06-17-2008, 02:43 PM | #101 |
www.73-87chevytrucks.com
Re: ojoe's crewcab shortbed build
You can shorten it without converting. Just take a section out of the existing frame and weld it back together. If I keep mine I plan to do it that way.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-17-2008, 03:49 PM | #102 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=123624 |
06-17-2008, 07:32 PM | #103 |
You can see a members truck that just did this. It is a Regular Cab Longbed to shortbed. Same concept.
http://forum.73-87chevytrucks.com/sm...p?topic=7334.0 There is also an article on it here by another member: http://www.73-87chevytrucks.com/lwb_to_swb.htm This subject has come up A LOT. I would follow the forum method of cutting the frame though.
06-24-2008, 02:44 PM | #104 |
Luv the Crewcabs
What was the Cost of Getting your Driveshaft Shortened for the Truck, I was Given a Quote of $250.00- $300.00 for this? Is that The Going Rate, We only have one Location nearby, I Just Thought that was kinda High to Shorten one? Any Suggestions on where i might look?
Thanks, Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
06-24-2008, 02:52 PM | #105 | |
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
06-24-2008, 07:40 PM | #106 |
Happy to be here
For 250-300 they should be building you a completely new shaft, not just re-tubing it.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 06-24-2008 at 07:40 PM. |
06-24-2008, 07:59 PM | #107 | |
Crew Cut
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
06-24-2008, 09:49 PM | #108 | |
06-24-2008, 10:39 PM | #109 |
Luv the Crewcabs
Thanks for the Input, I Thought that seemed High.................
I Think i will go looking at the Junkyard.............. Rick
07-29-2008, 05:51 AM | #110 |
69fatmotor
here's a few pics of the truck . it's getting ready to go off for paint. we swapped out two of the doors and got the bed ready . the gas door has been relocated . the next time you see the truck it should be red. the truck ride and drives great and the air is cold.
07-29-2008, 05:53 AM | #111 |
69fatmotor
also the tailgate handle was relocated.
07-29-2008, 06:31 AM | #112 |
sweet! Can't wait to ride in it!
07-29-2008, 06:33 AM | #113 |
THE VILLIAGE IDIOT
looks good.. cant wait to see it in paint
honestly honey,,i have no idea how that truck got here. |
07-29-2008, 02:27 PM | #114 |
Sweet! Can't wait to see it.
Rod Doors said the rear door panels are still about 4 weeks of being completed for test fitting...
07-29-2008, 07:04 PM | #115 |
Crew Cut
the truck is at the body shop now. was told i would have it back in 2-4 weeks. (hope not body shop weeks) paint will be torch red.
07-29-2008, 08:04 PM | #116 |
I know the pieces fit
I hope to see that truck at Flip's cruise in when it's done. I love the crew cabs.
07-30-2008, 03:49 PM | #117 | |
Then the upholstery shop? |
07-30-2008, 07:24 PM | #118 |
Crew Cut
yes and maybe the rear Rod door panels will be in by then.
07-30-2008, 07:29 PM | #119 |
Crew Cut
we will be there. are you from montgomery? mysel and my buddy mike nutt go there some. i take my 30 model A hot rod and mike takes his orange 69 chev p/u.
07-30-2008, 09:59 PM | #120 |
This may have been answered already but what size are the tires you have mounted . Also what are the specs on the wheels as far as backspacing goes ? I like the sidewall on them . I wonder how that much sidewall would look on a reg cab short bed ?
Frank
Born and proudly residing in a Red State ! Last edited by f.monroe; 07-30-2008 at 10:01 PM. |
07-30-2008, 10:29 PM | #121 |
ojoe, looking good.
If you ever get time, can you get some more pics of the filler routing? I like the new fuel door. Wheels: rear 20x10 5.5" bs front 20x8.5 5.25"bs (I think)
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
07-31-2008, 05:48 PM | #122 |
I'm in Montgomery. I'm usually at Flip's and make other shows if I hear about them. Post some pics of your car and Mike's truck, I'll look for you next show.
07-31-2008, 06:48 PM | #123 |
Who are you planning to use for the interior work? I'd been using Lucky, the guy who had a shop on 231 just south of Taylor Road. But he closed up shop, I heard he's working at home and only doing high-end work now. I'm not sure recovering my Blazer seats and installing a carpet kit would interest him.
07-31-2008, 07:37 PM | #124 | |
Crew Cut
07-31-2008, 07:48 PM | #125 | |
Crew Cut
i will try to get more pics at the body shop. they are taking the bed back off for paint. i did turn the filler tube to the rear of the truck about 2" or maybe from 6 o clock to about 8 o clock and just used a rubber hose to connect the tank to filler end. the hose was hard to find that can be used with gas
