07-12-2020, 08:16 AM | #1076 |
Post Whore
Re: A '54 named Busty
Decisions, decisions, decisions, so I am on the fence guys on weather or not to group/cluster all my fuses into a single location the one seen in the photos on the firewall (including tail lights, stop lights, etc.) or have two sets of fuses with the ones on the firewall being only for engine operation and a separate block for non engine ones?
I am sorta leaning towards two separate fuse blocks, both small and simple yet separate. The second one would be under the dash somewheres for the lights and gauges what not. |
07-12-2020, 08:20 AM | #1077 |
I have been laying out wire routes on paper to see what gives the cleanest appearance. I looked for locations for the relay box so as to minimize the visible wires.
So what are you looking to do? Simplest wiring, hidden wiring, something else? You've done a good job so far, I'm sure with a little more thought you'll nail it.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
07-12-2020, 08:25 AM | #1078 | |
Post Whore
the other reason would be that I heard you want the fuses closest to the components so no reason to run 3 feet of wire from the brake pedal to the passenger side fuse block only to run it back to the driver side |
07-12-2020, 01:57 PM | #1079 |
I vote for two blocks.
I’m set up with the factory fuses for all peripheral operations and a separate fuse block for the headlights, fan, etc. longest run for that block is the fuel pump. I’ll be adding a third block for engine control in the future as I switch from carb to efi.
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
07-13-2020, 09:25 AM | #1080 |
Post Whore
I'm not being a cry baby, I'm not, I'm not, I'm not, but go into your local parts store and pic up some pink primary wire for key on power, some purple wire for the fuel sending unit, and some orange wire for constant on power. You can't even find those, let alone all the other quality parts we once could get for our rigs.
I like to run proper color matching wire so that when I have to troubleshoot something I can. I once worked on a custom Chopper motorcycle where the knucklehead (the owner not the engine, ha ha) wired the entire bike, head to toe with a single gauge RED wire, yes for both plus an negative as well, then brought it to my buddy's cycle shop for help cause he had electrical issues!!! imagine that |
07-13-2020, 12:58 PM | #1081 |
Using two separate fuse blocks is "Semi-Pro" right there.
07-13-2020, 03:19 PM | #1082 | |
That dude nailed the faster, cheaper, better trifecta!
07-13-2020, 03:20 PM | #1083 |
So what does using three or more get me??
07-13-2020, 03:29 PM | #1084 |
07-13-2020, 04:31 PM | #1085 |
I used to work car stereo and guys would come in and order spools of primary wire all the time, any color. I just added them to my weekly order and they saved shipping, I marked up 20% for retail sale.
I havent worked car stereo for years (and years and years) but when I need primary wire I just stop in the shop I used to work and do the same.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-13-2020, 10:20 PM | #1086 |
Well shucks I was hoping for something like Wiring Wizard Grand Master Level III.
07-15-2020, 04:11 PM | #1087 |
Post Whore
killing it!
07-15-2020, 04:13 PM | #1088 |
Post Whore
fuse blocking like a Boss
07-15-2020, 04:17 PM | #1089 |
07-15-2020, 04:19 PM | #1090 |
Post Whore
so a quick list of nonsense to get her fired up Tanight!
07-15-2020, 04:38 PM | #1091 | |
It didn't happen unless you post a video of Busty running. I can't wait!! |
07-15-2020, 05:44 PM | #1092 |
I like how you videoed your fuse box build and put it on YouTube so the rest of us can see how to do it. How do we find it. I was doing something almost as tedious today, but you'll have to read about that later.
Hope Busty started tonight!
07-15-2020, 09:45 PM | #1093 |
Post Whore
07-15-2020, 10:01 PM | #1094 |
Very impressive.
07-16-2020, 12:36 AM | #1095 |
Post Whore
at least the General had the common sense to make the Throttle Position Sensor plug have the exact same style pins as the PCM and for that we praise the lord
yes we took pictures but as you can see sometimes there are two wires of the same color in two different spots so we numbertized them 1 through 16 for extra sureness |
07-16-2020, 12:37 AM | #1096 |
Post Whore
we was not so lucky when it came to the three prong OEM sending unit proprietary plug so we ditched it and will run a standard weather pack one instead
yes the OEM one was a three pronger but since we only own single and double weather packers we will use a double and just run the ground to the chassis separate, not gonna do a home run on the ground wire, and of course regret it later, ha ha Last edited by Gregski; 07-20-2020 at 03:52 PM. |
07-16-2020, 12:42 AM | #1097 |
Post Whore
here's a sight you don't see every day
I used my bench harness to read the PCM and save, save, save the original Tune and called it 00 - Stock Tune then I immediately saved it again with a new name called 01- VATS Disabled and as you can infer simply disabled the Vehicle Anti Theft System (pronounced: add 20 seconds to the time it takes a pro thief to [ahem] borrow your truck) |
07-16-2020, 12:44 AM | #1098 |
Post Whore
~ INTERMISSION ~
go get a cold one while the owner calmly looks for his truck keys... |
07-16-2020, 01:07 AM | #1099 |
Post Whore
so we did it here is the first start, well sort of, I did fire it up before reaching for the camera, and then had a couple failed filming attempts with me just being clumsy and tired
didn't want to run her too long since I don't have the stock oil pressure sending unit wired up to that awesome Insight CTS 2 digital multi gauge, I bought two wrong pig tails for it and apparently GM changed the plug somewhere between 2001 and 2004 apologies for the video being really dark, but you know how it is when projects get done late at night 54 Chevy Truck - LS Swap First Start |
07-16-2020, 07:01 AM | #1100 |
Awesome!!!!!
