11-19-2022, 07:15 PM | #76 | |
Re: CPP Rear Disc Brakes not bleeding!!
Could you send me a picture of how yours is installed? |
11-19-2022, 09:17 PM | #77 |
Good grief...swap the calipers side to side so the bleeder is on top of the piston hole. The levers should be on the bottom, not going over the top of the housing.
11-19-2022, 09:52 PM | #78 |
I didn't read through your entire thread, but when I did my disc brake swap on my '59, I used brand new rubber brake hoses from NAPA, front and rear. After trying to figure it out for a long time, I removed the new NAPA rubber brake hose and tried to blow through it. Nada. I went to NAPA, swapped it for another hose, which allowed the brakes to bleed appropriately. So, even if brand new, if you are still stumped, trying replacing the hose. Or at least remove it and see if you can blow air through it.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
11-19-2022, 09:58 PM | #79 | |
Dont good grief me....Please do not respond if you do not know what you are talking about. The calipers are on the correct sides and installed correctly. |
11-19-2022, 10:01 PM | #80 | |
11-20-2022, 09:54 AM | #81 |
Did you get a Motive power bleeder like this one?
https://smile.amazon.com/gp/product/B00CJ5E1GS/ It includes the flat plate that you would clamp to the top of your Wilwood master. You do have the oval type Wilwood master that has 4 allen head screws holding the top on? EDIT: Just found this video... I'm interested in being able to pressure bleed the Wilwood with a Motive power bleeder too. This guy says the plate I was talking about won't fit the wilwood. https://www.youtube.com/watch?v=cUOMt-81RiM Edit again: This the the vacuum bleeder from harbor freight I have - https://www.harborfreight.com/brake-...der-92924.html - I usually use this on the longest run and then the other 3, but end up finishing with this type bleeder - https://www.autozone.com/test-scan-a...-kit/46839_0_0 - Last edited by Jason Banks; 11-20-2022 at 10:04 AM. |
11-20-2022, 10:08 AM | #82 |
My car is put away at my rental next time I go down I’ll snap a few .
Edit :Found it prior to install . I used adjustable upper control arms to angle the rear as the pinion was angled to far down . Which angled the bleeder more to the top but the rotation of the bracket was still needed
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-20-2022 at 11:10 AM. |
11-20-2022, 10:10 AM | #83 |
The way the caliper is orientated if you put the ebrake on the bottom the bleeder is also on the bottom .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-20-2022 at 10:30 AM. |
11-20-2022, 10:12 AM | #84 |
I think 72c20customcamper is onto something. It appears the hose attaches on one side and horizontally straight across is the bleeder. The bleeder is not at the top of the caliper, so you have the top half of the caliper still
filled with air. You might need to rotate the brackets on the rear end to get the bleeder to be in the highest position possible. Which, might require swapping the calipers from side to side also. Edit: after seeing the new pic 72c20customcamper posted, I see I'm wrong about it being horizontal with the hose, but the rotating of the bracket on the rear end still probably needs to happen. |
11-20-2022, 10:14 AM | #85 |
All I did was rotate the bracket to the next hole . I used the same clamps also as I forgot to weld on the line keeper brackets which came with the rear .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-20-2022 at 11:13 AM. |
11-20-2022, 10:46 AM | #86 |
Here's the motive bleeder that should work with the Wilwood - https://www.motiveproducts.com/produ...c_id=61f139fc6
11-20-2022, 11:33 AM | #87 |
11-20-2022, 11:35 AM | #88 | |
11-20-2022, 12:15 PM | #89 |
If the cable moves smoothly it should matter if there is a bend in it . Mine I had to get new longer cables . Since my car sits high in the rear and I rotated everything
11-20-2022, 12:19 PM | #90 |
That should work . The first time I did mine I just took out the front bolt and put some plate steel in between the pads . From my memory which isn’t great half the pad was still on the rotor .
11-20-2022, 03:42 PM | #91 |
Post Whore
Wishful thinking.
Using the photos you posted I made this crude representation of how the air is trapped in your caliper. I orientated the caliper to match the axle mounted caliper in the photo. The lower half red circle is full of fluid. The upper purple part is where air is trapped. When you pump fluid into the caliper the air compresses into the top. The oil will not compress and is forced out of the open bleeder leaving the air trapped. All a power bleeder will do in this situation is compress the air the same way the master cylinder does. To verify hold a torpedo level level next to the caliper. Keep the top even with the bleeder. If any of the caliper's piston is above the level you will have trapped air. A power bleeder can be helpful in vehicles where the brake tubing is ran higher than the master cylinder and the fluid wants to flow back into the master cylinder between pump strokes. Oh, and when your working for flat rate it helps make you money. It's not common but, there are vehicles that the factory requires the calipers to be removed from their mounts in order to completely bleed the air.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-20-2022, 04:14 PM | #92 | |
Im going to try and rotate the bracket and see if that will work to get the bleeder higher. |
11-20-2022, 05:21 PM | #93 |
>>Im going to try and rotate the bracket and see if that will work to get the bleeder higher.<<
About time. As early as post #12, you were advised to make sure the bleeders were UP. Several posters since then suggested switching calipers to other side in order to get the bleeders UP. Post #65 again ask if you had the bleeders UP. You responded in post #66 with >>The bleeders are facing towards the front.<< Front is not the same as UP A couple of more posts followed, questioning the bleeder position and you responded with, >>Don't good grief me....<< CPP instructions said to make sure the bleeders are at the TOP.
'67 GMC 2500, 292, 4spd, AC |
11-20-2022, 10:18 PM | #94 | |
Move along |
11-23-2022, 12:36 AM | #95 | |
I just want to make sure before i take the time to remove everything. |
11-23-2022, 12:38 AM | #96 | |
11-23-2022, 11:16 AM | #97 |
It is not possible to determine from the pictures if the bleeder is at the top.
It still looks to me like the bleeder still has a little bit of the piston above it, but the pictures make it impossible to know for sure. |
11-23-2022, 12:46 PM | #98 |
I have installed the calipers and brackets per CPP instructions. Again please do not respond if you have comments to make and DO NOT know what you are talking about.
Cuz everything you've done so far has worked out for you Flip the brackets side to side so the long leg curls underneath--that will rotate the caliper the needed distance |
11-23-2022, 02:53 PM | #99 |
I would try to clock it a bit worst case is you still don’t have brakes . I’m assuming this is the passenger side since there’s a big R on the bracket . Take the top caliper bolt out and rotate .
11-23-2022, 07:30 PM | #100 |
Post Whore
While you have the caliper unmounted here are a couple of things to consider looking at.
Watch the caliper piston while having someone slowly push the brake pedal down. SLOWLY you don't want to blow the puck out of the caliper. When you see the puck stop immediately stop pushing the pedal. It's a good idea to check the fluidl level in the master cylinder after doing this. The caliper puck should move out approximately the the same distance as the thickness of the brake pads. In other words if one pad's lining is 1/4" thick the caliper should move out about 1/2 inch. (1/4 x1/4 = 1/2) A 3/8 inch at a minimum of move should be expected. Once you have fully extended the puck use a brake caliper compressor (or a C-clamp and a plate) to move the puck back into the caliper body as far as possible. Open the bleeder before pushing the puck back in and hold the caliper with the bleeder at the very highest point. Use the compressor to push the fluid and hopefully air out. Once the puck is completely compressed shut the bleeder. Pay attention to how far each puck extends. It is possible that the pucks are at their limit of extension and that may be causing problems. By compressing the puck you are minimizing the amount of air that can be trapped inside fr when you. When reinstalling the caliper with the compressed puck pay attention to how much play there is between the disk and the pads. With new pads and a proper new rotor there should be about 1/4" of play. When doing these checks do them one caliper at a time. After the first one is reinstalled pump the brake pedal to get the pads pushing against the disk again before starting on the 2nd one. Again keep an eye on the master cylinder fluid level. After doing all this and you have no change I would dive into the master cylinder as I would expect it to have a problem. All it takes is a fiber like a paint brush bristle under one of the master cylinder piston seals to foul things up. If things are better but not great then you likely will need to bleed the caliper unmounted with the bleeder as high as possible and a plate of similar thickness between the pads. I hope this makes sense. Your looking for a caliper that is not responding as expected indicating a problem inside. Good luck and keep us posted.
