#1001 |
Re: Rat repair.
looks like you need to strain your paint looks a little lumpy or maybe water in your air line
#1002 |
Re: Rat repair.
Yea i donno, I did strain it and aside from my manifold feeding 2 water separator traps another 100' of hose i installed an inline desiccant air dryer then another 50' of hose, i suppose its possible my last 50' of hose may have a little moisture in it its been sitting in the garage about a year? I will confess i did go in and out of the side door a couple times and forgot to shut off the fan first...
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#1003 |
Re: Rat repair.
i sprayed a lacquer once and it did the same thing it was too thick and too much paint not enough air and it didnt atomize right and ended up flinging blobs everwhere
#1004 |
Re: Rat repair.
This is PPG DP50lf grey primer and DP402lf catalyst. Sorry for the confusion..
But if the paint is too thick would i use paint thinner or laquer thinner to thin this stuff?
#1005 |
![]() Join Date: Mar 2012
Re: Rat repair.
I agree the material looks a bit heavy for the orifice size you have on the gun. Easiest fix would be to reduce it with a DT reducer. Get a quart of DT870 (mid temp) or whatever is most compatible with the temperature range you'll be spraying at. I don't recommend mixing brands or using generic reducers. Stay within the product line for best results. Not to say I haven't crossed over in an emergency, but there's a good chance you'll only make a bad situation worse. Good luck!
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#1006 |
Re: Rat repair.
Thanks Vic and , 69chevytrucker!
#1007 |
![]() Join Date: Dec 2012
Re: Rat repair.
Rat, you are more brave then I.... I hate to paint and I don't have the patience... that is a bad combination when painting!!! rock on!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#1008 |
Re: Rat repair.
Well i always wanted to take an auto body course at a community collage, but this way instead of spending money on tuition i spend it on paint supply's LOL!
Honestly i just wanted to try my hand at it, i may fail but i'm getting great advice and learning as i go, my biggest obstacle right now is having to have the garage doors shut while painting because its not warm enough outside and i'm using heaters.. Fumes get a bit strong until i air the garage out a little, usually a bout 1-2 hours after i lay down the paint..
#1009 |
Re: Rat repair.
Today was color day, I did have some dust bunny issues and I even went in there with a damp rag and wipes the walls and floor down real quick, this is making me wonder if I'm suppose to wipe the part off with wax and grease remover between coats? I have stayed within the window for no sanding in between.
#1010 |
Re: Rat repair.
I have had the same issue with dust bunnies. the last time I did some painting I hung static cling dryer sheets and wet the floor down with water to control the dust. worked out good for me.
#1011 | ||
Re: Rat repair.
Can't wait to see more!
"I feel the need for speed!"... as soon as I am done with my nap. |
#1012 |
Re: Rat repair.
Interesting thought on the dryer sheets. May be worth a shot. Thanks!
#1013 | |
Re: Rat repair.
#1014 |
Re: Rat repair.
Here's a couple of close ups of the same area, one with flash the other without, looking at it close up i'm starting to wonder if this is contaminant more than dust? what do you guys think?
So i guess i can color sand this with 1200, 1500 and 2000 and hit it with some swirl remover polish. And this paint is quite a bit brighter than the stock interior paint, i should have used the tag they printed when i did a color scan on my glove box lid but i forgot it when i went to buy the paint, of course its too late to add or remove pigment now. I will continue to use it for the places i mentioned but may reconsider the door jambs. (being educated ![]() So i have read enough of these forums to now garner the opinion that dual stage paint may be easier to work with so will probably try that for any other painting than what i have planned with this stuff.
#1015 |
Re: Rat repair.
you know i think alot of guys spend all the money painting a old late 60s truck with all the new types of paint but no offence to those guys but these trucks are not meant to have flashy paint jobs yes paint the trucks but you know they to me look better if you have a paint job the is not flawless it should have some spec and oddness to it they are forty and fifty year old trucks.
i think you are doing a great job because you are doing it yourself not getting someone else to do your truck for you i am a die hard build your own truck kinda guy i myself have built my truck by myself no pro help at all and my truck may not be perfect but i did it no one else GOOD FOR YOU FOR DOING IT ON YOUR OWN I THINK IT LOOKS GREAT . HERE ARE SOME PICS OF MINE YOU CAN SEE IT DOES NOT NEED TO BE PERFECT TO STILL LOOK GREAT... |
#1016 |
Re: Rat repair.
So a couple days of schooling by some board members i think i have a handle on my mistakes on my first attempt at painting, I'll try and get back at it soon.
Per post 1014, I do need to take my paint back and have them doctor the mix a little, they assured me that even tho i have used some out of the pint they can still modify it to match the glove box scan closer. I have my Orthopedic appt Monday, looking forward to see what he says.
#1017 |
Re: Rat repair.
So do the inner fenderwells have this bracket attached???? looks like i'd be money ahead buying a set as the rust is thru the bracket...
I talked to the paint shop and they said they could doctor my color paint a little but it takes about 4 days, i'm still waiting for them to finish it. The Dr does not want to rush into any surgery, gave me a cortisone shot and a follow up appt, I cant work overhead for crap right now and explained that to him too... :~/ i remain skeptical..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 05-26-2016 at 05:17 PM. |
#1018 |
Re: Rat repair.
I've repaired them in similar condition, but don't necessarily recommend it. In my case, I could drive to Classic or LMC and pick up the parts to save shipping. But in retrospect, a reproduction piece would have saved me a lot of grief. Of course, then the whole "fitment issues" come into play.
#1019 |
Re: Rat repair.
So my green paint has not been tint adjusted yet, they are swamped.. crap.. Been a week now.
Picked up a pair of inner fenders today locally plus a few other goodies, vendor suggested taking then to sandblast and powder coat someplace, i'm not sure i trust the place i took my rear fender to so don't know about that just yet, a little concerned about the blast media stressing the metal? If i paint them I assume i could just take some red scotchbrite to them first rather than sand? then i assume semi gloss black would be close to stock color?
#1020 | |
Re: Rat repair.
#1021 | |
Re: Rat repair.
I got the single stage back from the paint place today also, they added some yellow pigment to it and documented it on my mix lable for future reference. I sprayed a final coat on the inside of the fender, I'm sure its not perfect but it should be better than what i had before. I also noted my air flow has diminished so i need a new exhaust filter and will consider installing that second fan.
#1022 |
Re: Rat repair.
My last coat is a little lighter, wouldn't mind a little lighter yet but close enough, probably should have waited until i changed the filters but too late. Not perfect but will do for what it is.
Unfortunately i missed a little rust in my inner kick panel and its spreading so i have to cut about a 1.25 X.75 section out and put another little piece in, good thing i waited to spread that bondo! I need to get my butt in gear and start working on more than just one thing at a time.....
#1023 |
Re: Rat repair.
Nice work Mike really impressed on what you've gotten to so far!
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#1024 |
Re: Rat repair.
Thanks, i need some motivation, life has been getting in the way a little.
Small update, I found another blast and powdercoat place that quoted me $45 each to blast prime coat and color coat my inner fenderwells, that was a no brain'er. took them there yesterday. I'll use the paint i bought for other parts eventually I have mentioned i cut that area out of the inner kick panel, it ended up being a little bigger than previously mentioned, i have made a wand extension for a sprayer and have sprayed some GEM rust killer on the inside, will do it again before i weld the new piece in. Still working 2 weekends on one weekend off, starting to burn out a bit.. EDIT: Question, can you color sand single stage paint?
#1025 |
Re: Rat repair.
Maybe if it's been allowed to cure for about a year.
![]() Some folks say if you use a catalyst (hardener) with it and either force dry it or allow it to cure for 3-4 weeks, you can buff a solid color (non metallic) single stage paint. I've tried it a few times and it's very hard to get the sanding scratches out of it. Very easy to screw up and it wants to die back (lose its gloss) fairly quickly. As always, YMMV.
