Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-14-2010, 09:48 PM   #101
'72customdeluxe
Re: Most dangerous tool in your shop and why!!!!!!
timing light, I always get chopped, shocked, or burned when doing timing..
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-16-2010, 07:18 PM   #102
donut
donut's Avatar
Originally Posted by Longhorn321 View Post
I would have to say I am the most dangerous tool in my shop. I have never had a tool jump out of my tool box and bite me. It's always me who uses a cheap socket and too long of a ratchet on a really tight bolt that causes the loss of blood and skin on my knuckles.
I tend to agree. I get hurt less when the tools are put away for the winter.
Usually injuries occur to me when the brain slips into neutral.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 04-30-2010, 11:03 AM   #103
nlped
nlped's Avatar
Me!!! For Example: Burned myself pretty bad yesterday with the MIG welder...I was wearing flip flops!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-02-2010, 09:17 PM   #104
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
it's a toss up between the iron worker cause of flying steel or the torch due to ocasionally setting my self on fire
Tex_50613 is offline   Reply With Quote
Old 05-06-2010, 09:02 PM   #105
motornut
78K & 79C Jimmys
motornut's Avatar
Thumbs up Re: Most dangerous tool in your shop and why!!!!!!
While in high school auto shop class in 1985 ,with everyone standing by offering how to properly mount a car on the floor hoist,with too many voices, i had no sooner put my thumb under the end of the arm to flip up a part of the lift and the lift dropped down on my thumb it seemed to take for ever to get it up......off to the hospital they squished it very painfully into a thicker type of thumb again......went threw a few colours of flesh and nails before it was better.
Surprised no one has mentioned drive on ramps,in 1989 i had an 79 austin mini,fine for it ,but i lent them to a neighbour to work on his 81 camero in our underground parking garage ,he came up after a couple of hours asked for a couple of tools,chatted said i would go back down with him......only to find the rear 1/4 smashed in , back window smashed, car on the ground into a cement wall beside him,it had gone over sideways off the ramps.Mike said he was under there till he came back upstairs,we both felt he was lucky that day,i duno if i would use the home made wooden ones i've seen on here either .
i don't need to lift my 4x4 to work on it,but still put axle stands under it
then on my list is grinders and welders,and the idiots that can't use em
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-14-2010, 03:26 PM   #106
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I have a 1/2" air drill that ended up in my box because too many people got injured with it at my Dad's work
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-14-2010, 08:05 PM   #107
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
It may be a repost but it is on-topic
Tools Explained
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned
calluses from fingers in about the time it takes you to say, "Oh,
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs
into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle...
It transforms human energy into a crooked, unpredictable motion, and the
more you attempt to influence its course, the more dismal your future
becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If
nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop
on fire. Also handy for igniting the grease inside the wheel hub out of
which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles
for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed
your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash
can after you cut on the inside of the line instead of the outside
edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot
to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening
old-style paper-and-tin oil cans and splashing oil on your shirt; but can
also be used, as the name
implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent the
object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons
delivered to your front door; works particularly well on contents such
as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially
useful for slicing work clothes, but only while in use..
Son of a ***** TOOL:
Any handy tool that you grab and throw across the garage while yelling
"Son of a *****" at the top of your lungs. It is also, most often, the
next tool that you will need.
Ghostwhite is offline   Reply With Quote
Old 05-14-2010, 11:03 PM   #108
chas350
Ghostwhite, lmao!
Angle grinder for sure, with wire wheel or cut off discs.
Had a 14" cut off saw blade grenade on me while cutting angle iron.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 05-15-2010, 12:45 AM   #109
thepenguin99
HAMMER:
lmao
thepenguin99 is offline   Reply With Quote
Old 05-17-2010, 01:04 AM   #110
Warrens69GMC
Warrens69GMC's Avatar
I have a 12" Cresent styled adjustable wrench and it has a crack in it, needless to say it works MOST of the time.
Old 05-21-2010, 08:24 AM   #111
misternash2
Re: Most dangerous tool in youre shop and why!!!!!!
Originally Posted by wibilly View Post
angle grinder with wire wheel and a switch other than a paddle switch. mine cought in the shackel bracket jumped out of my hands, waked me in the nads then pealed out on my belly winding up my shirt comming to a stop just before tearing into my beard. thank god for short cords on cheap tools
damn, that's a GREAT mental image. i've done it too though. lmao
misternash2 is offline   Reply With Quote
Old 05-22-2010, 10:20 AM   #112
camjck89
camjck89's Avatar
mine would have to be the 350 ton Cincinnati break at work. its all computerized but your still like"holy s**t let me get my hands out" oh yea and a 13 amp dewalt 7 1/2 with backing pad for sand paper, snagging on near-by bolts (rips out your hands and go sailing 20' away)
camjck89 is offline   Reply With Quote
Old 06-02-2010, 01:55 PM   #113
gunnersm82
someone said it already. the nail gun. had a 1.5 in brad shoot into my index finger, bend after hitting the bone and punch through to the other side. FYI, they really only come out one way.
the grinder is always a treat. been farily fortunate though, only a little skin and a few pairs of pants.
sawzall. cant think of how many times i said "that blades probably too long, but ill just watch it". you know the rest.
gunnersm82 is offline   Reply With Quote
Old 06-02-2010, 03:08 PM   #114
scooterskoolkustoms
scooterskoolkustoms's Avatar
I don't care what tool it is if it's in my hands it's dangerous.LOL
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 06-05-2010, 09:28 PM   #115
68longhorn
68longhorn's Avatar
1/2inch air ratchet is great at pinning your hand somewhere, usually a stud or such. Its amazing how fast rotary tools wrap upr your shirt, gloves, etc.
68longhorn is offline   Reply With Quote
Old 06-11-2010, 10:34 PM   #116
Shyguy
Junior Member
Shyguy's Avatar
All the clutter, too much stuff too little room.
I really need to straighten up every once in a while.
4" grinders are the next most dangerous thing, ever time I use one I get broken skin.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-16-2010, 07:03 PM   #117
68chevyfuelie
68chevyfuelie's Avatar
Any electric tool with a trigger lock combined with someone not thinking everything through.
Saw two guys (temp workers) belt sanding a piece of Douglas fir, probably 20 feet long, to be used in a timber frame structure. The timber gets moved around the shop either by overhead crane or on roller conveyor belts, the kind with the steel rollers. This piece was on rollers, both guys locked the trigger on the belt sander, and started sanding, and watched as the beam flew down the rollers and fell off onto the floor. Then, to a man, put down the belt sanders to go get the beam, and watched as the belt sanders flew off down the floor.
Another guy, actually a lead hand for the company, standing on the top step of a 12 foot stepladder, you know the one that says "This is not a step!", had to drill a hole in something overhead. The trigger locked on at some point, then the drill bit snagged and stuck, and proceeded to whip around and keep smacking him in the chin till someone could quit laughing hard enough to pull the cord.
Same guy, you know how they say in safety lectures to make sure you are clipped in when running a Skyjack/scissorlift? And also how you should always turn around and back down the ladder, facing the Skyjack? Well, he was tied in alright....but he just went to jump down off the Skyjack, and was hanging there till someone went to go get him.
I've learned sometimes co-workers/friends/neighbours are the most dangerous, and most people need a 10 foot safety zone around them
68chevyfuelie is offline   Reply With Quote
Old 06-28-2010, 06:33 PM   #118
ya it is a classic
84 f250 diesel running away. selling it 2maro and making money on it. o ya!
ya it is a classic is offline   Reply With Quote
Old 06-30-2010, 09:44 AM   #119
pat 70/71
pat 70/71's Avatar
The most dangerous tool in my shop? Its a cabinet shop everything spins& cuts so you have to be 100% focused on the job at all times. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 06-30-2010, 02:04 PM   #120
ERASER5
ERASER5's Avatar
We had an electrician like that in our plant. A very dangerous man, nice, but dangerous. It was nothing for him to have 10ft stick of conduit on his shoulder and then pivot 180 degrees, taking anyone and anything around him.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-08-2012, 11:17 PM   #121
truckingsal3
Mine could be the overrated drill I bought last year. It kept me inside the hospital for seven days when it accidentally crushed my feet.
truckingsal3 is offline   Reply With Quote
Old 09-09-2012, 10:25 AM   #122
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Any thing at forehead level
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 09-09-2012, 11:19 AM   #123
ssapach
ssapach's Avatar
I have an older Black and Decker drill. It's a 3/4" electric drill that doesn't have a deadman type switch. It's simply on or off. The best part is that the switch is finicky and sometimes doesn't turn on or off when you want it to.
Powerful drill to say the least. I don't use it though.
ssapach is offline   Reply With Quote
Old 09-10-2012, 07:46 PM   #124
ERASER5
ERASER5's Avatar
84? That would be 6.9 like mine. So what, where, and how? After reading one story, I keep a closer check on the oil level.
That 86 F250 might be my dangerous tool. ANYTHING suspension related is painful! If I did not make pain during the fix, the pain will come by morning. Sometimes I just take the Aleeve before hand.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 09-10-2012, 08:55 PM   #125
ozzyman
ozzyman's Avatar
We had a civilian used to work in our shop, We called him stubs cause he was missing 3.5 fingers. His finaly accident was bracing some metal with his hand directly behind the drill spot......
I refused to work with the guy he scared the crap outa me
Active Duty Air Force 02'-Current
Proud dad of 3 girls, 1 boy and 1 TBD in Dec of 2012 - Lucky Husband
"Family owned and operated since 1969"
Dad's 66' Custom Camper - Big Family Small Budget
ozzyman is offline   Reply With Quote
