Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 07-04-2020, 09:59 PM   #1001
quadzero
quadzero's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
This is a very cool update. Love the paint on the box sides. Looking forward to more of the supercharger install. Keep up the great work.
quadzero is offline   Reply With Quote
Old 07-05-2020, 02:50 AM   #1002
Richard
Originally Posted by First c10 View Post
Here is the stator in the freezer that I left over night and the front half in the oven at 200 degrees for 20 minutes.
After it’s hot I will drop the stator in and set the depth and let it all come to room temperature and that will keep them in place.
Looking good. Used that same trick to get the reluctor ring on the output shaft of my 4l60e. Output shaft in the freezer and heated up the ring. Slid right on.
Richard
Old 07-05-2020, 07:37 PM   #1003
swamp rat
swamp rat's Avatar
Lookin sweet!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-12-2020, 07:33 PM   #1004
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Man you are doing some crazy a$$ stuff with this build. I love it. Keep it up.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-13-2020, 12:31 PM   #1005
First c10
First c10's Avatar
Thanks Guys....... I will never get this truck finished if i keep the crazy a$$ stuff up!!
Today I install the Russell performance fitting I ordered so I can finish the Power steering lines up.
I was able to get the front accessory drive finished so just need the PS fitting so I can start the truck to make sure belt tracks like it should and no leaks.
Then on to the Supercharger!!!
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-13-2020, 01:53 PM   #1006
TA_C10
TA_C10's Avatar
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 07-15-2020, 11:11 AM   #1007
First c10
First c10's Avatar
Hey guys! well 1 step forward 2 steps back. I was able to get the front accessory drive completed and running, but when I went to install the drive belt on the supercharger the 8 rib belt touches the water pump pulley. I guess I have to change to a 2010-2015 Camaro water pump due to the domed pulley on a truck water pump. See picture.
so I ordered a new ACDelco pump and it comes in today. I will have to change the belt tensioner and idler pulley because the truck water pump and the Camaro water pump have different accessory mounts. Oh and I am sure the belt itself will have to to be changed due to needing a different length.
More to come....
GO GO!!!
Old 07-17-2020, 03:07 AM   #1008
Richard
I knew that most supercharger drives required the Camaro/Corvette setup. Did not know the belt rides in the same place with the Camaro/Corvette pump. Just a shorter pump and slimmer pulley. Good deal you do not have to change other accessories and pulleys. Hope the idler and WP pulley are the same size so the belt works.
Richard
Old 07-24-2020, 10:39 AM   #1009
First c10
First c10's Avatar
Well since the Camaro water pump and the truck water pump do not have the same accessory mounting locations I had to change the idler location and the belt tensioner. Before the belt length was 111.5" after all said and done I needed a 100.5" belt
GO GO!!!
Old 07-24-2020, 11:14 AM   #1010
First c10
First c10's Avatar
I added the correct length flanged bolts, torqued to spec and was able to start the motor. Man that Supercharger has a nice whine....OK back to the update...
The belts tracked nice but I didn't get to rev it up since I don't have an upper radiator hose (SS parts on order) and didn't want to run it too long.
I started working on the new shorter but taller AC condenser. I made all aluminum brackets for the condenser and picked up more aluminum for the inner cooler mounts.
Hopefully I can get the inner cooler brackets built this weekend and start the intake tubing.
GO GO!!!
Old 07-24-2020, 11:21 AM   #1011
TA_C10
TA_C10's Avatar
Very nice. I like the aluminum brackets. Nerve racking drilling painted surfaces.... Usually goes fine with tape but still, there is always that chance lol.
"It's only money".
Old 07-24-2020, 12:44 PM   #1012
First c10
First c10's Avatar
Yes I agree.....I drilled the core support and added nutserts
GO GO!!!
Old 07-27-2020, 06:18 PM   #1013
First c10
First c10's Avatar
I was able to get the inner cooler brackets made and installed. I still have to clean up the edges and paint the top mounts body color.
Next is to install the grill and see if it clears. I have a feeling I will have to trim the grill louvers to clear either the edges of the inner cooler and/or the aluminum piping.
The hood lever misses the inner cooler by about 1/4".
GO GO!!!
Old 08-05-2020, 12:49 AM   #1014
Richard
Looking good. Maybe have to trim the hood latch brace as well. I am expecting that. Where did you source the condenser from?
Richard
Old 08-05-2020, 11:50 AM   #1015
DWilbur
your engine sits higher than mine and some of the issues I ran into installing supercharger. i had to cut a 1/4" off my cross member to clear the crank pulley. looking good.
DWilbur is offline   Reply With Quote
Old 08-06-2020, 09:57 AM   #1016
First c10
First c10's Avatar
Richard I don’t think I will use the brace. Since the front end is a 67-68 the grill itself is part of the structure of the front. After I get the inner cooler plumbed I will install the grill and see how much trimming I will need to do and find out if I can forget about the center brace if not I will build something....
GO GO!!!
Old 08-07-2020, 03:08 AM   #1017
Richard
Care to share about the AC condenser? Can PM me.
Richard
Old 08-08-2020, 12:18 PM   #1018
First c10
First c10's Avatar
Oh sorry I forgot to get you the info.
The coil I received from old air products was 12x26 which equals 312 square inches. The one I ordered was 14x23 which equals 322 square inches.
This is what I ordered 100% aluminum
https://www.ebay.com/itm/184176408501
I will have to make some custom aluminum hard lines to get around the radiator and core support.
GO GO!!!
Old 08-13-2020, 12:23 PM   #1019
First c10
First c10's Avatar
Hey all, I able to install some inner cooler plumbing through the radiator support.
I am waiting on a new Mass Air Flow sensor and the weld on Bung for it.
I still have to install the Blow Off Valve, you can see the little black circle where I am going to install it.
I am not sure I like the intake tube and filter but I will work on it after I get it running on the Supercharger and the grill back on.
GO GO!!!
Old 08-15-2020, 02:49 AM   #1020
Richard
Thanks. Was looking at the ebay condensers myself. Want to get as large as I can fit for the 134a conversion.
Richard
Old 08-17-2020, 01:57 PM   #1021
TA_C10
TA_C10's Avatar
Very nice, that looks awesome.
"It's only money".
Old 09-03-2020, 05:14 PM   #1022
First c10
First c10's Avatar
Hey guys I had to order the Holley throttle body adapter or wedge adapter to lower the upwards angle of the throttle body. You can see the black wedge adapter and how it lowers the angle of the throttle body from one of the previous pictures I posted.
I was able to finish the intake tubing with the new MAF installed.
I am still waiting on a few AC fittings for the condenser I relocated.
Now its time to tune!!!
GO GO!!!
Old 09-05-2020, 02:51 AM   #1023
Richard
Curious about the filler piece above the frame rails in front of the core support. Looking back through the thread I did not see any mention of it. Is this a stock 67-68 part or is it custom?
Richard
Old 09-05-2020, 12:08 PM   #1024
First c10
First c10's Avatar
Richard are you talking about the black powder coated metal piece under the inner cooler? yes that is stock 67-68. I had it powder coated years ago. It just bolts to the core support.
GO GO!!!
Old 09-07-2020, 02:20 AM   #1025
Richard
Thanks for the response. Never seen it before, but then again I have not really worked on a 67 or 68. Wonder if it could be fitted to the newer models with a little bit of fab?
Richard
