02-07-2021, 05:21 AM | #1076 |
Re: TA_C10: Stage 1
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
03-27-2021, 05:43 PM | #1077 |
Re: TA_C10: Stage 1
It's been a while, out of town for few months, but wife told me to go for it. Happy birthday to me. I can't wait to get this installed. Oh, and while Ive been gone my plates showed up, it's legal after 2.5 years. Boom.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-27-2021, 06:12 PM | #1078 |
Re: TA_C10: Stage 1
Nice, good to see you getting back at it!
03-29-2021, 09:27 AM | #1079 |
Re: TA_C10: Stage 1
That's an upgrade that I've got on my wish list. Should make for some more "spirited" driving.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
03-30-2021, 08:07 AM | #1080 |
Re: TA_C10: Stage 1
Interested in how this performs. I have a stock posi in my 72 Blazer and have never had one before. My 2014 has a G80 locker with 3.42 gears and is a blast to drive. I know the G80 is a ticking bomb but for now is fun. This may be in my Christmas wish list.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-21-2021, 11:46 AM | #1081 |
Re: TA_C10: Stage 1
05-21-2021, 03:37 PM | #1082 |
Re: TA_C10: Stage 1
2qty thumbs
05-21-2021, 07:07 PM | #1083 |
Re: TA_C10: Stage 1
That's nice.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
05-22-2021, 12:55 AM | #1084 |
Re: TA_C10: Stage 1
Sweet plates brother. Did you get the Detroit locker installed yet? I can't wait to get a ride in this truck!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-22-2021, 01:11 AM | #1085 |
Re: TA_C10: Stage 1
Looks awesome!
05-23-2021, 03:22 PM | #1086 | |
Re: TA_C10: Stage 1
05-28-2021, 12:23 AM | #1087 |
Re: TA_C10: Stage 1
Awesome update. Have you been driving it much?
05-28-2021, 12:32 AM | #1088 |
Re: TA_C10: Stage 1
I drive it all the time now. I can't help it...
05-28-2021, 12:57 AM | #1089 |
Re: TA_C10: Stage 1
Right on! These trucks deserve to be driven!
05-31-2021, 01:55 PM | #1090 |
Re: TA_C10: Stage 1
So I've drove the truck in rain couple times now. And rust starting to come through inside cowl. I was not able to get in there good enough with wire wheel and get it cleaned out obviously. This was 2 years ago and didn't know what I was doing. I have no idea what I can do to fix this without starting over, getting in there cleaning it out then repainting.... Any ideas? Do I even worry about it since it's in the cowl? Will it last 5-7 years?
05-31-2021, 02:11 PM | #1091 |
Re: TA_C10: Stage 1
Decided to finish paint, front half of truck was different shade due to me learning the painting process(too high PSI). Bed color is what I am matching. Bed done at 12 PSI. Front half was various PSI on different panels and also a mix of gun speed trying to figure it out. Yeah.... I know....
Scuffed and almost ready for paint.
05-31-2021, 06:16 PM | #1092 |
Re: TA_C10: Stage 1
Not good painting weather. Humidity this high will cause a possible 'splotchy' appearance.
06-01-2021, 04:23 PM | #1093 |
Re: TA_C10: Stage 1
Yeah I gave up. Too much rain...
06-03-2021, 11:43 AM | #1094 |
Re: TA_C10: Stage 1
I, like you, learned the hard way spraying. I painted my dad's 64 a blue metallic and I have the same matching issue between panels. He doesn't seem to mind, but it bothers me. Someday I want to reshoot it...
As far as the cowl goes, I wouldn't lose too much sleep over it. What I would do is scuff it and brush on some Chassis Saver (can go over rust) to lock down the rust. The ideal process would be to strip it of the paint and rust and go over with epoxy primer, but that's more involved than the first option. Glad you've been driving it!
06-04-2021, 06:41 PM | #1095 | |
Re: TA_C10: Stage 1
06-04-2021, 06:42 PM | #1096 |
Re: TA_C10: Stage 1
06-04-2021, 08:00 PM | #1097 |
Re: TA_C10: Stage 1
From my limited experience & what I learned in school... Your panels should always be 'set-up' for applying color coat the same way they would be positioned on the vehicle; especially w/metallics or a pearl color.
06-05-2021, 02:10 AM | #1098 |
Re: TA_C10: Stage 1
Yeah I've read that several times from different sources, but then I watch these power nation shows and other shows and you see them spraying hoods like I have mine hung. Metallics. Of course they are in a controlled booth and they do this for a living LoL. So my plan is to final sand my hood, paint the underneath side with color. Then install it back on truck and paint the truck put together.
06-05-2021, 02:47 AM | #1099 | |
Re: TA_C10: Stage 1
Equipment, skill, & experience make things fair much better when having to make choices to ensure quality results.
06-13-2021, 06:24 AM | #1100 |
Re: TA_C10: Stage 1
Ready for paint! I need to finish hood to 600 grit tomorrow, already painted underneath. Install the hood, wipe her clean and start spraying.
