Old 09-28-2020, 03:24 PM   #76
1981_c10
1981_c10's Avatar
Re: 1981_c10 Step-Side
Originally Posted by LT7A View Post
Lots of progress, looks good. You mentioned a Subaru silver and I actually thought that it's too bad there wasn't a stock silver you could use instead of an offshore color. That's how rare, they are, I don't recall ever seeing a silver one. I was also thinking today that I've had two vehicles repainted in a a color different than original. If I was doing them over, I would paint them the original color. Also, for what it's worth, I think stripes and stuff like that can be cool if done well, but I would recommend doing them in vinyl. Probably something you can do yourself and save on the painting costs. With mine, I figure when I want to go back to a stock looking rig, all I have to do is warm it up with a hair dryer and peel away.
To be honest, i just have found a stock silver i like. I want one with more metallic than the GM colors offer. Good thoughts on the stripes. I will talk to my painter and get his thoughts. It is a friend of mine so it doesnt impact the cost too much.
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 09-28-2020, 03:25 PM   #77
1981_c10
1981_c10's Avatar
Has anyone used POR15 kits to coat the frame? Since my frame is open right now i was going to wire wheel and brush on. I have no experience with the product but the current route i am leaning toward.
Is you have used it to you recommend gloss or semi to closest match stock? I am leaning semi.
Builds:
1981 C10
Old 09-29-2020, 11:38 AM   #78
daddyjeep
daddyjeep's Avatar
I have used it a couple times. Make sure that you use their prep and follow the directions, especially the part about wearing gloves. This crap will not come off your skin for a couple weeks. I used in on my Jeep frame and didn't use their prep and it is peeling off. My frame was mostly bare metal and it doesn't bond to that without their prep. My truck frame was just wire wheeled so it did have some light surface rust and it is working much better. Remember that this stuff needs topcoated so the gloss and color of that is up to you. I have found that gloss is easier to keep clean.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-29-2020, 11:45 AM   #79
1981_c10
1981_c10's Avatar
Thanks for the insight!
Builds:
1981 C10
Old 09-30-2020, 12:37 AM   #80
LT7A
Chances are that even with your buddy, you will save some pretty good money if you someday decide you don't want the stripes because you won't have to repaint anything.
I'm a big fan of Rustoleum since it is paint and go. Touch up and go. Although I think you can leave POR15 un-topcoated on your frame, if I understand correctly, it is the UV that affects it and on your frame it should be indirect, any UV that gets to it. That said, I never have used it so others who have left it uncoated could tell you more. It's beyond my budget for $ and time spent, given the location.
Old 09-30-2020, 06:27 AM   #81
MY buddy did his 70 with POR and it is holding up good. IT is very touchy and can be a mess. Wear Gloves and a good respirator. I have used on several trucks what I like better is Eastwood's Rust Encapsulater. It seems to do as well as the POR (to me), is easier, less toxic to apply andcan easily be top coated if you want.
As mentioned in my youth up north I have also used Rustoleium and it did OK also. Of the 3, nowadays, I like the Eastwood.
Old 09-30-2020, 11:42 AM   #82
1981_c10
1981_c10's Avatar
Thanks for all the insight. I think I will look into the eastwood products! I am picking up a power washer from a friend today to start cleaning the frame this weekend.
Builds:
1981 C10
Old 09-30-2020, 12:07 PM   #83
Go to the dollar store and get some cheap oven cleaner (3/4 cans) to spray on before you pressure wash it. It really helps clean up the grease and grime.
Old 09-30-2020, 02:44 PM   #84
1981_c10
1981_c10's Avatar
Great idea, i have 2 cans but could probably use one more.
I took out the after-market radio today...the big cut out in the dash is a bummer. I am wanting to go back to a stock looking radio. Does anyone have any experience in repairing the oversized whole the installers cut. (i am not a welder...)
Builds:
1981 C10
Old 10-14-2020, 10:57 AM   #85
1981_c10
1981_c10's Avatar
Small update, i got the rest of the gauges, ac controls etc out of the truck. Only thing in the cab now is the steering column. I had to replace my column a few years ago after some dummies tried to steal my truck and broke my column to pieces. Well, i just noticed the plastic part that signals what gear is broke, so i guess i will have to pull the column again to replace that.
I also have been scrapping the glue from the windshield channel. I will try to get some pics.
Builds:
1981 C10
Old 10-28-2020, 08:43 PM   #86
TKCR
TKCR's Avatar
Just read them your build thread. I really like what you have done so far. And looking at your interior, your door panels, it’s definitely CarmineRed.
Also for the radio repair, you can get a radio repair patch in. That way you can go back to a stock radio. Check out the parts section, they are on there every now & then. I see them on eBay also. Looking forward to seeing more of the work your doing on the stepside.
Old 10-30-2020, 12:27 PM   #87
1981_c10
1981_c10's Avatar
Small update, been sanding out the windshield adhesive and going to be prepping the interior for paint soon. Also been working through interior items and new parts needed.
Taking to the painter 11/17!!
Builds:
1981 C10
Old 11-18-2020, 05:22 PM   #88
1981_c10
1981_c10's Avatar
Update, been gathering parts. Got some seat belts from a donor truck. some are good some are bad. Still looking for one should belt and two female belts in carmine red.
Also picked up two carmine red headliners and all the trim parts. Mine didnt come with a headliner so will be adding.
Builds:
1981 C10
Old 11-18-2020, 07:29 PM   #89
TKCR
TKCR's Avatar
Show us your goodies you’ve been gathering up.
Old 11-19-2020, 09:42 AM   #90
1981_c10
1981_c10's Avatar
here is the first headliner parts and leather part for behind the seat. I need to take pictures of what i got yesterday. I the headliner parts i got yesterday are in a bit better shape and true carmine red.
Builds:
1981 C10
Old 11-19-2020, 02:15 PM   #91
TKCR
TKCR's Avatar
That leather piece for behind the seat, that’s cool!
Old 11-19-2020, 04:21 PM   #92
1981_c10
1981_c10's Avatar
I am excited for it. The guy has a brown one too if anyone needs it. I am happy to go pick it up and ship.
Builds:
1981 C10
Old 11-19-2020, 04:24 PM   #93
1981_c10
1981_c10's Avatar
here are the plastic parts from the second headliner i bought. few spots i will have to do repair, but over all better condition than the darker ones. Excited to have these in the truck. I need to order some paint match for the 81-83 carmine red. Saw USA1 sells some. Anyone used them before for interior paints?
Builds:
1981 C10
Old 11-19-2020, 06:49 PM   #94
TKCR
TKCR's Avatar
That’s the dye I use, from USA1. Been using it for several years now. Make sure you get some SEM Prep and Adhesive Promoter. Here’s some Carmine Parts I’d have done in the past. But these are 79-80 CarmineRed.
Old 11-20-2020, 09:26 AM   #95
1981_c10
1981_c10's Avatar
Those look great! I will be sure to get the prep and promoter! thanks for the tip!
Builds:
1981 C10
Old 11-20-2020, 09:42 AM   #96
TKCR
TKCR's Avatar
Your Welcome
Old 12-28-2020, 09:23 AM   #97
1981_c10
1981_c10's Avatar
Good news and bad news...
Bad: painter got behind so my truck didnt get touched in Dec as planned.
Good: bed is going to him this friday then the rest of the truck Jan 12th!
I also was able to get the first coat of the frame paint on. See the pics and what i used. Over all really happy with the product so far especially coming from a can. Bought the stuff from Summit.
Builds:
1981 C10
Old 12-28-2020, 09:27 AM   #98
1981_c10
1981_c10's Avatar
Your Welcome
TKCR,
I finally got to open my seatbelts for christmas! They turned out awesome! I appreciate your work and time making them look great. For sure going to be one of those subtle touches that makes the truck look GREAT!
Builds:
1981 C10
Old 12-28-2020, 10:22 AM   #99
TKCR
TKCR's Avatar
TKCR,
Happy to hear you like them! Hope you had a Merry Christmas.
Your frame turned out awesome.
Old 12-30-2020, 10:26 AM   #100
calvin78612
calvin78612's Avatar
I might be interested in the brown one if the guy still has it.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
