Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 02-01-2006, 04:47 PM   #101
see ten
WTB this ad
see ten's Avatar
Re: Wheel/Tire Fitment Pictures & Info
Originally Posted by incoma
see ten - are your inner fenders out of that truck? I'm running a 2.5" front drop and it looks like my tires will hit the inner fenders if I go over a bump. I noticed that you said you had some rubbing when cutting corners, and didn't see any comments on the inner fenders, so I thought I'd ask.
Yep, she has inner fenders. the only place I have rubbed is on the control arms.
see ten is offline
Old 02-14-2006, 09:55 PM   #102
Radman
Here is my pick. I'm old school and still like lots of rubber and 15" rims. These are 285-70-15"s on 10" rims( no rubbing Issues) Frt's are 255-70-15's on 8" rims
Truck Has 3" drop spindles with 2 in drop springs. Rear has a 4" drop spring with a 2" spacer.
Better pics at www.classictruckworld.tenmagazines.com
Go to gallerys,then1968, mine is the BCHN-68 gallery.
Radman is offline
Old 02-15-2006, 12:19 PM   #103
cfleeks
I need help on finding a cowl hood and shaved tailgate for 72 chevy pickup
cfleeks is offline
Old 02-15-2006, 12:59 PM   #104
Zumo
Hot Rods For Life
Zumo's Avatar
Nice. I actaully like the size you have for the front for my rear wheels.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline
Old 02-18-2006, 05:54 PM   #105
diggertodd
diggertodd
diggertodd's Avatar
Kudos to Radman - the look you have achived is great - can you tell me what backspace you used for the front/back - thanks in advance
diggertodd is offline
Old 02-18-2006, 10:29 PM   #106
Radman
The rims and the cowl inducton hood were the first things i bought to start this project. The rims are american racings standard back spacing. It's been awhile but it is in the neigborhood of 4 or 4 1/4" back space frt and rear. What ever standard is from the company. the fronts should actually have about an extra 1/2" of back space as the tire just barely touches the inner wheel well on a hard bump. I have a frt.sway bar from a 86 suburban mounted up frt and the truck corners great.
thx for the great comments!
ttyl
Rick
Radman is offline
Old 02-19-2006, 02:15 AM   #107
SCOTI
SCOTI's Avatar
ttyl
Rick
AR Wheels typically have 3 5/8" BS standard (especially the torq thrusts).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 02-19-2006, 02:21 AM   #108
SCOTI
SCOTI's Avatar
I just read this thread . . ..... some good info to use before spending your hard earned $$.....
215/70-15 on 15x6.5" van ralleys w/a 2.5" spindle & 2.5" spring (cut stockers) on the front & 255/70-15 on 15x8" truck ralleys w/ air bags, 1.5" lowering blocks, adj panhard bar & relocated stock shock mounts out back.
Rubs up front on the top of the inner fenderwells on big dips/bumps in the road @ speed . . .... never a problem @ any other time.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 02-19-2006, 09:21 AM   #109
Radman
scoti; did you notch your frame and cut out your box floor to make it look this great?
Radman is offline
Old 02-19-2006, 11:24 AM   #110
SCOTI
SCOTI's Avatar
It's c-notched w/a bolt-in CPP notch (that's now been welded too) & the rear pumpkin clearanced the old, original-wood bed floor on an "as needed" basis .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 02-19-2006, 11:45 AM   #111
bagged74
its just $$$$$
bagged74's Avatar
3" spindle w/ cut springs(1 wrap), 5" drop springs in the rear.
20x8.5" Coys Rodder 5 wheels w/ 5" Backspacing (too much for the rear)
255/35 Falken tires.
second pic is same drop with 255-70s on 8" truck rallys
bagged74 is offline
Old 02-19-2006, 08:21 PM   #112
Radman
Bagged74: love the look of the ralleys over the billet jobs and rubber band tires. Sorry, I'm old school and love BIG rubber.
Bagged&scotti:
Notice how the rear tire moves forward in the wheel well when these trucks get this low. The frts always look so centered. I didn't like the rear look, so i am in the process of building new rear arms with a 15 degree angle on the rear arm to get the pinion angle right again. I also moved the rear axle mounting point on the arms back 1" to get the rear tire centered in the wheel well. I will have the new frt bushings here mon or tues and will post a pic when done.
Radman is offline
Old 02-20-2006, 12:45 AM   #113
SCOTI
SCOTI's Avatar
Bagged&scotti:
Please do.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 02-22-2006, 08:06 AM   #114
2-BAD-72
2-BAD-72's Avatar
Howdy evryone Im new here.
295/50 15 on 15 X 10 ralleys with 4" back spacingon all 4 corners with NO rubbing issues
lowered 2" up front and 3" in the back
http://67-72chevytrucks.com/vboard/a...1&d=1140609791
2-BAD-72 is offline
Old 02-23-2006, 12:51 PM   #115
lux hauler
Psycho-billy Member
lux hauler's Avatar
Anyone happen to have a picture of a lwb fleet with 2.5" front drop - 4" rear drop with 15x8 4" b.s. front and 15x10 5"b.s. rear?
I know it's a shot in the dark but.... I'm thinking thinking that I'd like to go that route with my '72.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline
Old 02-25-2006, 11:31 PM   #116
rkarr
rkarr's Avatar
295/45 20's... no rubbing issues----yet...
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline
Old 03-05-2006, 02:46 PM   #117
english
i have just purchased 71c10.can anyone advise me why when veiwing the truck the front the wheels are 1inch offset to the body on the left hand side.front and rear.Nothing seems wrong with the front clip or the rear axle.The truck drives straight and true.Could it be that the body cab and buck has been located wrongley or is this not possible.The wheel pcd measures at 5inches not 4.75.Any information will be apreciated.The truck is in England.Thanks.
english is offline
Old 03-06-2006, 04:09 AM   #118
jus_1982
jus_1982's Avatar
15x8 stock toyota wheels. unsure of tire size. freshly bought. will look sweet with a 2" front drop which is in the works. think i may stick with these toyota wheels as they look like a decent aftermarket wheel. what do you guys think? they fill the fenders well. may go with a taller tire to fill the fenders to my hearts content.
-justin-
70 chevy longbed: 350/th350 12 bolt project
jus_1982 is offline
Old 03-06-2006, 12:02 PM   #119
Jerry Jones
Happy Camper
Jerry Jones's Avatar
1st pic 71 Custom Camper 3/4 ton. Eagle Alloys with Bridgstone duelers @ P265/70R16's Stock suspension
2nd pick '68 1/2 ton with stock suspension, unknown wheel maker. Tires front 245/75R16 and rear LT235/85R16
RIP El Jay! Love you brother!
Jerry Jones is offline
Old 03-12-2006, 12:20 AM   #120
TooT
Active Member
TooT's Avatar
We put 295/50's on the back.....245/60's on the front. all on 15x8 ralleys. finally got them all matched up and put on!
TooT is offline
Old 03-12-2006, 12:26 AM   #121
TooT
Active Member
TooT's Avatar
15x7 chrome mod's on the 68
TooT is offline
Old 03-13-2006, 03:29 AM   #122
rigon4
rigon4's Avatar
is it true that you should c-notch the frame for 4 inch or bigger drop. going 4/5 with 20's on 1971 2wd blazer. if c-notch is not needed
rigon4 is offline
Old 03-13-2006, 11:07 AM   #123
72MARIO
72MARIO's Avatar
A few of us are running around with 6" and no notch. No problem here I have 2.5" of travel and it still rides nice.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline
Old 03-18-2006, 11:47 PM   #124
Bill Malanca
Here's my 69,ECE's 2 inch spindels w/ 4" spring, 6" springs out back. American Racing Torq-thrust 6's, 17x9.5 w/245/45 front and 265/50 rear on Fuzion tires . Backspacing is bout 5'' front and 3.5 at rear.
Bill Malanca is offline
Old 03-19-2006, 12:20 AM   #125
jay-dawg
chevelito
jay-dawg's Avatar
wow...6/6 drop.....can't wait till the pic shows up.
jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline
