08-17-2021, 02:00 AM | #1176 |
Post Whore
Re: Facebook Marketplace finds
08-17-2021, 06:52 AM | #1177 |
WOW 80 grand, that has to be the highest price so far,
well done Wikid
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
08-17-2021, 10:22 AM | #1178 |
I had already looked at this one 25k new 6.0
https://www.facebook.com/marketplace...3A108%7D%22%7D
08-17-2021, 11:02 AM | #1179 | |
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
08-17-2021, 11:46 AM | #1180 |
Post Whore
08-17-2021, 11:47 AM | #1181 |
Post Whore
08-17-2021, 11:56 AM | #1182 |
Post Whore
08-17-2021, 12:12 PM | #1183 |
Post Whore
I have for sale my 1972 Chevy C20 Custom long box with a 350 and Turbo 400 Trans. Runs, drives, and stops great. It's a Montana truck, so very solid. It does have rust holes on both sides of the floor pan and on the bottom of the doors to be patched. It's a very good all original candidate for a restoration. Or just drive as is. $5,500, https://www.facebook.com/marketplace...b-9b6c0f3af2d5
08-17-2021, 02:06 PM | #1184 |
I love the look of that red truck above but I can't take the time to go thru rockers rust repairs again.
1971 C-10 307 3OTT |
08-17-2021, 02:44 PM | #1185 |
Post Whore
08-17-2021, 02:55 PM | #1186 |
Post Whore
1200. Non-runner. Long bed pick up. Been sitting a long time. She definitely got some rot. 307 with 3 speed on the column. Needs a flywheel to crank. Ran when parked. Repeat will not start. 1200 obo https://www.facebook.com/marketplace...b-32df313041d2
08-17-2021, 02:59 PM | #1187 |
Post Whore
Runs. Needs transmission. Has Disc brakes and power steering. Some work done. Heat works. All lights and gauges work. 305 board 30. Headed 2.2 valves. Eldebroke intake. Passed down generation to generation family owned. https://www.facebook.com/marketplace...b-32df313041d2
08-17-2021, 03:05 PM | #1188 |
Post Whore
1970 gmc 1500
Has the ac dash but the compressor is out of the truck. Also it will need a new plug for the heater to work. 350 engine and turbo 350 transmission Drum power brakes with new booster and master cylinder and some other brake parts. The truck runs and drives but hasn’t been drove in a couple months but fires right up. Does have the normal rust for these of trucks in the cab and has rust in the bed side on the inside and the bottom supports of the bed. 3,900 obo https://www.facebook.com/marketplace...b-32df313041d2 |
08-17-2021, 03:07 PM | #1189 |
Post Whore
Im selling my 1971 chevy C10 for 13,500
. Edelbrock carburetor . Edelbrock high rise . Flow master mufflers . Dz302 Cam . 202 double hump heads . New tires . New rotors .new dash pad .new alpine radio bt . New brakes . New calipers . New plug wires . K/N air filter . New flow master mufflers Only thing wrong with it is that the timing needs to be set Need to ask me any more questions call me https://www.facebook.com/marketplace...b-32df313041d2 |
08-17-2021, 03:09 PM | #1190 |
Post Whore
08-17-2021, 03:11 PM | #1191 |
Post Whore
I just got this truck don't know anything about it floor seem to be in pretty good shape motor does turn over has no wood left in the bottom of the bed play good for a patina rat rod truck would much rather sell but if you have to trade send me a picture of what you have will not respond to is this available will just block it https://www.facebook.com/marketplace...b-32df313041d2
08-17-2021, 03:19 PM | #1192 |
Post Whore
Another $80,000 tag. XXXX I OWNED THIS TRUCK SINCE 1973
STARTED REBUILD 1999 ONLY DRIVEN TO CAR SHOWS & CRUISINS - 112 TROPHIES ENGINE: Blue Print- GM 396 Dyno tested 514 HP/510 ft lbs @6000 rpm Forged steel crank balanced rotating assembly Forged pistons and connecting rods w/hasting moly rings CYLINDER HEADS: Aluminum 10.4:1- swirl polished 2.08 int and 1.60 exh valves CAMSHAFT: Roller- lift .544 intake .555 exh. 230 int/236 exh duration TIMING SET: Heavy Duty Double roller Chain. INDUCTION: Edelbrock "endurashine" performer air gap dual quad manifold Edelbrock 500 cfm thunder series AVS carbs Spectre custom dual air ram induction EXHAUST: Hooker competition metallic ceramic headers with Doug's electric cut outs Custom 2.5 inch polished stainless steel mufflers and pipes COOLING: Heavy duty 4 core radiator. stainless steel 7 blade fan Stock AC system with Old Air pro 6 ten compressor and update kit TRANSMISSION: 700R4 overdrive Hi performance with 1700 stall converter Red lined band overhaul kit / 3/4 commercial pack. forward sprag late model TransGo full race shift kit. True cool trans cooler. Over rev pump kit Lockar floor shifter. Detroit 4:10 Locker differential SUSPENSION: Air Ride Technologies with 2" drop spindles and wheel level control modules Dual Viar 400c compressors, 5 gal tank, rear locator kits and shocks WHEELS: Pacer 16X8 polished aluminum TIRES: Michelin LTX M/X P225/70 R16 PAINT: 3 coats Matrix 9700 Black / 3 coats Matrix 85 clear. Red custom blend Prep and paint 418 hrs INTERIOR: Fabricated mountings for 1995 Dodge 1500 pickup seats Custom seat and console covering with red piping CUSTOM DESIGNS: 2000 fabricate marker light tunnels on front and rear panels Seal Cab exterior and interior seams. Recess radio antenna Install 1995 Cadillac tail light fabrication to blend with tailgate and fenders Create paint design on doors, bed and tailgate Redesign area for spare tire accessibility 2003 Install 1990 Chevrolet suburban quad headlights with custom mountings to fit a fabricated phantom billet aluminum grill 2014 Install Led-glow led lights in Grill, Engine, Cab, Bed, Wheel wells and chassis 2015 C Notch Frame 4" for rear axle clearance 2016 Redesign and fabricate Cab drip rail 2019 Install back-up lights on notched rear bumper Daphne, AL Location is approximate Seller Information Albert https://www.facebook.com/marketplace...b-32df313041d2 Joined Facebook in 2010 |
08-17-2021, 03:28 PM | #1193 |
Post Whore
08-17-2021, 03:31 PM | #1194 |
Post Whore
1971 C-10 Cheyenne pickup. One family owned since 1976. 350 2 barrel carb. Automatic transmission, Runs great, factory A/C Price is $22,000 https://www.facebook.com/marketplace...2-6691bb8f7618
08-17-2021, 03:53 PM | #1195 |
Post Whore
08-17-2021, 03:56 PM | #1196 |
Post Whore
69 c10 short/wide. 6 cyl/3 speed manual. Needs rockers. corners, door bottoms, kick panels and windshield. Yard drives. New brakes. Good Ky. title. A lot of new LMC parts included. Lost interest.....Not really interested in trades, but I'll listen. https://www.facebook.com/marketplace...3A123%7D%22%7D
08-17-2021, 04:03 PM | #1197 |
Post Whore
1968 c10 350 automatic longbed. It's not perfect but not rusted out either. Little rust under the doors. Needs some brake work to be a daily. It's a nice enough truck it could be restored or turned into a rat rod, or drive as is. No major leaks, windows need work to roll up and down. Brakes need work, haven't messed with the stereo but everything is there to get it working. No clue on actual mileage. Will consider fun trades Corvette, 350z, GTO, ect. Could include cash on my side for the right trade. https://www.facebook.com/marketplace...7-d53eba790860
08-17-2021, 04:06 PM | #1198 |
Post Whore
1/2 ton 4 x 4 pickup with hydraulic round bale unroller. 6,853 miles on 2nd pickup engine. Will carry two 800# bales. Selling as a unit. $6,000 OBO. https://www.facebook.com/marketplace...7-d53eba790860
08-17-2021, 04:09 PM | #1199 |
Post Whore
08-17-2021, 04:10 PM | #1200 | |
1971 SWB step side: Original NM Forestry and then NM Fire truck |
