Old 05-02-2009, 05:08 AM   #101
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Post Your Straight Six Pics!
Nice "HD-TD". I wonder why I never painted my lifter covers flat black? Looks cool. The chromed Chevy script valve cover is a real keeper. HEI for L6 -- you got it all goin', pal. Keep up the good work.
What carb is that on the Cliffy intake? Almost looks like a Q-Jet.
Old 05-02-2009, 02:53 PM   #102
pulltilbroke
pulltilbroke's Avatar
Yep its a Q-jet not sure if I'm gonna run it or use an old AFB of an small buick I got
I've actually been thinkin about paintin the side covers a cast aluminum color, (same color as the valve covers on my Cummins)
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 05-03-2009, 05:00 PM   #103
'68OrangeSunshine
I wonder what CFM that Q-jet has? I know GM Brazil has a Quadrajet L6 intake, but they're running almost pure alcohol down there, and you have to burn twice as much to get the same power as gas. If you look at the air/fuel charts a 292 @ WOT ideally needs 400 CFM. 390 is closest, but after 25 years I've had it with my Holley 8007. I now run the Edelbrock 1404, 500 CFM clone of the old Carter AFB. The AFB design with vacuum secondary only draws as much mixture as the engine vacuum demands, so a 500 isn't too big. But it does run rich. It would be interesting to see what you get with the Q-jet.
Old 05-03-2009, 11:24 PM   #104
pulltilbroke
I think the Q jet I got is 725 cfm, I"m not sure on the cfm on the afb I got but it came off a I think 215 all aluminum v8 Buick or Olds like what they used in a F85
I've ran both of these carbs on my last 292 and the AFB did seem to run a little better
Old 05-04-2009, 01:34 AM   #105
texanidiot25
Eat My Rust
texanidiot25's Avatar
I'd imagine that's because the Q-Jet was way over-carbed for that motor. 725 is pretty mad for a little inliner.
From what I've experienced, the two standard carbs I've had on the truck so far were 650s.
texanidiot25 is offline   Reply With Quote
Old 05-04-2009, 07:53 PM   #106
Brad
Out of the carpool lane.
Brad's Avatar
Pontiac used a Q-jet on their ohc 250 engine in the 1st gen Firebird. There's at least 2 people now on the board that have used a Q-jet on their 250. I was going to try it on my '67 but never made the time to do it.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 05-04-2009, 11:46 PM   #107
trenz68
Damage Inc
trenz68's Avatar
my 6
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 05-06-2009, 05:31 AM   #108
'68OrangeSunshine
Could be the Q-jet also has vacuum secondaries, so the engine only demands what it needs...? I have little experience with them, all bad, but I guess back in the day with full corporate support, they worked OK. The Re-mans you get from Checker Auto and the like all suck.
Pulltill-- Carter used to make a 400 CFM AFB. [It's not commercially viable for Edelbrock to go that small now.] Can you lift the numbers from the front passenger-side "foot"?
Trenz -- Is that a Yorx A/C compressor powering a set of triple airhorns? You are one mad, bad and dangerous dude.
Old 05-31-2009, 09:57 PM   #109
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Here's mine.
I have a rebuilt engine and am having hell getting the exhaust manifold to seal after the first cylinder at the bottom.
I am also curious if the exhaust preheat valve could be sticking and causing additional back preasure.
It is not sticking, but what if I wired it open?
The first picture is at rest with the manifold warm, the second the spring is under slight preasure to hold in that postion.
I have a really quiet muffler on it, so I expect I have some back preasure anyway.
I put the second gasket on and it did not seal at all, looking for ideas.
I thought I read that you must put the intake and exhaust on together but not bolted up, tighten everything, then tighten the preheat cavity.
Also looking for a tuning schematic for the 1BBL carbs if you might know where to find one.
Mike
CUSTOMAL@FLASH.NET
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 06-01-2009, 05:09 AM   #110
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mike that thing is beautiful!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-01-2009, 07:07 PM   #111
Conroe trucker
Thanks!
Now I just need to get it running good.
01 C5 convertable
08 Z06
Old 06-01-2009, 09:50 PM   #112
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Would you mind posting a few more pics of your setup? Also is this in your '70 or your '67?
Any overall shots of your truck?
What can I say... I am intrigued by your truck!
-Nate
Old 06-01-2009, 10:01 PM   #113
Conroe trucker
Here are my build sites.
I have 2) 67s, one 2x4 and one 4x4.
If you have questions let me know.
It is easier for me to send you there than convert the pictures back to a format that the site can handle.
If you want more detail let me know.
I can email them.
Not too much on the 70 292.
We are not planning to restore it, but it is a daily driver and we are getting kind of fond of it.......
http://67-72chevytrucks.com/vboard/s...d.php?t=289840
http://67-72chevytrucks.com/vboard/s...=1#post2826812
01 C5 convertable
08 Z06
Old 06-01-2009, 10:09 PM   #114
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Those threads will be fine. If I run into any questions, I will be sure to ask. I checked out the '67 and it is truly amazing what you've done with it.
Thanks for posting those links, and get ready for a few questions!
-Nate
Old 06-03-2010, 12:43 PM   #115
Old Bluey
Old Bluey's Avatar
Inline thread is still alive! Holley/Offenhauser project is all done.
Old Bluey is offline   Reply With Quote
Old 06-05-2010, 12:26 PM   #116
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That looks good!
-Nate
Old 06-05-2010, 01:10 PM   #117
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Do they have to be in the truck to run???
powerdriver 1958 is offline   Reply With Quote
Old 06-05-2010, 04:15 PM   #118
kyull67
kyull67's Avatar
Nice! I love these little monsters with open headers!
kyull67 is offline   Reply With Quote
Old 06-05-2010, 06:06 PM   #119
mosesburb
I had a V-8
mosesburb's Avatar
Your power steering project appears to be done too.
Looks good!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 06-05-2010, 06:08 PM   #120
Shyguy
Junior Member
Shyguy's Avatar
Originally Posted by Conroe trucker View Post
Here's mine.
Mike
CUSTOMAL@FLASH.NET
The pre-heat valve can be wired open ok. We wired open the one on my son's 250 in his '71 Chevelle and it runs great.
I have not checked the one on the 250 in my '67 yet so I don't know if the previous owner wired it open or not.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 12-01-2010, 12:04 PM   #121
made2drag
made2drag's Avatar
inline 6 guys, i love the pics of the inlines! i came across this after doing a search. i am trying to find a good picture of where to hook my power brake hose from the booster to the engine. i did the conversion from 73-87. now i just have to hook the tube up to my 6. thanks
made2drag is offline   Reply With Quote
Old 12-01-2010, 12:12 PM   #122
geezer#99
geezer#99's Avatar
Made2drag. Are you all stock intake carb etc. or modded?
Old 12-01-2010, 12:15 PM   #123
made2drag
made2drag's Avatar
geezer, its all stock (250)
Old 12-01-2010, 12:32 PM   #124
Brad
Brad's Avatar
Arrow Re: Post Your Straight Six Pics!
You can hook it up to the intake manifold. It doesn't matter where, just hook it up wherever is convenient at the intake manifold. The booster requires vacuum and it gets it from the vacuum the intake manifold creates.
As a side note, I was out in the garage last night tinkering with the 6 in my Camaro. Trying to get excited about cars and this forum again.
Old 12-01-2010, 12:38 PM   #125
made2drag
made2drag's Avatar
thanks brad! i went out and saw a square headed bolt that unscrewed. now i just need to find some kind of fitting to accept the hose. maybe i can find one at the hardware store. and yes, this site does cure the motivation blues!
