Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-21-2007, 01:15 AM   #101
sick69
sick69's Avatar
Re: LFD's Project Traizer 2WD closed cab.
Hey now thats a plan! But do you have to pay him to supervise?
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 10-21-2007, 03:27 AM   #102
earl87gta
earl87gta's Avatar
man you do some crazzy good work. Im not in to the Trazer thing but I love watching any thing you build.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-21-2007, 01:52 PM   #103
Rokcrln
Rokcrln's Avatar
Well he slept for another hour this morning so I had a chance to clean things up and get ready for next weekend, CUT TIME! I moved things around in the shop so it is front and center for slicing and fitting of all the new body parts! See you all next weekend
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-29-2007, 03:55 PM   #104
Rokcrln
Rokcrln's Avatar
Things are starting to happen and will be going even faster in the next month or so. I an getting it ready to head off to the media blasters by removing all rusted metal that will be replaced with new. This way we only pay to get blasted what is going to stay for the long hall. I am also test fitting the new panels so once it comes back it will fly together Here are a few pics from the last few days. I hope to have it all blown apart by Sunday after noon so it can hit the blasters in the next two weeks.
Kevin
LFD Inc.
Old 10-29-2007, 03:56 PM   #105
Rokcrln
Rokcrln's Avatar
It may get done yet
Kevin
LFD Inc.
Old 10-29-2007, 04:16 PM   #106
SCOTI
SCOTI's Avatar
I'm amazed by your talent.
IMO, it takes some keen 'vision' to see how things 'should' come together when doing one-off stuff (should & do are two very different results). You seem to have the touch needed to make things right.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-29-2007, 06:15 PM   #107
Rokcrln
Rokcrln's Avatar
Thanks but it all comes down to not being afraid to try somthing new. And alot of practice
Well the floors were not as bad as most I have worked on but still need the usual work. The rocker box's are in real good shape and I cut the floor open bigger than I had to just so the blaster can get in their real good and then seal it all up with epoxy sealer. The kicks and A post bottoms are gone as are the inner and outer rockers but that is about it for rust problems. I figure about a day per side and it will be better (sealed on both sides!) then new.
Kevin
LFD Inc.
Old 10-29-2007, 07:51 PM   #108
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Looking good Kevin, keep it up. Don't let the shop forman ride you too hard though! Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-29-2007, 08:19 PM   #109
Rokcrln
Rokcrln's Avatar
He can be a hard arss but today I distracted him with a shinny thing over his chair!
Kevin
LFD Inc.
Old 10-29-2007, 08:37 PM   #110
NTR72GMC
2wd FTW!!!!
NTR72GMC's Avatar
WOW not very much blazer left but its going to look sweet when its done!!!!!
NTR72GMC is offline   Reply With Quote
Old 10-30-2007, 12:31 AM   #111
gringoloco
A guy with a truck
gringoloco's Avatar
So you're using SWB bedsides cut down? I see that you trimmed the front- does the rear end up having to be sectioned, or do they line up? I always assumed the Blazer and short fleet bedsides were different dimensions behind the wheel arch.
Edit- nevermind- just went and measured. Beauty of having one of each! This is good to know- funny how your eye will play tricks on you...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-31-2007, 07:04 PM   #112
mkundo
Kevin,
Even with all the personal distractions mine and yours, during this build you are doing an amazing job. I can only say THANK'S for the great workmanship.
Dan
mkundo is offline   Reply With Quote
Old 11-01-2007, 10:41 PM   #113
Rokcrln
Rokcrln's Avatar
Check this out, yesterday the owner of this build called up ECE and ordered the floor patches for front and back, side to side as well as the two A pillar bottoms. Guess what was waiting for me today when I got home! Now that is fast service
Kevin
LFD Inc.
Old 11-01-2007, 11:08 PM   #114
PBFAB.COM
PBFAB.COM's Avatar
Subscribed...
Looks good as usual!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-05-2007, 03:48 PM   #115
Rokcrln
Rokcrln's Avatar
Getting more done today on the Trazer. Started off by grinding down the rear cab belt line weld and the pop rivit holes inside the cab. Then I focused on the A pillar section's. I could have just welded it up like most people do but I feel it is a good idea to add a bit of reinforcement to the posts. I do this in two ways, first I cut the opst open on the inside of the jamb stagering the out side cut. Then I cut out a patch from the doner cab so when it is welded up the cut seam is not all in the same plane ( one straite line) but off set to three different areas. Also I like to add a section plate to the inside of the post adding more strength to the post. I cut this section out of the same doner post that I got the outer plate from. I drilled 10 holes in it so I could plug weld it to the inside post but not untill I cleanned everything real well and sprayed it all down with Eastwoods Rust Encapsulator. I also coated everyting after the inner plate was welded up. Here are some pics of the passenger side and I am headed back out to finish the drivers side now that I had lunch
Kevin
LFD Inc.
Old 11-05-2007, 03:50 PM   #116
Rokcrln
Rokcrln's Avatar
Next five! I wish I knew how to string them al together
Old 11-05-2007, 03:51 PM   #117
Rokcrln
Rokcrln's Avatar
And the last five for now!
Old 11-05-2007, 04:40 PM   #118
tvblazer78
Low & Fast!
tvblazer78's Avatar
Looking sweet, love the work on the post.
tvblazer78 is offline   Reply With Quote
Old 11-06-2007, 07:17 PM   #119
Rokcrln
Rokcrln's Avatar
A bit more progress for the day
I started things off by checking the fit of a very rare blazer option, the bolt in low hump floor
Then I welded up all the holes in the new dash that were caused when it was removed from the doner vehical. I figured it would be alot easier to do all this now before it gets installed. Then I started fitting the floors, kick panels, A post bottoms and outer rockers. Everything is trimmed and cut awaiting blasting then it will just pop it self all back in
Kevin
LFD Inc.
Old 11-06-2007, 07:19 PM   #120
Rokcrln
Rokcrln's Avatar
It will all look better once it is all welded in place after blasting and epoxy coating.
Kevin
LFD Inc.
Old 11-06-2007, 10:10 PM   #121
red71cheyenne
Back in the sticks
So you are going to blast, then install the replacement panels? Just wondering why you wouldn't go ahead and install, then blast once all assembled. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 11-06-2007, 10:20 PM   #122
Rokcrln
Rokcrln's Avatar
Good question! I want the blaster to have full access to every thing posible. With the dash out, bed sides off, rockers and floors out and on a tip and flip dolly they will be able to get almost every square inch of this blazer. They will also be tipping it on it side to get teh entire bottom surface as well. The only thing they will not have access to is the inside of the head liner and under side of the roof. That is one reason we used the cab that we did for the roof section is because it had zero rust.
So once it is blasted and epoxy coated I will then replace all the areas that you have seen so far. I have made all the cuts in places that I will be able to get to thru the rocker box ends to prime and seal after install. I felt this was the best way to insure a longer rust free life after completion.
Kevin
LFD Inc.
Old 11-06-2007, 10:39 PM   #123
red71cheyenne
Back in the sticks
Ahh, I see. Thats a good idea. Putting all that new stuff in would just cover up the bad spots. I'll have to file that away for my next project. Thanks!! Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 11-09-2007, 06:54 AM   #124
Jtrux
I'm a poor spectator
Jtrux's Avatar
This is a very impressive undertaking, I enjoy following your project.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-11-2007, 08:25 PM   #125
Rokcrln
Rokcrln's Avatar
First big mile stone was hit today! Just got back from droping it off at American Strippers to get blasted and sealed then back here to get finished up. Seams like latly their has not been much progress but infact their was alot of prep for blasting and fitting all the new parts that needed to be done at some point. I also had the mad in brown drop off a box of Lizard Skin sound/heat proofing that will get sprayed on the inside of the cab and doors once it comes back. I also have all new hardware for bolting things up. This is going to be one slick ride when it is done. It has me inspired again for my 2wd Blazer so once this one is out I will be starting on mine, I was getting pricing today for metal stock for my new frame jig table. I also have 9 sheets of notes for mods as well as several body and chassie renditions It will be slick.
Well more on Trazer in a few weeks!
Kevin
LFD Inc.
