dug out the old umbrella holder to slide in the receiver & went fishin!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 06-05-2014, 12:29 PM   #99
DeadheadNM
Carpe manana
DeadheadNM's Avatar
GM left that vertical part of the floor uncovered - done right like yours it does look better IMO.
Old 06-05-2014, 12:55 PM   #100
rwhite692
Finally finished up my weld-on beadlocks (5) and mounted my 35s
My 72 Blazer Project:
http://www.67-72chevytrucks.com/vboa...d.php?t=621724
rwhite692 is offline   Reply With Quote
