Old 11-28-2014, 10:33 PM   #76
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Temp Battery Tray
The previous owner made a rather nifty temporary battery tray, I wonder how many years he drove with this one around.
The bottom plate was 1/4 inch nice and sturdy like, but now original so it must go
Gregski is offline   Reply With Quote
Old 11-28-2014, 10:38 PM   #77
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - New(er) Battery Tray
so it was off to Pick N Pull for a new(er) used battery tray - $12 bucks I think I paid for this one, she aint perfect but she will do
not sure if all you all got a Pick N Pull in your neck of the woods, so I'll tell you what it is, it's like a Walmart franchise like junkyard where they let you pull your own parts, they pretty much scrap all the cars for metal, so the parts prices are very reasonable
and yes we can still find some of our trucks in those yards
Old 11-28-2014, 10:45 PM   #78
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Inner Fender
now as baby Godzillas grow and become teenagers they get hungrier, so they expand their battery tray diet to other parts, they love inner fenders
now since mine was missing a large chunk I was able to remove it with the front wheel still on, not sure if you might could as well, fer sure I would not mount a new shinny one using this method, but since my driveway has a significant slope and the battery was out of the truck, I did not wanna prop it up with a jack and get me one of 'em Darwin awards
Old 11-28-2014, 10:46 PM   #79
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I guess this website uploads these pictures any which one is up !!!
Old 11-28-2014, 10:53 PM   #80
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Poor Front Fender
here's what accumulates in our front fender corners and why they rot away, shame really, poor design if you ask me, what were you thinking GM?
Old 11-28-2014, 10:57 PM   #81
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - New (used) Front Fender
The Greg was pretty busy
So I went back to the junkyard and pulled an inner fender - $15 bucks I think, now watch I'll probably spend twice that on materials to strip it, clean it, prime it, and paint it, LOL
Question for you all: Did GM undercoat these inner fenders at the factory, or is that just 40 years of dirt and grime stuck to their bellies?
Old 11-28-2014, 11:03 PM   #82
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Prepping the Inner Front Fender
so I used the Aircraft paint stripper on the top side and it didn't do much, so then I went to the Muriatic acid and it showed better results, but when it came down to it, I still had to use a wire wheel on my small grinder to get all the rust off
man this thing flush rusts super quick, so its hose it off, then dry if off, then Acetone it and shoot it with that clear Rust Fix rust converter thing, that brand sucks when it comes out, it shoots a small narrow strip and does not cover well at all, see how it turned out like a zebra or a tiger, yet it all looked nice and wet when I sprayed it, but it comes out clear so its difficult to see what you sprayed
Old 11-28-2014, 11:04 PM   #83
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Jack Usage
in case you all were wonderin' how to use that bottle jack ~ here you go
Old 11-28-2014, 11:13 PM   #84
Gregski
Post Whore
Gregski's Avatar
man lots of work, this is
cleaned the belly of that inner fender and tried a different rust converter primer this time, cheaper too, this one is by RUST-OLEUM, love the way it covers and sprays, really good coverage, also since it's not clear you actually know what you sprayed
I am gonna use RUST-OLEUM undercoating for the belly, which says you may or may not use a primer first, but I decided to use one anyway
Old 12-02-2014, 08:54 PM   #85
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Holley Carburetor
just scored this 600 CFM Holley 4160 four barrel electric choke refurbished aluminum Carburetor with vacuum secondaries on eBay for $190 shipped, should go nicely with that Weiand intake
Old 12-02-2014, 10:06 PM   #86
rusty76
rusty76's Avatar
Re: Restoring Rusty
Cool work. Glad to see you keeping at it.!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-02-2014, 11:30 PM   #87
79azc10
Re: Restoring Rusty
Truck is looking good
79azc10 is offline   Reply With Quote
Old 12-04-2014, 11:49 PM   #88
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thank you
Old 12-04-2014, 11:51 PM   #89
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the rain let up so I decided to go back at it, I resprayed that "tiger stripe" inner fender with the Rust-Oleum primer which is meant to shoot over rust, it has better coverage than that Kryolan clear stuff I was using
if all goes well tomorrow I will shoot the undercoating
Old 12-05-2014, 12:04 AM   #90
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - A.I.R. Delete
been planning on removing the Air Injection Reactor System and finally got around to it
the first pipe plug broke off - go figure, then a second one, although I did soak em in BP Blaster
one as always needed a bit of gentle persuasion - vice grips style
Old 12-05-2014, 12:05 AM   #91
pontgta
pontgta's Avatar
Re: Restoring Rusty
I used to use the rutoleum but another member mentioned this..... And like the fact of no primer needed..
VHT EPOXY
Found some at advance
By the way AWESOME progress
pontgta is offline   Reply With Quote
Old 12-05-2014, 12:30 AM   #92
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
VHT EPOXY
thanks I will have to check it out, sounds like POR15 in aerosol
Old 12-05-2014, 12:39 AM   #93
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then it was off to Home Depot (well two of em since the first only had 5 of the fittings)
thanks to the good folks on this forum sharing their know how I was able to determine I needed the Brass Pipe LFA-737 plugs
can you see my plug in the red 1/4 inch (8mm) slot I screwed in to the store to show you guys what we need
Old 12-05-2014, 10:39 AM   #94
motornut
78K & 79C Jimmys
motornut's Avatar
yup ours do that up here,fall leaves/debris and then it holds the winter salt....
I opened up the drain holes in the 4X4s fender bottom,stuff flushes out easier.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-05-2014, 11:48 AM   #95
Lokin4AReason
Lokin4AReason's Avatar
Re: Restoring Rusty
nice progress .... keep up the good work =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-05-2014, 10:16 PM   #96
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Plugs Are In
it was too dark last night to get more than one plug in so I came home from work today and got the other seven screwed in, note the aligned bolt heads, Concourse Ready! JK
$20 bucks I paid for these and now my car looks like it has 8 gold teeth, not a big fan, if I was to stick with manifolds I would pick up some without em holes at a swap meet, but I'm getting headers come March
Old 12-05-2014, 10:23 PM   #97
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Painting the Inner Fender
finally got the fender in the paint booth today ~ LOL, bet you didn't know I was gonna color match that baby, I know it was black from the factory, but I like more contrast in the engine bay, the engine don't stand out if everything around it is also black, just my preference that's all
got some single stage color match paint, (OMNI brand I think it's PPGs cheaper cousin) will most likely need a second spray can too get the color to brighten up cause of the deep brownish red primer under it, note the lame color comparison of the wet fender to the dry glove box on the ground (and in different light) but hey I was impatient to see the results
Old 12-05-2014, 10:32 PM   #98
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Blower Unit
figured if I don't get to the blower unit now I will never be able to reach the bottom bolt after I put the shinny new(er) inner fender back on, so that baby had to come off for a wash and a respray
trying to figure out if there is s gasket between the fire wall and that blower box cause there aint much left of mine if there was one
Old 12-05-2014, 10:39 PM   #99
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Cross Eyed Rusty
while I was literally watching the paint dry I decided to see if I could figure out why Rusty is cross eyed, well the only plastic part in the headlight assembly is what broke, that white little piece that holds the adjusting screw to the radiator support, go figure, darn plastic!
some turn signal bulbs are out too, so making a short list for AutoZone for tomorrow, lol
Side Note: very impressed with the heavy duty quality headlight chrome bezels, love working on this truck, easy to take in and out too
Old 12-05-2014, 11:42 PM   #100
KrazyRay
KrazyRay's Avatar
Re: Restoring Rusty
Your truck is looking good! Is that paint from Jerry's Paint? I used their matching paint on my 87 GMC and was very happy with it.
KrazyRay is offline   Reply With Quote
