Old 02-24-2011, 08:31 PM   #1126
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: 1967 C10 Custom Big Window
Alrighty then, on to the progress pics. I ordered some Hedman Hedders part #68608, they are the mid-length 1967 Camaro/Chevelle headers. Summit had them for the least coin. $333 shipped.
Name:  SAM_0817 (800x600).jpg
I test fitted the passenger side first and they fit perfect and luckily the trans lines that I bent a few months ago turned out to be perfect also, guess I got lucky again.
Name:  SAM_0820 (800x600).jpg
Name:  SAM_0821 (800x600).jpg
I didn't get so lucky on the driver side. There is a post that is floating around out there that says these fit perfect on both sides with no mods, that is not really true. You can see the header is high toward the back of the block because it is hitting the motor mount bracket. Pay no attention to the dust and bondo sanding mess that is everywhere, we are still sanding the 39.
Name:  SAM_0822 (800x600).jpg
Name:  SAM_0823 (800x600).jpg
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-24-2011, 08:38 PM   #1127
Slick67
Sofa King Crazy!!
Slick67's Avatar
Aggravated, I pulled out the trusty grinder and started throwin sparks. I know it looks like messy grinding.....because it was! I had to cover everything in cardboard which made it difficult to get to.
Name:  SAM_0825 (800x600).jpg
After taking out about half an inch or so, the header dropped into posistion leaving about 1/16th of an inch clearance......good enough for government work!! Promise the next pics will be of a cleaner engine bay!!!
Name:  SAM_0827 (800x600).jpg
Old 02-24-2011, 09:07 PM   #1128
Jeffs70
Jeffs70's Avatar
the Headers look great, sorry to hear about the fitting problems.
I was planning on getting this same set of headers. I wonder if it would be smart for me to mod my mount tower and flush it out on the top rather then have that hump sitting out there that much where you had to grind
Jeffs70 is offline   Reply With Quote
Old 02-24-2011, 09:18 PM   #1129
Slick67
Sofa King Crazy!!
Slick67's Avatar
Sounds like your idea would work well and be a cleaner install. These headers look really good and fit great once you get past the motor mount, I would recommend them if you don't mind a little modification.
Old 02-24-2011, 09:22 PM   #1130
VA72C10
VA72C10
VA72C10's Avatar
looks good...even though it's sooooooo dirty
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-24-2011, 09:37 PM   #1131
Slick67
Sofa King Crazy!!
Slick67's Avatar
I am ashamed.
Old 02-24-2011, 10:17 PM   #1132
67chevy1series
67chevy1series's Avatar
slick it looks awsome! i dont care my engine bay is dusty to great work and now paint that mount!
67chevy1series is offline   Reply With Quote
Old 02-25-2011, 12:03 AM   #1133
Slick67
Sofa King Crazy!!
Slick67's Avatar
It's painted, at least I wiped it with alcohol before I did it. Rubbing alcohol.....not the good stuff.
Old 02-25-2011, 12:09 AM   #1134
67chevy1series
slick thats funny! nice job man seriously.
Old 02-25-2011, 12:11 AM   #1135
David67
David67's Avatar
wow those look slick! basketball seasons over so i have time to actually work on my truck now. counting down the days till April 2nd!
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 02-25-2011, 12:19 AM   #1136
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks David, it'll be good to see some more progress on your truck it's super clean. April is creepin up quick and I am hoping to have mine almost complete.
Old 02-25-2011, 12:54 PM   #1137
68 Quad C10
68 Quad C10's Avatar
that looks great...... love this truck very clean....
http://www.tandscustomcars.com/
My Quad Cab build:http://67-72chevytrucks.com/vboard/s...d.php?t=352342
IT"S GOT A ROOF NOW WHOO HOO!!!!
65 GTO Build (If you wanna check it out) http://67-72chevytrucks.com/vboard/s...40#post4503040
68 Quad C10 is offline   Reply With Quote
Old 02-25-2011, 07:34 PM   #1138
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Bro! Tryin to stay focused!! I'll have some more update pics tomorrow.
Old 02-27-2011, 10:28 PM   #1139
Slick67
Sofa King Crazy!!
Slick67's Avatar
Another small update. I got the HEI wired permanently, installed my one-wire alternator and played musical belts till I got the perfect one. Also, got some spark-plug wire looms installed and covered alot of the wires under the hood. The first pic shows the aircleaner that is under my custom cover. I will be building my new spark plug wires tomorrow, so more pics!!!
Old 02-27-2011, 11:06 PM   #1140
VA72C10
VA72C10
VA72C10's Avatar
very nice! Looking sharp!
Old 02-28-2011, 12:20 AM   #1141
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Dude! I am not too sure about those billet wire looms, but I guess it's better than nothin.
Old 02-28-2011, 12:47 AM   #1142
67chevy1series
those billet wire looms dont look like they are doing anything but other than that truck looks awsome
Old 02-28-2011, 01:40 AM   #1143
VA72C10
VA72C10
VA72C10's Avatar
THey'll be doing something when he runs the new spark plug wires through them
Old 02-28-2011, 01:43 AM   #1144
67chevy1series
OOOOOOOOOHHHHHHH isee how they help now thanks for the LIGHT BULB haha
Old 02-28-2011, 02:47 AM   #1145
Jeffs70
Jeffs70's Avatar
looks great. I was thinking on the idea of these billet type wire looms and also had an after thought maybe even using the style of wires and connectors the old corvette's used to use and wrap the wires from behind the motor and from under the headers. just an idea if you dont like the looms.
Old 02-28-2011, 12:07 PM   #1146
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks for clarifying that for me VA! I bought Street Fire 8.8mm wires to run permanently about a year ago and now it's time to take these cheap grey ones off and put my nice black ones on. Got to build em first.
Thanks Jeff, I have seen those vette looms and they do look great. Maybe after I run my wires through these looms they will grow on me. After lookin at em yesterday I like them more.
Old 02-28-2011, 02:10 PM   #1147
72SWBChevy
72SWBChevy's Avatar
Engine bay is looking sweeeet!! Cant wait to see it.
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 02-28-2011, 07:45 PM   #1148
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks! Niftee 50ees is coming in a few weeks so I am trying to have the exhaust done this week and hopefully the interior partially done in the next couple of weeks.
Old 02-28-2011, 09:13 PM   #1149
Slick67
Sofa King Crazy!!
Slick67's Avatar
Got the new wires temporarily put in so I can measure them to the distributor then make my cuts. After wiring them through the new wirelooms I think they look great and they are staying on the truck. Spark plug #6 has to be ran differently than the others because it is too close to the headers. But the short dipstick tube worked out great.
Old 02-28-2011, 11:08 PM   #1150
67chevy1series
i like those.....only i dont want any chrome on mine so i would need to paint them orange or black
1967, custom, lwb
