01-01-2022, 06:41 PM | #76 |
Re: Interest in Dummy Gas Cap Filler Neck?
01-02-2022, 11:11 AM | #77 |
I’d buy one.
01-03-2022, 12:06 PM | #78 |
01-03-2022, 12:44 PM | #79 |
pj,
I am in as well. I was looking at the gaping hole in my truck cab this weekend and thought of this thread. Sure, I could make something myself but sometimes it's more time conscious to buy something and move on to the next thing.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
01-03-2022, 12:49 PM | #80 |
Sweet. Thanks. I might need to make more than 10
01-03-2022, 01:34 PM | #81 | |
01-03-2022, 01:36 PM | #82 |
I own both a 55.2, 3100 and a 68, C10.
Since you are still at the brain storming stage of design, now is the time to consider a single design that would include an expanded market of "most" years? Step back and look at the big picture. Don't narrow your design to only portion of our hobby. I believe your existing concept design could be slightly modified to accommodate a larger market. |
01-04-2022, 04:33 PM | #83 |
Based on some measurements Bullzak_83 took for me, I added a 3/8" spacer to the outside of the filler neck to get it to stick out the correct amount. Personally, I don't really like the way the spacer looks. I think it makes the filler neck look too bulky. It does, however, support the filler neck better due to the larger contact area with the grommet. What are your opinions? Spacer or no spacer?
I still need to test the finger clamp idea dmjlambert proposed. It may be tricky due to the irregular curvy shape of the cab where the filler neck is located. |
01-05-2022, 12:12 AM | #84 | |
01-05-2022, 01:16 PM | #85 |
Looks neat.
I just cut the neck off my old tank, got a new grommet/seal and popped it back in the hole. It stays there real well and holds tight. Even if someone took off the cap, they can't really get to anything back there, so I'm not worried about it. |
01-05-2022, 01:30 PM | #86 |
Would it be possible to use thinner wall tubing for the spacer? If so that would give it a less bulky appearance.
01-05-2022, 01:50 PM | #87 | |
Beep! Beep!
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport 2003 Chevrolet 2500HD CC 6.0 4wd 2004 Jeep Rubicon some aftermarket stuff... 2019 Jeep Unlimited Rubicon (the wife's baby hauler) |
01-05-2022, 02:31 PM | #88 |
01-05-2022, 02:33 PM | #89 | |
01-05-2022, 08:02 PM | #90 |
I like the first design with the spacer and it would be for a 72. Great job at putting this all together.
01-06-2022, 04:23 AM | #91 |
I found some thinner tubing to use as a spacer. It blends in much better than the thicker tubing I tried previously. I think it might be sticking out a little too far. The last photo is with the original tank still installed. What do you all think?
01-06-2022, 07:02 AM | #92 |
I think it looks great and that spacer work for me.
01-06-2022, 08:45 AM | #93 |
I'm in for your original idea. I personally like the low profile look to it.
Just say when.... |
01-06-2022, 09:44 AM | #94 |
Makes me wish I never blanked off the old cab fill on my GMC.
Low profile or standard are both cool. I'm in for whatever you decide. Great work, PJ.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
01-06-2022, 11:00 AM | #95 |
Since I am still in the body work stage, I'm thinking of welding tabs on the inside of the cab to bolt the filler neck brackets to.
01-06-2022, 11:09 AM | #96 |
01-06-2022, 11:56 AM | #97 |
01-06-2022, 03:34 PM | #98 |
Excellent work! That does look better. It also doesn't appear to distort the grommet, like the thicker spacer. You can add me to the list of buyers.
01-06-2022, 09:54 PM | #99 |
I think that is perfect! Excellent job!
01-06-2022, 10:02 PM | #100 |
Thanks for the feedback. I appreciate it!
