04-23-2020, 09:53 PM | #76 |
Re: Facebook Marketplace finds
67 SHORTBED rolling chassis
Nixa, MO · 2 hours ago · $1,500 https://www.facebook.com/marketplace...5363151232165/ 67 swb chassis CPP tubular trailing arms, lowering springs with air shocks in rear 2.5 drop spindles with disc brake conversion with lowering springs in front Truck was rear ended and cab was used for a tube chassis build. Also has newer brake booster and master cylinder Wheels and tires included. Price is OBO Less
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-23-2020, 10:01 PM | #77 |
$5,900
1972 Chevrolet k10 Siloam Springs, AR · https://www.facebook.com/marketplace...0414686794857/ About This Vehicle Tow hooks and 4 speed tilt. Manual transmission Exterior color: Brown · Interior color: White Good condition Seller's Description 1972 K10. Factory 4x4. 4 speed. 350 motor. 3.73 gears. Runs and drives. Factory tow hooks. New cab corners and rocker panels. New fuel system. New 33x12.50 tires. 4 speed tilt column. Very solid project. Comes with lots of new parts.
04-23-2020, 10:20 PM | #78 |
04-23-2020, 10:38 PM | #79 |
More treasure there this is what is in the little shop behind the truck
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
04-23-2020, 11:01 PM | #80 |
sub
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-24-2020, 12:57 AM | #81 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
04-24-2020, 09:14 PM | #82 |
1972 Chevy 4x4
Cumberland City, TN · over a week ago · $7,000 https://www.facebook.com/marketplace...1145947589647/ 400 sb ,.30 over, 400 turbo w/h shift kit. A/C cab. Dana 44 front and rear, 3.73 gears. Runs and shifts great. Needs front leaf springs and you can drive it anywhere. Comes with extra stuff for these trucks I've accumulated over the years. If the ad is still up it is available. Will not answer "is it still available"
04-24-2020, 09:15 PM | #83 |
nice truck
04-24-2020, 09:17 PM | #84 |
04-25-2020, 06:08 PM | #85 |
04-26-2020, 09:14 AM | #86 | |
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
04-26-2020, 11:36 PM | #87 |
Looks like someone is getting a good deal.
I know it's not the right year but I love this thing! It's definitely not a steel though. https://www.facebook.com/marketplace...40410150365440 |
04-26-2020, 11:48 PM | #88 |
1968 Chevrolet c-10
Piqua, KS · 10 hours ago · $4,000 https://www.facebook.com/marketplace...6249804494125/ Driven 150,000 miles Manual transmission Exterior color: Orange · Interior color: Orange Good condition Seller's Description 3 speed manual on the column Runs Minimal rust here and there Long bed (wood needs replaced)
04-27-2020, 11:35 PM | #89 |
1967 Chevrolet c-10
Yukon, OK · over a week ago · $4,500 https://www.facebook.com/marketplace...8742335181674/ About This Vehicle Driven 121,000 miles Automatic transmission Exterior color: Blue Seller's Description 1967 C-10 pickup lwb. It’s a solid truck with zero rust in the rockers, cab corners and floor. Truck is all original with the rare big back window. It is a roller. Parts: New door seals New window seals New carpet Tci trans cooler Ict ls motor mount adapters Cpp trans linkage Cpp trans crossmember Cpp 3/5 drop with shocks and panhard bar.
04-27-2020, 11:46 PM | #90 | |
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
04-28-2020, 12:16 AM | #91 |
Found this on Marketplace in Indiana yesterday. I picked it up today 4 hours each way and $700.00
04-28-2020, 01:33 AM | #92 |
04-28-2020, 08:21 AM | #93 |
I wish I could!
04-28-2020, 01:48 PM | #94 |
https://www.facebook.com/marketplace...8095151866058/
This is a factory v8, automatic, factory AC, power steering, power brake, CST, the motor runs great and lights work. Will be checking to see if I can get it driveable. I have a clean title and original build sheet for the truck. This is a great truck for restoration.
04-28-2020, 01:51 PM | #95 |
https://www.facebook.com/marketplace...1382065816012/
1972 c30 one ton dump truck .. 355 small block Chevy 4 speed rock crusher tran. Truck been packed for over a yr do going to need one back tire and new water lines and new belts on the motor as far as I can tell that all it will need to run again open to any fair trades looking for a good running work truck u can buy the dump bed for what I'm asking so don't low ball me
04-28-2020, 06:14 PM | #96 |
Lots of good stuff.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) Last edited by 71gmcC15; 04-28-2020 at 06:25 PM. |
04-28-2020, 06:50 PM | #97 |
Smitty '71 Short Fleetside Spring Valley, Ca. |
04-28-2020, 10:34 PM | #98 |
1971 Chevrolet c10
Kansas City, MO · 59 minutes ago · $2,500 https://www.facebook.com/marketplace...4777086030878/ Driven 11,000 miles Automatic transmission Exterior color: Orange · Interior color: Orange Fair condition Seller's Description Body is in fair condition, engine did run but been sitting in pasture. Clean title new tires were put on it before pastured. Will make a great truck to restore. Not much rust as you can see in pictures. $2500 . This again. Is a1971 Chevy with long bed very straight body.
04-29-2020, 02:28 PM | #99 |
https://www.facebook.com/marketplace...5743836142921/
72 Chevy C20 Deluxe 2wd Sweet Home, OR · 14 hours ago · $6,500 Seller's Description 1972 Chevy C20 Deluxe 2wd 350V8, auto, disc front breaks, factory AC. This was a barn find that I drug out from behind a shop. Had been sitting for several years. A new battery, 1 hour tune-up, and she fired right to life. Once I got it home and cleaned up, I was pleasantly surprised at the condition. I bought this to be a donor for my K20 and K5 projects that I am working on. But I don't feel right parting out a perfectly good truck, so I'm offering it for sale. BAD: drivers front fender has a large rust hole. Passenger floor has a small rust hole on outer edge Drivers door is caved in slightly (tried to get photos of the problem spots) GOOD: FACTORY AC! Clean Oregon title All other sheet metal is good No rust around windshield Tailgate and front bumper are like-new Bedsides, roof, hood are straight All glass is good Runs excellent (I mean REALLY smooth). Transmission shifts as expected. Front discs. Dog Dish caps, driver quality. It has been painted over the original dark blue. This would be a great restoration base, or if you are desperate for a complete AC cab. Located in western Oregon. I can deliver within reasonable driving distance. $6500. Make me an offer. Not willing to sell parts at this time.
05-03-2020, 09:03 PM | #100 |
