Old 04-04-2013, 08:41 PM   #976
jasons
not enough hours in the day
jasons's Avatar
Re: Tbi swap build thread
I have ground at the following plugs.
A12- blk/wht- System ground
B3- blk/red- Distributor plug
B10-orange/blk- park neutral switch wire
D1- brn/wht- system ground
D6- Tan- O2 sensor ground to engine
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
& piles of spare parts
jasons is offline   Reply With Quote
Old 04-04-2013, 10:38 PM   #977
jasons
jasons's Avatar
Installed the new IAC valve and did the reset procedure. Now it idles at 2,500rpm.
I'm at a loss. It's hard to search for a vacuum leak when you don't want to let the motor run.
Just a thought, but could too much fuel pressure cause this?
The fuel pump is rated at 29 GPH @ 12 PSI which should be right. Would a blocked return line boost the pressure? I ran into that on an 87 Dodge pickup once, but the increased fuel pressure caused it to shut down after a couple seconds, not run fast.
Any ideas? I appreciate it.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-04-2013, 10:50 PM   #978
rfmaster
rfmaster's Avatar
Originally Posted by jasons View Post
The IAC did click when A&B pins were jumpered, I'm just not sure the plunger extended completely, the new IAC valve will be here in a couple hours.
The EGR valve is installed and the vacuum hose is connected. Should it be disconnected for this?
I will double check grounds at the ecm plug.
BY disconnecting EGR you'll make sure that EGR is not active at idle. This is just a precaution.
There are no grounds at ECM - there are two multi pin plugs that plug into dual row connectors. The grounds that I referring are harness grounds - 3/8 ID lugs in the engine bay.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 04-05-2013, 12:23 PM   #979
jasons
jasons's Avatar
Having run out of ideas and remembering late last night that a friends 87 body swap project was in one of my storage units I swaped throttle bodys. It now idles like it should. I must have gotten something messed up when I put the kit in my throttle body. I'll have to go throught it again.
Thanks for the help RF.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-06-2013, 08:38 AM   #980
BigrobDog
all i got left is my drac to wire up . has any body got info on were to wire each wire to, 90 suburban 350
BigrobDog is offline   Reply With Quote
Old 04-10-2013, 05:00 PM   #981
jasons
jasons's Avatar
Originally Posted by rfmaster View Post
Ok Guys.
Zooming into high temperature coolant area.
Cross over occurs right around 76 to 80C region.
AC Delco G1852 (found on Internet) data stops at 100C (212F) - I do not have this sensor at this time, but would like to re-run it to see how it behaves between 100 and 135C.
Next step is to validate SW5051 with the actual gauge.
Suggestions???? Questions???
//RF
Do you have the data for the SW5051 sensor broke down as to Ohms at a specific temperature? I have the data for the G1852 from the web, which is probably the same you found, but can't find it for the SW5051. I used the 5051 sender in my Blazer and the gauge pegs before the electric fan comes on at 185*. I think adding a resistor in line would work, but need to know what the difference between the two senders is to figure out how much resistance to add.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-11-2013, 02:17 AM   #982
rfmaster
rfmaster's Avatar
Yes, SW5051 is not a direct replacement.
RED line is the temperature curve for SW5051 with a series 22 Ohm resistor added. Below 75C (165F) the temperature gauge will be displaying very low temperatures due to higher resistance offered by SW5051. Above 75C with 22Ohm series resistor SW5051 appear to track TU5 very closely.
I have not had a chance to verify this, but test data supports this conclusion.
//RF
"The Beast"
Old 04-11-2013, 08:27 AM   #983
jasons
jasons's Avatar
Thanks RF. I was thinking around 30 Ohm would be needed. I'll get a resistor to add and post the results.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-11-2013, 09:17 AM   #984
Jonboy
Slots go on anything!
Just a quick fuel question, for a swap into an older vehicle. I am getting ready to help a friend do a TBI swap into a '74 Blazer, but it does not have a return line. What is the best way to do one? Should I use rubber line going back to the tank, (and does the return need to be FI rated?), or does it need to be hard line. I am planning on using an inline fuel pump and using the original feed line. Also, where are you guys putting the fuel filter when doing an inline pump?
Old 04-11-2013, 11:05 AM   #985
rfmaster
rfmaster's Avatar
1) You'll have to become a plumber and install a new 3/8" supply line - for example SUM-G2538 aluminum fuel line which is easy to work with. Use your old line as return. Do not use rubber line - it will increase pressure drop and will deteriorate over time. As a minimum supply must be 3/8" and return 5/16". Return is a low pressure, but it still carries fuel. When plumbing vehicle for EFI keep safety and long term maintenance in mind!!!
2) If you have a baffled tank - use in tank fuel pump. In case of conventional tank use largest fuel filter you can find before inline FP inlet port. Large fuel filter will act as a mini surge tank and prevent fuel starvation when fuel sock gets uncovered. It is not a perfect solution, but it is as close as you can get away with without building a full surge tank system and lift pump.
//RF
"The Beast"
Old 04-11-2013, 11:10 AM   #986
Jonboy
Wow. I would have thought that the feed line would have been 3/8 already. Guess that's what I get for trying to engineer a TBI swap from 250 miles away. Thanks for the heads up.
Old 04-11-2013, 01:05 PM   #987
rfmaster
rfmaster's Avatar
It probably is a 3/8" line, but after 40 years of service I would be leery to subject OE fuel line to high pressure. Fuel fires kinda ruin your day! In carb operation the fuel is sucked from the gas tank by the engine mounted fuel pump. In the EFI system fuel pump is working against FPR mounted in the TB, hence between fuel pump outlet and TB FPR fuel system is pressurized. Leaks are not good since today's gasoline is a nasty concoction of Gasoline and ethanol and other 'poop' that I do not care to remember.
//RF
"The Beast"
Old 04-11-2013, 01:08 PM   #988
rfmaster
rfmaster's Avatar
22, 27 and 33 Ohms are standard values per E12 (10%) series resistors.... Use 2 Watt Allen Bradley resistors if you can..
//RF
"The Beast"
Old 04-11-2013, 07:51 PM   #989
jasons
jasons's Avatar
I added a 22 Ohm resistor. The guage is now about 2/3 of the way up the normal range.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-11-2013, 08:56 PM   #990
rfmaster
rfmaster's Avatar
Earlier generation gauges may have been a bit off, but like you said you may try slightly higher resistor to dial it in.
//RF
"The Beast"
Old 04-11-2013, 09:19 PM   #991
jasons
jasons's Avatar
I'm fine with where it reads now. I tried a 22 Ohm resistor, but it put the guage at about 1/3 of the way into the normal range. A 27 Ohm would probably put it in the middle, but the local Radio Shack didn't have one.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-15-2013, 03:33 PM   #992
k1blazer
k1blazer's Avatar
I apologize for coming in late in the thread. I have a 72 K5. What did you guys do to tackle the return fuel line to the tank?
k1blazer is offline   Reply With Quote
Old 04-15-2013, 08:25 PM   #993
jasons
jasons's Avatar
I'm running an in tank fuel pump that has a return build into the unit. It's a little more than a frame mounted pump, but as far as I'm concerned it's worth it. It is as quiet as a factory setup and I've run it with as little as 3 gallons of gas in the tank with no starvation problems. This is where I got the pump
http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm. It is item PA-TBI. The customer service was excellent also. For a stock Blazer tank let them know you need longer tubes for a 13" deep tank and you will have to improvise a little on mounting the sump pump to the bracket. I welded mine together and it works fine.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-15-2013, 10:09 PM   #994
k1blazer
k1blazer's Avatar
That's pretty awesome! So this one mounts directly to the stock tank?? I'll be honest, I've never actually seen the top if my tank.
Old 04-16-2013, 08:21 AM   #995
jasons
jasons's Avatar
I didn't take any pictures while putting it together. You would cut about a 4" hole in the top of the tank, be careful if reusing your existing tank. I put the unit in just behind the existing sending unit which you will still need for the gauge. I had to move the tank forward about 2" to clear the crossmember. The fuel pump could be located toward the right front corner of the tank and then the tank could stay in the original location. Just make sure there is no interference between the pump unit and the sending unit for the gauge.
65 K-10 Short Step
68 C-50
70 K-5
85 K-10
Old 04-16-2013, 08:38 AM   #996
k1blazer
k1blazer's Avatar
Thanks again!! I can't wait to start on mine.
Old 04-22-2013, 11:36 PM   #997
k1blazer
k1blazer's Avatar
Guys! This is a very long thread and I've read through it. Thanks for all of the information! I have a question though. I probably just overlooked this in the thread but which intake manifold would I use on a '72 small block. The two center holes are at different angles on the later manifold.
Old 04-23-2013, 01:49 AM   #998
rfmaster
rfmaster's Avatar
1972 block is not your main concern, but cylinder heads produced from 55 to 86 had the four inner holes drilled at 90 degrees to the head flange surface. Starting 87 and up CI heads had the four inner mounting holes drilled at 72 degrees.
Holes in intake manifold can be slotted to accommodate 72 degree angle or manifold adapter bushings from Professional Products part number 52110 can be used in place of washers.
//RF
"The Beast"
Old 09-03-2013, 09:43 PM   #999
iceship
So what is the least about of componits you need for the engine to fire up. ....
iceship is offline   Reply With Quote
Old 09-09-2013, 01:00 PM   #1000
rfmaster
rfmaster's Avatar
The thread has been quiet for a while! For those who are looking to upgrade TBI harness from JY pulled rat nest or contemplating clean carb to TBI swap Northern Autoparts has a special on Painless EFI TBI swap harness #60101 this week:
http://www.northernautoparts.com/Pro...ProductId=1468
//RF
"The Beast"
