Old 02-15-2016, 03:09 PM   #76
whitels1
whitels1's Avatar
Re: 79 K20 Custom Deluxe - Goldy LS1
Took a trip to the wrecking yard, couldn't find a battery tray but did find a cooling fan from an S10, not sure the year, but it was just laying in the engine bay and I noticed the longer shaft on the clutch, which got the wheels spinning in my head so I bought it. Before I could even test fit it, I had to cut my crossmember out, I'm thinking of just moving it right in front of the steering box bolts, I think with the boxing and crossmember being so close there should still be enough strength. I will need to replace the fan clutch with new since this one is leaking, so hopefully I can find a part number on it, if I do I will post it. I also reworked the 84 K10 battery tray to work. No wiring was done due to me not being able to focus on one thing for more than 10 seconds....
Battery tray, ugly but it should hold.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 02-29-2016, 06:24 PM   #77
whitels1
whitels1's Avatar
It's been slow going with the wiring, I have been on it for over a week. It's not glamorous but overall not to bad, just time consuming. I am happy I went with a small fuse box and a few relays. It's mostly done at this point, other than grounding and testing everything in the cab, running some ignition wires, and a little more loom work. It's not as pretty as some I have seen on the site but as long as it works I'm happy!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-03-2016, 10:31 AM   #78
mattcrp1
mattcrp1's Avatar
Looking good, I like the video's. The pcm mounted on the engine should be ok. I do a lot of work on Ford diesels and the injector driver module is mounted on the top by the turbo. Did I miss it or are you going to hook the evap up this truck like you did on the k5? I am doing a similar swap on a swb truck and getting ready to finish up the evap for emission reasons.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-03-2016, 07:51 PM   #79
Jake Wade
Jake Wade's Avatar
Did you intend for the front axle to be further forward? Curious to know the benefits/advantages.
Jake Wade is offline   Reply With Quote
Old 03-04-2016, 10:59 AM   #80
whitels1
whitels1's Avatar
Thanks for the info on the pcm. I have all of the stuff, but I'm not that far yet, still trying to figure out which fuel tank set up I will run.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-04-2016, 11:06 AM   #81
whitels1
whitels1's Avatar
Yes with the 52" springs the axle is 2"ish forward, it helps for running a larger tire on a smaller lift so that it doesn't rub on the cab while articulating etc and it will help with approach/departure angle while wheeling.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-13-2016, 08:11 PM   #82
Jake Wade
Jake Wade's Avatar
Where you at White? Taking a break? I enjoy watching your videos/progress, much better than most of what you see on the Velocity channel.
Old 03-16-2016, 11:15 PM   #83
whitels1
whitels1's Avatar
Thanks, I appreciate it! Sort of taking a break, just haven't been hitting it as hard, since I will probably be moving soon. Don't want to get into a big project, or at least tear something more apart than it already is. Trying to keep the truck together enough so I can roll it on a trailer and then off with most everything in tact.
Here is your video Jake, I did manage to make it to the wrecking yard and do some wire looming.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-18-2016, 02:31 AM   #84
MTCK
MTCK's Avatar
Good update as always. Headed across town or further?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-18-2016, 10:30 AM   #85
whitels1
whitels1's Avatar
Thanks Marcus, were are just moving a few miles away.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 03-18-2016, 12:54 PM   #86
daddyjeep
daddyjeep's Avatar
That should make for a real nice approach angle.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-19-2016, 09:21 PM   #87
Jake Wade
Jake Wade's Avatar
Looking good! I know your new place will have a work area or you would not consider it. Is it an improvement over what you have now? Not that your current place is bad but, you know, one never has enough room.
Digging the junkyard visits/scores.
Old 04-14-2016, 10:05 AM   #88
COS399
COS399's Avatar
Dave - Glad you saved another square.
Your DIY/on the cheap is an inspiration to people who don't have or want to spend a lot of money to have a dependable DD or toy. Being a Foster Parent and giving up your nice Camaro is another example of your inspiration to us. Keep up the awesome work. Can't wait to see the new Pad. Hopefully no HOA.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 04-27-2016, 11:45 PM   #89
whitels1
whitels1's Avatar
I'm thinking so too, I can't wait to try it!
Thanks! and yes it has more garage room and RV / Square body parking. I'm in heaven
Thanks man! I want to save more squares, the other day I saw a 1 ton square dump truck in good shape and was almost tempted but I have to finish my two projects before starting another. I try to keep it cheap, it keeps the wife off my back and If I can make/do it for less why not. Still have an HOA, but hopefully they take it easy on me and the old squares!
Update video as well, hopefully I can get back to working on this sucker soon!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 04-28-2016, 12:29 AM   #90
COS399
COS399's Avatar
Thanks for the video update. Bigger garage and a fenced/gated work area on the side.
Old 04-28-2016, 02:06 AM   #91
MTCK
MTCK's Avatar
Congrats on the new digs! It looks nice there. That extra space will be awesome.
-Marcus
Project Plow Truck
Old 04-28-2016, 08:37 AM   #92
Greenlee
Greenlee's Avatar
Looking good! Nice garage / work area!!! I like how you don't have real grass to mow there.
Greenlee is offline   Reply With Quote
Old 04-30-2016, 11:29 AM   #93
whitels1
whitels1's Avatar
Ya man, it's gonna work out! I wanted to get out and pull that engine back out and get it into the garage to finish it up, but its been raining all morning. Maybe it will let up later today.
Thanks Marcus, I can't wait to tear back into a project!
Thanks buddy! I don't have a green thumb or a mower so rocks it is!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-17-2016, 05:45 PM   #94
whitels1
whitels1's Avatar
Some more progress, I'm down to frame now which means more rivets = more fun
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-17-2016, 09:20 PM   #95
Jake Wade
Jake Wade's Avatar
Good work!
Old 05-17-2016, 09:54 PM   #96
daddyjeep
daddyjeep's Avatar
Rivets...good times.
04 1500 crew cab
Old 05-21-2016, 12:38 PM   #97
whitels1
whitels1's Avatar
Good work!
Thanks!
Always, they never let you down!
More progress
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-26-2016, 02:02 PM   #98
whitels1
whitels1's Avatar
More work, spent a productive Saturday, working on the LS1 for a few, popped the heads on, moved onto the frame, removed some rivets and got the shackle flip and 56" springs on.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 05-26-2016, 02:24 PM   #99
MTCK
MTCK's Avatar
Man you are straight cranking this thing out. New digs look great.
-Marcus
Project Plow Truck
Old 08-08-2016, 02:57 PM   #100
whitels1
whitels1's Avatar
Thanks Marcus, it's been a while since I have updated this build and I have been thinking a lot about the direction of this truck. After doing some wheelin with the K10 it has made me change my mind on the whole turbo400 doubler situation, since the SM465 without a doubler still has a lower crawl ratio. After some heavy thought I have decided to turn this into my tow / daily rig and put more work into making the K10 a more capable trail rig. So as of now that's the plan, which may change at any moment especially when I have too much time to think! I still have plenty of work to do with the K20 so I hope I haven't lost anyone with the change up. Let's get back to work enjoy the video.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
