Old 10-20-2021, 08:23 PM   #76
skymangs
skymangs's Avatar
Re: 1950 Chevy 3600 Woody R
I was wrong, the firewall needed one more fill!
Should be is primer tomorrow, God willing
skymangs is offline   Reply With Quote
Old 10-21-2021, 09:08 PM   #77
skymangs
skymangs's Avatar
First we drillled the hole for the firewall pass through grommet for the engine harness
Then we welded a tab to bend and hold the starter wires
Here’s the firewall masked and wet sanded
Here it is in one color
Much easier to tell where it needs work, and there are a few places
Old 10-21-2021, 09:10 PM   #78
skymangs
skymangs's Avatar
then we dragged over a mock up engine and started designing the engine cover
this is the template for the coil covers
The lines are where we intend to bead roll
Old 10-22-2021, 09:40 AM   #79
Tempest67
Tempest67's Avatar
nice custom touch, looking forward to seeing it in metal.
Tempest67 is offline   Reply With Quote
Old 10-22-2021, 10:55 AM   #80
skymangs
skymangs's Avatar
Thanks we try
Old 10-22-2021, 11:52 PM   #81
skymangs
skymangs's Avatar
We did figure out the coil covers though. We have to re-make the left one, screwed up the bead roll.
The transfer of the templates to steel
The mock up of the passenger coil cover, it’s out of position and not fastened down yet
We will be building a center cover, I just need these figured out first
Old 10-25-2021, 07:22 AM   #82
6DoF
6DoF's Avatar
got a nice patina look there too
6DoF is offline   Reply With Quote
Old 10-25-2021, 09:45 AM   #83
skymangs
skymangs's Avatar
Thanks, but we will be repainting the truck. Patina'd robins egg blue
Old 10-25-2021, 09:54 PM   #84
skymangs
skymangs's Avatar
We started the day working the firewall. Bodywork where it needed touchup
And then a final coat of filler
Old 10-25-2021, 10:01 PM   #85
skymangs
skymangs's Avatar
we wound up re-making both coil covers, the bead roll wasn’t as straight as I thought
Here’s the finished product
we primed both sides
Tomorrow we build the intake cover and work on the outside of the cab
Old 10-26-2021, 07:35 PM   #86
oldman3
oldman3's Avatar
nice...Jim
oldman3 is offline   Reply With Quote
Old 10-26-2021, 08:50 PM   #87
skymangs
skymangs's Avatar
Thanks buddy
Old 10-26-2021, 09:26 PM   #88
skymangs
skymangs's Avatar
so we pretty much worked on the engine cover all day. This is what $30 worth of specialty hardware gets you
so once we had attachment figured out we could begin designing the intake cover
Old 10-26-2021, 09:29 PM   #89
skymangs
skymangs's Avatar
the crease is just for templating, won’t be there in steel. The lines represent bead rolls
The idea was a round cover to go with the round lines of the truck
Old 10-27-2021, 09:11 PM   #90
skymangs
skymangs's Avatar
The firewall has about done
Here’s the engine cover, now we still have some bending and tweaking to do, but you get the idea
the last pic is an idea we had. Putting an oval hole in the side of the engine cover to use the fender supports
Old 10-28-2021, 07:33 AM   #91
6DoF
6DoF's Avatar
i don't know, something is messing with my eye ... the big center cover just seams kinda too much. maybe the back could be cut in kind of like the front cuts out, just less?. maybe a step between the intake and coil covers to break up the solid plane? maybe i'm missing the look with the rest of the fender and rad covers, or maybe i'm nutz and am just the guy who never really likes full covers too.
but i don't have your final vision, so i shall stay tuned!
Old 10-28-2021, 10:06 AM   #92
skymangs
skymangs's Avatar
dunno, I’ll run the cutting the back idea by my mechanic and see what he thinks
Old 10-28-2021, 10:21 PM   #93
skymangs
skymangs's Avatar
We’ve discussed cutting the back of the intake cover and decided against it. The owner is delighted with the look.
Old 10-28-2021, 10:23 PM   #94
skymangs
skymangs's Avatar
The last few trouble spots on the firewall
Firewall in primer
Old 10-28-2021, 10:29 PM   #95
skymangs
skymangs's Avatar
After some hammering and dolliieng the engine cover is much straighter
I can almost be proud of that!
Old 10-28-2021, 10:35 PM   #96
skymangs
skymangs's Avatar
Gas filler got it’s final fill and prime
But we found a few more dents
Old 10-29-2021, 07:46 AM   #97
6DoF
6DoF's Avatar
that's all that matters!!
Old 10-30-2021, 10:54 AM   #98
skymangs
skymangs's Avatar
We worked on that hinged center grill
I think it came out looking pretty sharp!
Monday we’ll make the radio plate that goes behind
Unless you have strong objections, I am going to paint the center of the grill and glovebox door dashboard color
And we finally got that right speaker pod in!
Old 10-30-2021, 11:33 AM   #99
Tempest67
Tempest67's Avatar
nice touch with the hinged speaker grill.
What are you going to use for a latch? magnet?
Thanks for sharing these ideas,
Old 10-30-2021, 12:37 PM   #100
skymangs
skymangs's Avatar
yeah, magnets seem to work best. Powerful earth magnets
