12-21-2015, 08:05 AM | #76 |
Re: 1972 K5 CST Highlander Blazer Patina Texas
that's all the ol' girl needs, just a little TLC. What's the interior look like
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-21-2015, 09:24 AM | #77 |
Blazer still has all the original interior. Front highlander seat covers are a little tired, have new ones on order. Back seat is nice, all paint on inside nice, dash pad etc are good.
12-21-2015, 10:32 AM | #78 |
I'm trying....
Love every truck in this thread. That K10 SWB Super is the business!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
12-21-2015, 01:05 PM | #79 |
Your blazer has almost all the same options as mine. Check out my profile to see what it looks like with the same paint.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
12-27-2015, 12:52 AM | #80 |
Love this blazer! I need a blazer...
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
12-27-2015, 05:33 PM | #81 |
Thanks IronCanine, your blazer is very nice.
Thanks Blazerowner, I will check it out. Thanks tommys72, yes you need one, sold my first one and wished I hadn't and thought my young kids would like this one. |
12-27-2015, 05:52 PM | #82 |
Got to mess with blazer just a little this weekend. I am having a little bit of a issue of popping thru the exhaust. It's kinda sparatic. It will not do it idling, but it seems after u drive around a little bit it will pop thru the exhaust sparaticly. So, I have changed the points to petronix, new cap, new rotor, new cool, new spark plugs. Put a rebuilt quadrajet on it, old one looks like someone had rebuilt it a few times. Put new base plate carb gasket on, new vacuum lines on and new rubber caps for lines no used. Still popping. Old
Carb front barrels were black. Going to go ahead and put new spark plug wires on this week and crawl under it and check for exhaust leak. Manifolds seem good, but it sounds like i here a popping noise at mufflers. Put new fuel filter, may put new fuel Pump on even though I don't think that's it. |
01-01-2016, 06:55 PM | #83 |
What was the easiest way you used to get the tint off? I have 2 layers on my blazer and will be removing it all.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 Last edited by Ridnhi; 01-01-2016 at 07:00 PM. |
01-01-2016, 10:31 PM | #84 |
I didn't find a easy way to get tint off. I just plan sucked. I bought a cheap Walmart clothes steamer, heated tint up and it peeled off. Then it left me the glue residue. I tried the window tint glue remover at auto store. Didn't work well. Used goo gone, nothing. So I just used razor blades and 409 and got all the glue off and cleaned. I will try to post some pics of it tomorrow with tint off. It's way cleaner and better.
Second note, put new fuel pump on today and it pretty much almost cleared up my popping issue. I just need to drive it and get it timed in correctly and make some final adjustments. Actually got to drive it around today. |
01-01-2016, 10:40 PM | #85 |
I've used,these on 25 year,old stripes,and decals. Used adhesive remover on the real stubborn spots.
3M Stripe Off Wheel 07498, 3/8" Mandrel,... One more,idea Bodywork primo and waxed? Now you need to pull off that faded, bubbled window tint. The side windows are easy--just get out a single-edge razor blade and scrape them clean. Not so the backlite. The silk-screened defroster grid is way too easy to damage. You might try using the hair dryer trick on it, but this polyester (not vinyl) film is probably too brittle to peel. Here's a technique we learned from a local trim shop. Start by slitting open a large plastic trash bag into a single large panel--any color is fine. Spray a little water on the outside of the back window glass and use it to temporarily stick the bag to the window. Use your single-edge blade to cut the bag approximately 1 in. smaller than the glass. Add a couple of spoonfuls of household ammonia to your water sprayer and spray it on the tinting film. (The ammonia will stink--do this outdoors with the car doors open.) Use this to stick the bag to the film. If needed, add some more spray between the bag and the film to keep things wet and sticking. In about 20 minutes, the adhesive will have softened, and you should be able to peel off the tint more easily. Don't scrape, not even with your credit card. Remove the remaining adhesive with a very soft cloth and more ammonia or Goo Gone. If you must rub the glass to lift off old adhesive, rub along the length of the heater grid conductors, not across them. |
01-02-2016, 06:26 PM | #86 |
01-02-2016, 06:27 PM | #87 |
Pic with window tint off.
01-02-2016, 07:17 PM | #88 |
Is that snow I see in the shadows by the shop? Makes me glad I don't live in the warm sunny south. Oh, thats looks much better with the tint gone by the way.
02-11-2016, 10:47 PM | #89 |
Well it's been slow progress. I found some nice nos mirrors that I need to put on. Hopefully I will be posting some more pics this weekend.
02-21-2016, 09:46 PM | #90 |
02-21-2016, 09:48 PM | #91 |
02-21-2016, 10:00 PM | #92 |
Looks awesome!!
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
02-21-2016, 10:11 PM | #93 |
Well I been getting things done that didn't need to be done. I bought another set of factory steel wheels from Kevin and blasted them and painted them. I got another set of tires for a steal of a price, that's the only reason I bought them. But I did find a nice set of supposedly nos sport mirrors that are really nice that don't need to go on this rig but I bought them right so I guess I will put them on and Maddox hooked me up with some original bumper guards that are nice that I need to install. So maybe I can get those installed and get the nicer set of wood grain molding put on and hopefully my seat covers will be done anytime so I can get the new carpet installed.
02-21-2016, 10:13 PM | #94 |
thanks sambrutay I got my little 63 out and drove it this weekend since it was so nice here.
02-21-2016, 10:38 PM | #95 |
Jason that looks nice turned out super what size tires did you go with
I aint nobody DORK 1972 Cheyenne super k10 swb 350 4speed posi hooks 1934 ford 3 window blown 355 1969 Camaro hugger orange hounds tooth |
02-21-2016, 10:47 PM | #96 |
33x10.50 15 both sets. The other set in previous pics were 33x10.50x15 bfg all terrians on the first set of rims I got from you and I did the same size tire again on second set. Debating if I should put these on the green 72 super swb k10.
02-21-2016, 10:50 PM | #97 |
looks tasty , im going to have to pick up a set
02-22-2016, 08:23 PM | #98 |
I'm diggin those tires!
02-25-2016, 10:21 PM | #99 |
Nice Blazer! It's great to get one that is clean and original, along with the entire ownership history and paperwork too!!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
03-03-2016, 10:17 PM | #100 |
Ls or carb 350?
