Old 11-10-2022, 01:03 PM   #76
harrij4
Re: Amp Research Powerstep
OK, as promised I've compiled a very detailed guide for bracket fabrication and installation of the brackets and steps. It has lots of pictures and a full set of prints, but that unfortunately makes it a huge document (96MB). So, I've hosted it on my personal Google Drive, but made it publicly available via this link:
Bracket Fabrication and Install Guide for Amp Research Powersteps (1st Gen K5)
I'll also attach just the prints to a later post here.
Hopefully this helps someone out there!
harrij4 is offline   Reply With Quote
Old 11-10-2022, 01:10 PM   #77
harrij4
Posting PDFs of the prints. Here are the core components:
Old 11-10-2022, 01:11 PM   #78
harrij4
Posting PDFs of the prints. Here are the weldments:
File Type: pdf K5BlazerPowersteps_BasePlate Weldment.pdf (103.8 KB, 102 views)
File Type: pdf K5BlazerPowersteps_TopPlate Weldment.pdf (111.5 KB, 82 views)
Old 11-11-2022, 04:03 AM   #79
Blazerowner
Blazerowner's Avatar
Very nice. Much appreciated.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is offline   Reply With Quote
Old 03-20-2023, 01:35 PM   #80
paujones1
I purchased the Powersteps for the Jeep as recommended. I’m wondering if aluminum stock would work for the brackets vs steel?
paujones1 is offline   Reply With Quote
Old 03-20-2023, 04:37 PM   #81
harrij4
It probably would. I personally went with steel because a) I didn't want to experience any flex when standing on the steps, and b) because I'm better at welding steel than aluminum
Beyond stiffness, the issue you'd run into (if trying to use my design exactly) would be the weld nuts on the top plate assembly.
Old 04-07-2023, 07:19 PM   #82
paujones1
I went ahead and ordered the steel and hardware per
Your specs. Pricier than I expected but I have it shipping so that cost a few bucks. I went with 4 4” lower plates that I will weld into the 2 plates. Was easier than sourcing 8” wide plate steel. I may have some questions / comments when I get into it… but I am very grateful for the recommendations, instructions and supply list!
Old 05-08-2024, 01:02 AM   #83
Blazerowner
Another option:
https://hoganbuilt.com/productPages/exterior/ampStep
Kirk
66 Nova
Old 05-08-2024, 02:57 AM   #84
Richard
Originally Posted by Blazerowner View Post
Yikes! Seems Blazers are bit more troublesome than trucks, but that is a hefty price they are asking for RND on the brackets. Was just able to just use some axle shims to get Amp steps on my 72 SWB truck. Install can be seen in my build thread.
Richard
Old 05-08-2024, 03:16 PM   #85
SeventyOne
I'm in the middle of installing these on mine
SeventyOne is offline   Reply With Quote
Old 05-08-2024, 03:36 PM   #86
Blazerowner
Happen to have some pictures of the install? I just ordered a set.
Kirk
66 Nova
Old 05-08-2024, 08:19 PM   #87
SeventyOne
I'll post some pics when i get back in the garage to keep working on it.
Do you have your AMP steps already?
Old 05-08-2024, 11:11 PM   #88
Blazerowner
Not yet. I ordered a set from summit racing but they are on back order.
Kirk
66 Nova
