Old 01-28-2019, 07:02 AM   #76
Wgesnerjr
Wgesnerjr's Avatar
Re: Stumbling after start up
I got the free Torque Lite app, but considering how it helped me solve the mystery, I will probably go back and get the pro version. The free app takes about 30 sec to link up with the PCM, so you can imagine with my problem, how little time I had for diagnostics. I would be very interested in the "fast connect" option.
The Veepeak dongle/device had some recommendations on apps depending if you have Android or Apple. I am Android so I tried OBD Check but thought it was too limited on the free version. The Torque Lite app had more ability to see more items and the output could be changed between the line graph, a dial indicator or basic number readout. I felt it gave better info and cool stuff like speed, 0-60, etc. Not a lot of explanation of the reading (good vs. bad, in range vs. out of range, etc.) but still gave the best info, IMO. Abilities like reading and clearing codes on the free app were good too.
The one downside is that it will not let you modify or turn things on/off. You would need some kind of editing software for that.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 01-28-2019, 08:41 AM   #77
jjzepplin
jjzepplin's Avatar
Oh snap! I just saw the linky and I have something very similar that I can check codes with. Your app is better than mine though. I must search for a better one! I also went and bought a scanner from Harbor Freight. The best one they have and it is pretty cool as it can reset SRS codes and it gives you possible fixes to the issue it finds. I also have a Snap On unit but the HF unit is easier to use.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
