04-15-2022, 05:34 PM | #76 |
Re: subframe question
Sorry, thought you said 81 up.
04-15-2022, 06:03 PM | #77 |
04-15-2022, 11:03 PM | #78 |
I have a 57 one ton and I installed 73 3/4 ton frame on my truck and it could'nt have worked out better, I cut a c shape right behind where shocks were mounted. I then removed the rotors and calipers, installed 1988 one ton rotors, put the calipers back on and a proportioning valve and a dual chamber m cylinder in the stock location with a booster and it rides, handles, steers, and stops like a 73 to 85 square body. make sure to right down any V I N or serial number you come across, most frames are numbered on the front. and make sure (most important) that you keep the wheel base the same.
04-15-2022, 11:06 PM | #79 |
Included some pics if it helps. TonyMann.
04-21-2022, 11:10 PM | #80 |
can get a 91 1 ton dually frame but not sure on making it work.
also can get a mid 90's 3500 hd. it has 19.5 wheels and 454ci with 4l80e Those years have a lot more curves in the frame. |
05-12-2022, 12:15 AM | #81 |
Got my hands on a perfect 1980 long bed 3/4 ton frame. Looks like I will do the complete swap instead of the graft after all.
05-12-2022, 08:23 AM | #82 |
Nice. Post up so.e pics when you get rolling in it.
06-14-2022, 06:51 PM | #83 |
8 inches removed from wheelbase
06-14-2022, 07:06 PM | #84 |
Nice fitment. Should weld up nice.
06-19-2022, 04:12 PM | #85 |
plates bolted into place and ready to weld.
I know the plates are overkill but I like to over engineer everything. |
06-19-2022, 04:19 PM | #86 |
frame is nice and straight
06-24-2022, 02:47 PM | #87 |
cab mounts installed
04-07-2023, 07:58 PM | #88 |
engine and tranny is in
04-07-2023, 08:00 PM | #89 |
1st suburban tank bracket installed
04-07-2023, 08:05 PM | #90 |
good forward progress. keep plugging away and soon it will be together.
