#1101 |
Re: What did you do to your truck today.The 3rd chapter
Got the Broski's truck fired up this weekend, found a few leaks and had to pull off the intake manifold to reseal the rear. At least we caught it now so it wasn't too bad.
After getting that done we set the timing and she fired up great. I gotta say I'm impressed by how easy this newer EFI stuff is making it. I posted a video of the kid starting his truck up over on my Instagram. Here's a quick link: https://www.instagram.com/p/B9PILuPJKXw/ ![]()
1969 K10 LWB - 383/SM465/T221/4.56 - 8" of lift and 40" tires - the broski's truck aka JackdTruck 1974 C30 Crew Cab Dually - No Eng/No Trans/Bagged sometime in the 1990s and will be worked on sometime in the 2020s ... And a whole gaggle of other projects. Check out what I'm up to on Instagram: @zohmbii |
#1102 |
I spent most of the day removing my steering arm , gotter Done but boy what
a. PITA |
#1103 |
![]() Join Date: Nov 2015
Thanks, I will look for one like that. Or perhaps I could make one by heating an old cheap wrench with a torch and bending it .
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
#1104 |
Did the front half of my headliner on the 77. Really dont want to do the back it was a pain in the butt. Think if they didn't use foam it would still be up there . Foam failed not the glue
#1105 |
Black stuff is what's left of the foam
#1106 |
Close up of the snake bite pattern
#1107 | ||
I made two of them with ratchet type head one for loosing and one for tightening. Easy to do just heat it up and bend the crap put of it
#1108 |
Old member
I got the stacks hooked up this morning and painted the bed sides this afternoon!
After & before. ![]() https://www.youtube.com/watch?v=h-3YgxE12T0
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#1109 |
Great idea! thanks, I will have to make 1 each
#1110 |
![]() Join Date: Feb 2019
Vent window seals, and window channels.
Also working on a couple of Ford Phaetons, 1934 and a 1935..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA Last edited by Astro-Balls; 03-11-2020 at 11:33 PM. |
#1111 | |
Worked in a restoration shop on long island . I have polaroids of it but I believe this is the one since it's one of one 1929 Bentley made for the Paris auto show . The car had been cut up during WWII and was used as a tanker on an RAF airfield . Owner was adamant about leaving the holes in the frame from it being strafed by the luftwaffe. I did the aluminium came as a rough piece I shaped it sanded it to a mirror shine . Took 6 weeks my arms were shot. This was in 1978 .
#1112 |
Had the day off work, so I took the opportunity to weld up the new inner rocker,kick panel and outer rocker .
#1113 |
Old member
Welded in a lockable tool box into the bed side of the ramp truck. Going to paint it to match the bed better.
#1114 |
![]() Join Date: Feb 2011
Replaced the old, leaky master cylinder cap on my '98.....hoping to give the '72 some attention soon
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1115 |
![]() Join Date: Mar 2005
Got my new crate motor dyno'd today. 249/329 at the rear wheels. Not to bad for a mild cam'd 350
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#1116 |
Got the drivers side step for the bed in rust remover to get it clean for priming. Hope to get both sides in epoxy primer by end of weekend. Pulled vent door from passenger side and vacuumed out at least 5 pounds of leaves and junk. Still needs more work but gonna pull drivers side as well.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#1117 |
I will be going to get it from the alignment shop. Hopefully its better.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
#1118 |
![]() Join Date: Aug 2015
Started routing out the cracks in my 67's new steering wheel in preparation for epoxy. It is going to look at lot worse before it looks better.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
#1119 |
![]() Join Date: Aug 2016
Stripped the door panels out. Two tiny holes. Think I may have one of the best sets of doors around. I was stoked about not needing to reskin or patch the shell extensively. Installed the 4in rear drop springs and track bar. Working on spindles today.
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
#1120 |
I get my bedwood finished this week. It looks a little better then the old one
#1121 |
![]() Join Date: Mar 2011
very nice.......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#1122 |
Closer to making it cool. Just hoses left to install.
#1123 |
Repaired bad section in my intermediate wiring harness. Confirmed the tail lights and back up lights would now work (if installed). Will work on stop and turn signal next. Got tired after a day of moving furniture.
Just working on some small stuff while being socially distant. Going to try to get my bed steps fully stripped and in epoxy primer as well.
#1124 |
Finally got around to putting the sound deadener and new carpet. Next weekend will reupholster the bench and then I’m good to get her back on the road. It’s been six weeks since I’ve driven her and I’m going through withdrawals.
#1125 |
Oooppss. Sorry they are sideways
