03-12-2021, 08:50 PM | #1201 |
Re: What did you do to your truck today part IV
Today I re-installed my Ramhorns after having the machine shop guy true them up on some kind of a plane or whatever. He said they were pretty warped but they came out fine. I could tell they had been leaking exhaust for a while when I pulled them, and the gaskets were a crispy "well done". Now, after machining them, I don't need gaskets anymore and the truck is noticeably quieter.
In the past I have painted exhaust manifolds with Rustoleum cold galvanizing compound in a spray can and it doesn't burn off. (It will discolor, but stays put.) This time around I bought a new can and did it again. The stuff used to be more silvery and shiny than it is now which is flat gray. The cap on the can was reflective of that change as well. Here's hoping the new formula is as tough as the old.... |
03-20-2021, 07:05 PM | #1202 |
Finished wiring the gauge panel..
Pictures don’t want to upload????🤔🤔🤔🤔 |
03-20-2021, 08:04 PM | #1203 |
Finished wiring gauge panel...
03-21-2021, 01:24 AM | #1204 |
BLAZER THIRTY!!
Nothing today was raining all day didn't even drive it, but last week lowered it 4 Inches and built my own exhaust
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
03-21-2021, 02:02 AM | #1205 |
After bottoming-out got old quickly, swapped 4" drop springs with 3" drops.
Had started 4" drop non-BBC springs a few years, then added 2.5" CPP modular drop spindles recently. That combo, along with a heavy BBC, doesn't work well. The ride is relatively much better with the 3s. Relatively.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
03-24-2021, 08:36 AM | #1206 |
I got my Mar-K hidden tailgate latches and link assembly installed. I also changed out the Chevy bowtie for the Chevrolet script in my big truck grill.
03-24-2021, 09:52 PM | #1207 |
Took my 250 six cylinder to rebuilders today. Should get it back in a couple of weeks weeks. Started looking for a 700R4 transmission.
03-28-2021, 11:23 AM | #1208 |
Worked on the magnetic latch, a little fine tuning and it’s finished...
04-10-2021, 08:57 PM | #1209 |
Revitalizing a 6T C10
removed that rare two piece battery tray
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
04-11-2021, 12:07 AM | #1210 |
04-11-2021, 10:01 AM | #1211 |
Looks awesome! What did you use for the stain? what was your process? I want mine to be black like that as well!
04-11-2021, 10:36 AM | #1212 | |
The strips are plain steel and the bolts are the zinc kit from Classic Industries. The strips were marked Tri-Plus. They are painted Rustoleum satin black. |
04-11-2021, 10:39 AM | #1213 | |
My wife wants it to be stained so she can see the grain of the wood, but it is a truck that will be used...I use my truck as a truck also and it is my daily driver so this may be perfect...now how to break it to the wife! |
04-11-2021, 11:53 AM | #1214 |
1965 Chevy C10, 2005 4.8L/4l60
Body side molding done
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-12-2021, 04:44 PM | #1215 |
Guest
Posts: n/a
Swapped out the original old barn door slammers and replaced with gas struts! No more getting body slammed when the wind blows and the doors are open.
Super easy upgrade! Very pleased with this. |
04-13-2021, 06:53 AM | #1216 |
04-13-2021, 09:11 AM | #1217 |
I use rust oleum satin on oak reduced 50 percent on first coat so it soaked in and 20 percent on the next two you can still see the woodgrain
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
04-13-2021, 09:15 AM | #1218 |
very nice
I use rust oleum satin on oak reduced 50 percent on first coat so it soaked in and 20 percent on the next two you can still see the woodgrain Attachment 2095267[/quote] |
04-13-2021, 09:22 AM | #1219 | |
04-13-2021, 09:38 AM | #1220 |
Yes paint and reduce with mineral spirits reducing it let’s it soak into the wood so you get better protection I don’t know if it matters but I also sprayed it
04-13-2021, 03:25 PM | #1221 |
Guest
Posts: n/a
Installed emergency flasher circuit today, and adjusted the wiring coming out of the column so turn signals work properly now.
04-14-2021, 10:56 AM | #1222 |
Similar process as above with a gloss black paint (thinned way out). Did this five years ago, and it's held up great, though I don't carry much in the bed.
04-21-2021, 11:33 AM | #1223 |
Guest
Posts: n/a
Working to solve leaky exhaust issues that I inherited...the [studs] from manifold to exhaust were non-existant, the bolts used needed to be tightened daily, so that had to change. After installing studs, a compression plug that was in the hole for the flapper blew out, had to order that and pull the manifolds to drill out the hole and re-plug...manifolds needed to come of at some point anyway as there was also a leak on the forward exhaust port, so pulled the manifolds and found that the gasket was not breached at the exhaust port as I suspected. Turns out the intake manifold face stood above the exhaust manifold face by a fair amount. The bolts bonding the manifolds together were NOT coming out without a fight (that I did not want to lose), so I applied a little redneck machine shop skills and brought out the belt sander to even the faces out. Lots of steel dust later I had a fairly consistent face ready to reinstall.
This is all temporary as it's all going away in favor of a more modern setup as soon as I can get parts ordered. Finishing up the install after work today, hope to have her back on the road by dinner time. |
04-21-2021, 12:38 PM | #1224 |
My first post other than my intro! Drivers side is done, started fitting in the passenger side patches on the old girl...
04-21-2021, 09:01 PM | #1225 |
Installed a 1 1/16 sway bar out of a 1990 suburban 2wd on my 66 c10.
