Old 07-07-2012, 11:22 PM   #1151
candyx
candyx's Avatar
Re: Kabwe's aka Bam's build
Kabwe
Whats your take on hood rockets on trucks?????
candyx is offline   Reply With Quote
Old 07-09-2012, 12:17 PM   #1152
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by candyx View Post
Kabwe
I'm a little wired when it comes to ornaments, trim, and emblems, I don't care for them except on certain cars. On certain cars they are needed like the tri5 chevys especially the 56 belaire I love that trim but I can live without the hood emblems. Mine will be gone the next time I rebuild my car. I like the smooth look.
I like the 57 truck grill I know a lot of people don't but I do like it better than the 55-56, but I like the 55-56 hood better because of the smoothness of it. The 57 grill is different and very cool in my opinion.
That said it also depends on the theme of the truck. I've seen the rockets, visors, and the emblems installed on truck and I love the look because it fit the theme of the truck so perfectly.
Kabwe is offline   Reply With Quote
Old 07-09-2012, 07:31 PM   #1153
blue57
blue57's Avatar
Where are the pictures from the show??????
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 07-09-2012, 07:35 PM   #1154
Kabwe
Certified Car Nut
Kabwe's Avatar
The guys already posted a lot of the same pics I have here
http://67-72chevytrucks.com/vboard/s...d.php?t=532981
Old 07-11-2012, 09:58 AM   #1155
fat53chevy
It's lookin good bro! All that hard work will pay off big time! Can't wait to see it when she's done!
fat53chevy is offline   Reply With Quote
Old 07-11-2012, 06:24 PM   #1156
ashtray455
hey dude, hope all is well , had a ? when u did ur mustang ii my directions say measure from center of front shackle hole 20 7/8 back that should be center ? but i marked mine before i disembled it what i got was 21 7/8 ? do u remember what urs was ? thanks
ashtray455 is offline   Reply With Quote
Old 07-11-2012, 06:46 PM   #1157
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks man, I appreciate you taking the time to let me know you like the project.
I only used it as a guide line. Yeah my instructions said the same as yours, but I always just tacked the unit in, put the upper and lower a arms on, install the spindle, rotor, and wheels, and used a floor jack in the center of the cross member so that I could put the truck at ride height (the lower a arms parallel to the ground) and put a fender on to see how I liked it. I ended up moving it forward I forgot how much. I don't ever go by instructions alone, I believe mockup is everything.
Old 07-11-2012, 08:33 PM   #1158
ashtray455
I only used it as a guide line. Yeah my instructions said the same as yours, but I always just tacked the unit in, put the upper and lower a arms on, install the spindle, rotor, and wheels, and used a floor jack in the center of the cross member so that I could put the truck at ride height (the lower a arms parallel to the ground) and put a fender on to see how I liked it. I ended up moving it forward I forgot how much. I don't ever go buy instructions alone, I believe mockup is everything.
thanks not a bad idea
Old 07-11-2012, 10:14 PM   #1159
fat53chevy
What color or colors are we thinkin' for it? I think all black, black chrome wheels and air ride
Old 07-11-2012, 10:20 PM   #1160
blue57
blue57's Avatar
Exactly what i did as well. Used a piece of tubing and welded a bolt to the top of it and drilled the bottom out to run a bolt through it rather then using the coil spring. Easier on the ball joints until it goes together for good. Got mine tacked in and hardware hung then bolted in core support and hung a fender. Good to go then tore it back apart and welded in for good.
my build thread:
Old 07-12-2012, 06:29 AM   #1161
ashtray455
ok thanks alot ya still tring to gather all my parts and peieces then will be time to play thanks alot for all the info
Old 07-12-2012, 01:41 PM   #1162
Kabwe
Certified Car Nut
Kabwe's Avatar
ashtray455,
Notice what I'm using for springs and shocks during mockup.
Old 07-12-2012, 05:54 PM   #1163
Chevette
Chevette's Avatar
ashtray455,
I thought you were using "55" front fenders. You been hanging around with Ogre, haven't you?
Chevette is offline   Reply With Quote
Old 07-12-2012, 07:14 PM   #1164
Kabwe
Certified Car Nut
Kabwe's Avatar
I am using 55 front fenders that mock up was done before I got the 55 front clip. But I am starting to see some 58-59 I really like lately.lol But I have to have my twins.
Old 07-12-2012, 09:11 PM   #1165
ashtray455
ashtray455,
ok ya that looks good man u remember how long they were or a closer pic ,im going to have to do somthing like that when i get started havnt got any coilovers yet thanks
Old 07-12-2012, 09:49 PM   #1166
Kabwe
Certified Car Nut
Kabwe's Avatar
Once you tack everything in get you floor jack under the crossmember and jack it up until the a arms are parallel with the floor. then measure from the lower a-arms mounting holes to the top of the shock hat and cut your tubing. You can weld a bolt to the top of the tubing and drill a hole at the bottom of the tubing for mounting.
Old 07-12-2012, 09:54 PM   #1167
blue57
blue57's Avatar
what are yours plans for an e-brake?
my build thread:
Old 07-12-2012, 11:32 PM   #1168
Kabwe
Certified Car Nut
Kabwe's Avatar
I planned on using a foot e-brake from a 80's Chevy truck that I got off ebay for 30 bucks a while back. But I've been looking at those lokar units lately.lol
Old 07-13-2012, 01:12 AM   #1169
blue57
blue57's Avatar
I was just checking those out
my build thread:
Old 07-13-2012, 02:18 AM   #1170
VDOG
Grand PooBaa Member
VDOG's Avatar
There you go!
VDOG is offline   Reply With Quote
Old 07-13-2012, 07:55 PM   #1171
ashtray455
Once you tack everything in get you floor jack under the crossmember and jack it up until the a arms are parallel with the floor. then measure from the lower a-arms mounting holes to the top of the shock hat and cut your tubing. You can weld a bolt to the top of the tubing and drill a hole at the bottom of the tubing to mounting.
thanks
Old 07-14-2012, 09:49 AM   #1172
ZR2RICK
ZR2RICK's Avatar
Hey Kabwe, what radiator you planning on running with your LSX ?
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 07-14-2012, 12:14 PM   #1173
_Ogre
_Ogre's Avatar
we call that character building
I am using 55 front fenders that mock up was done before before I got the 55 front clip. But I am starting to see some 58-59 I really like lately.lol But I have to have my twins.
it does look wicked like that, no hood and no core support.
everyone builds 55-57 trucks, dare to be different and build a 4 eyed truck
shop air compressor timer
Old 07-14-2012, 12:32 PM   #1174
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey ZR2Rick,
Hows everything going? Man I don't quite know what rediator I'm going to run yet. I think I'm just going to buy an aluminum crossflow and make it work.
I never gave into peer pressure when I was a kid and the great thing about being adult is I find it easier not to listen to peer pressure. I have a 55 210 and when looking for a truck I was looking for a 55-56 to build a twin. The 55-57 trucks are my personal favorite and always will be. I've seen some really nice 58-59 but it still hasn't changed my opinion of which truck I like the best. I knew when I bought my truck it would have many mods and one happens to be 55-56 front clip. If I wanted a 58-59 I would have built one, case closed.
Old 07-17-2012, 09:30 AM   #1175
seanery
seanery's Avatar
Man, I just read all 47 pages of this thread! Great work, I like your style - both in cars and how you treat people! Keep it up, I can't wait to see you finish!
seanery is offline   Reply With Quote
