Old 07-27-2017, 10:51 PM   #1026
88lowrider
Re: Tbi swap build thread
I don't have the answers but stumbled onto this thread and like what I see.
I have my Dads old 1979 Chev 4x4 pickup that has less than 48K on it.
I was thinking of pulling the top off the engine and going with a early EFI with the first generation computer ( like my 1988 GMC full size lowrider that gets 19.8mpg).
The game plan is to find a Donner and switch it over to the EFI. Now I know the fuel tank will need to be swapped too. Tanks look the same between my 79 and 88 so might just luck out.
Right now, still in the process of replacing about Everything around my 88 lowrider engine that is at 170k crate motor and fresh build on the transmission at less than 6K. The fellow that did the transmission also uses that transmission for racing so I got a good build on it.
So, will be watching and learning.
Helmar
88lowrider is offline   Reply With Quote
Old 07-28-2017, 12:41 PM   #1027
daddyjeep
daddyjeep's Avatar
I will post in this one so I have it for future reference. I am putting a TBI 350 in my Jeep some time soon.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 07-28-2017, 01:08 PM   #1028
rfmaster
rfmaster's Avatar
Wwes
I have to look up FP sending unit wiring. Usually it is a three wire configuration: FP +12, Common ground, fuel level. Fuel level is a resistance 0 to 90 Ohms.
According to Pollack Data sheet 42-159 fuel tank switch can handle OE pump pressures 65 PSI deadheaded. Should be just fine for TBI/TPI rated pumps.
http://products.pollakaftermarket.co...n-valve/42-159
Check supplied diagram for dual tank operation
http://products.pollakaftermarket.co...S_41-revdd.pdf
Factory wiring at the FP sending unit.
Tan-white - FP +12Vdc, circuit #120
Pink - fuel gauge, circuit #30
Black - Ground return, Circuit #150
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 07-28-2017, 01:42 PM   #1029
Wwes
Big help, thanks sir!
Where could I get the connectors for the wire harnesses, or should I just splice/build my own?
(I'm new to wiring and such this will be an experience)
Wwes is offline   Reply With Quote
Old 07-28-2017, 02:22 PM   #1030
rfmaster
rfmaster's Avatar
Well, it all depends how involved do you want to get with making your harness robust. In my case I can assemble weather pack connector from scratch. If you go this far use brand new Delphi connector bodies, wire insulators and pins. Assembly requires having a correct crimping tool. Purchasing a weather pack kit goes a long way. If you do not have access to connector bodies and crimping tool you can source a pig tail from JY. However, be aware that plastic gets brittle over years and pin fitment leads to corrosion. If you live in rust belt area these plugs are exposed to corrosive salt mix over years of service. IMHO not worth it.
It does not look like Pico offers a brand new service pigtails for this circuit. I would double check FP plug against catalog drawing to verify P/N.
Fuel tank plug body 12020829 - 3-way, female
Harness side Socket body 12020827 - 3-way, Male
Connector Pins
OEM# | Description | AWG Gauge
12124581 | tin brass, female | 12
12124580 | tin brass, female | 16 -14
12089188 | tin brass, female | 20 -18
12020801 | tin brass, female | 24 -22
12124587 | tin brass, male | 12
12124582 | tin brass, male |16 - 14
12089040 | tin brass, male | 20 -18
12089307 | tin brass, male | 24 - 22
//RF
"The Beast"
Old 08-04-2017, 02:00 PM   #1031
rfmaster
rfmaster's Avatar
So what is the status on your project???
//RF
"The Beast"
Old 08-06-2017, 10:33 PM   #1032
Wwes
Hey RF I didn't forget you! Been on vacation for the last week so I'll work on it again next weekend. Expect an update/pictures then. Still not sure on how I'll handle the wiring, there aren't any squares around here to pick parts from!
Old 08-07-2017, 02:08 AM   #1033
rfmaster
rfmaster's Avatar
Ahhh - I can use a vacation as well, but work keeps me busy. What else is new!
If push comes to shove 1988-1990 B-bodies can a source (Caprice Classic equipped with LO3 or LO5) for some of the EFI related parts.
"The Beast"
Old 08-14-2017, 07:33 PM   #1034
cjracing15
cjracing15's Avatar
Glad to see this thread is still up and helping folks out!
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 08-15-2017, 11:01 AM   #1035
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
This is a great thread. I used it for reference several times when doing the install in my 74.
Old 08-15-2017, 10:15 PM   #1036
Wwes
Looks great Kevin, nice and clean. Stick around I'll have more questions I'm sure!
Old 09-13-2017, 09:48 PM   #1037
Wwes
Hey RF - I am making progress again.
I have a full fuel harness from a donor truck. I'm going to tackle that this weekend so I'll have another question then, but first...
Do I need to replace the fuel selector switch with a 87 one?
Old 07-22-2020, 11:38 PM   #1038
Rookiebuilder
It's been a few years on this particular reply so we'll see if I get a reply
I'm working on a '67 C10 small window, short bed, fleet side truck. I dropped '93 5.7 TBI w/ 4l80e that came from a G3500 Vandura (it was free). The engine and tranny have been rebuilt to stock specs. I also have the fuse block, bulkhead connector, wiring harness and VSS buffer from the van and am using them. The only thing I using from the ’67 C10 is the original i/p cluster connector (12 pins).
Now I'm stuck and looking for some wiring help specific to my '67 Instrument Panel (I/P) Cluster Connector (12 pins) (the '93 I/P Cluster has 18 pins). The guy I bought the truck from already converted the I/P cluster connector to a gauge cluster when he has his Stroker 383 in it.
I do have the '93 electrical diagram and diagnosis manual (It's great) but the main problem I’m getting confused on is i/p cluster is NOT 12 pins (it’s 18) so it throws me all off. I’m stuck now wondering I shouldn’t have changed the fuse block and bulkhead connector.
I was told I should get a standalone harness to run the engine and tranny so I’m looking at doing that real soon; however, that does not fix my problem of figuring out where or how to wire some of the other wires. I have follow the wiring diagram for a V8 that’s floating around on the forum but I’m still not sure with the following wires go FROM the i/p cluster connector to the different parts (ie., Fuse Block, Engine, Ignition etc). Again, I have seen the 67-72 wiring diagrams but they don’t’ seem go to the same locations on my fuse block and I’m wondering if that’s because it’s a TBI.
• Temperature Gauge (20 Dark Green)
• Fuel Gauge (20 Tan)
• Fuel Gauge Fee (20 Pink)
• Brake Warning Lmp (20 Tan)
• Alternator (Black/Brwn)
• Terminal by Battery
I feel like if there was an adapter from a 12 pin to an 18 pin i/p cluster connector (and a few gauges changes to mechanical to electrical) I’d be in a lot better place. I’m sorry for rambling and I’d appreciate any help you might be able to provide. After all, there's a reason my login is Rookiebuilder.
Thanks for any insight anyone can provide.
Eric
Rookiebuilder is offline   Reply With Quote
Old 07-23-2020, 03:09 PM   #1039
44th Miss Inf
I’ll try to dig out my folder and add to this if interested. I repinned an 87, added wires, and used a 94-95 computer and added a 4L80 to a buddies truck.
44th Miss Inf is offline   Reply With Quote
Old 07-23-2020, 03:42 PM   #1040
Rookiebuilder
Thumbs up Re: Tbi swap build thread
Please do!!!!! I'll take any and all information from you. I'm at a standstill until I figure this out. I appreciate it
