Old 07-20-2007, 12:16 AM   #101
cstm68
cstm68's Avatar
Re: my 68 shortbed build
so i havent done too much to the truck lately but it should be getting another coat of primer to the interior this weekend and then paint for door jams
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 08-21-2007, 10:28 PM   #102
Lated
Lated's Avatar
Cstm, what are those seats out of?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 09-04-2007, 01:32 AM   #103
cstm68
cstm68's Avatar
i got them from summit
http://store.summitracing.com/partde...5&autoview=sku
i had to make my own brakets to lift the off the floor about 3 1/2 inches
Old 10-02-2007, 12:55 AM   #104
cstm68
cstm68's Avatar
not too much progress but the cab is ready for paint !!
also i picked up some 15/9 wheels and a couple sets of goodyear eagle drag slicks to burn off and play around with!!
ill get some pics soon
Old 11-13-2007, 08:29 PM   #105
cstm68
cstm68's Avatar
i bought a saginaw 4 speed for the truck today. it in great shape, just needs some cleaning up.
ill post some pics later tonight
any idea of what linkage will work with this trans in a 68 ?
Old 11-14-2007, 12:53 AM   #106
cstm68
cstm68's Avatar
heres the tranny
im gunna try to use this shifter.
Old 11-14-2007, 07:20 PM   #107
cstm68
cstm68's Avatar
ive also decided to shave the tail gate handle
anyone know of a good place to get the relocation kit?
Old 11-30-2007, 12:23 AM   #108
cstm68
cstm68's Avatar
so herd of an idea for uning seat belt latches on the inside of the bed as a tailgate latch for shaving the handle.
ill post pics when i get started on it
Old 12-05-2007, 09:25 PM   #109
cstm68
cstm68's Avatar
here is a littl bit of my new tailgate latches
i used a set of seatbelts from my parts truck
i need one more of the silver parts that go into the latch if any one has one, i was short one and had to make my own until i can find one
Old 12-05-2007, 10:05 PM   #110
cstm68
cstm68's Avatar
i also cut a peice out of a scrap tailgate from the parts truck to use as a filler pannel on the outside for shaving the handle
Old 12-06-2007, 12:55 PM   #111
BP68
BP68's Avatar
I got mine from Brothers. I have not got it installed yet, but it looks like a nice kit.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 12-06-2007, 03:43 PM   #112
cstm68
cstm68's Avatar
i was thinking about that kit but decided to make my own latches
Old 12-07-2007, 10:13 PM   #113
cstm68
cstm68's Avatar
so i got the latches on today and that work great!!! just need some fine tuning. also i got my filler piece welded in on the tailgate.
let me know what you think
heres some pics
Old 12-07-2007, 10:19 PM   #114
cstm68
cstm68's Avatar
one more
Old 12-07-2007, 11:29 PM   #115
cstm68
cstm68's Avatar
any feedback???
Old 12-08-2007, 11:11 AM   #116
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good keep up the work!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-08-2007, 11:30 AM   #117
cstm68
cstm68's Avatar
thanx
Old 12-23-2007, 09:05 PM   #118
cstm68
cstm68's Avatar
so i pulled my old 3 speed out and hope to be puting the 4 speed in
in the next week or two !!!
Old 01-01-2008, 07:15 PM   #119
cstm68
cstm68's Avatar
so i got the input bearing retainer changed out so now my 4 speed with adapt to me bellhousing. then i took it to work and filles it with 90w and got my shifter oon and shifting great.
next step= install
also i got some new flowmaster super 40's
Old 01-07-2008, 07:39 PM   #120
cstm68
cstm68's Avatar
so i cleaned up how my new taligate latches bot the the bed.
the did have a bolt welded to the inside of the bed and then a nes screwed on to that. now i have changed it so it is more like the way factory style stuff bolts on. i took some washers and nuts and welded the a nut the the washer. then i cut a round hole in the stake post i the bed. the i welded the washer into the hole so it was flush and the nut was on the inside.
i think it will give the larches a more clean look.
Old 01-07-2008, 07:47 PM   #121
cstm68
cstm68's Avatar
other pics
Old 01-07-2008, 08:36 PM   #122
cstm68
cstm68's Avatar
You must be a subscribing member to make a What's it Worth" post.
Old 01-10-2008, 05:19 PM   #123
cstm68
cstm68's Avatar
so ive been looking into build in my extral 12 bolt, i will be converting it to 5 lug with a 3.73 posi and disc brakes. thanks to other board members i have found the disc parts combo that i will use and looked into that at work where i can get the parts at my discount also i have found that summit has the axels ans posi. this should start once the tranny is in !!!
Old 01-15-2008, 05:42 PM   #124
cstm68
cstm68's Avatar
today i got the 4 speed in and im going to try to get the linkage set up tomarow after school and then take it and put it on a lift at work to adjust everything
Old 01-16-2008, 08:20 AM   #125
SchreinerM
If you don't mind me asking, what are you estimating for the rear end rebuild? Posi, 5 lug, disc brakes - all sounds like what I'd like to do.
SchreinerM is offline   Reply With Quote
