Old 08-02-2008, 07:46 PM   #101
joe231
joe231's Avatar
Re: my radical 60 build
looks nice!
CHEVY ONLY
Old 08-03-2008, 12:10 PM   #102
Dinos63
chevy only
Dinos63's Avatar
I dig it looks killer , you must gets some crazy looks when you are driving
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-16-2008, 10:38 PM   #103
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
Just Read thru your entire Build & want to say Congrat's on your Vison , It is Inspiring to see such creativity being put Together.............
Signing up for More.............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 08-18-2008, 03:37 PM   #104
Joey~AP
TexasBowhunter
Joey~AP's Avatar
How about some step side fenders for inner fender wells?
Joey~AP is offline   Reply With Quote
Old 08-18-2008, 09:42 PM   #105
original_balzer
original_balzer's Avatar
That ^^^^ is a cool idea. I cant wait to se you blend the front fenders and doors. Sweet ride Keep up the good work.
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
-77 k20 long fleet (gettin all the goodies from frankentruck)
-79 c30/k30 3+3 frankentruck (cab and frame for sale)
-99 GMC yukon daily driver
original_balzer is offline   Reply With Quote
Old 08-19-2008, 07:31 AM   #106
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
That is a cool idea, I am still hashing out the inside of the bed, I wanted to use the chevrolet tailgate letters off one of those new avalanches on the front bed panel, but I found out that they are fiberglass.
I have been taking it easy on the build these last few weeks.
I had eyeballed the bed when I mounted it, and the horizontal body line creeped up about 2 inches higher to the rear, I used a laser level, and cut the rear frame horns and dropped the bed till it was level.
I got one (of the 8 I need to do) bed corner figured out and welded up.
I nhave been doing a bunch of homework trying to figure the best way to do the chop on the roof.
and I am going out later this week to try to find a better drivers fender and hood before I get into welding up the fender blend.
Old 08-19-2008, 11:55 AM   #107
muddpile
muddpile's Avatar
I found the same problem with my project, the rear of the bed was too high. Once you get it dropped down, they look just SICK with the rear wheel tucked.
As for the top chop, I've seen a few guys sink the roof into the cab sort of. I'm still looking for ideas as well, as I think my Tornado project would look pretty wild with a chop.
muddpile is offline   Reply With Quote
Old 08-20-2008, 02:17 PM   #108
jonzcustomshop
1961 crewcab
here is the bed corner, I just used the original cap and then cut and angled it to match the bedside sngle for the rear piece.
then, shots of the cut frame to lower the rear bed, this was easier than re-doing the box and bumper mounts. this lowered the rear of the bed to get the horizontal body line right.
Old 08-20-2008, 02:29 PM   #109
jonzcustomshop
1961 crewcab
the new side profile.
the shots with the hood on.
I will have to use the rear bit of a 60-66 hood to get the straight edge across the back, and the gap is wedge shaped (the 60 cab is a half inch wider than the plymouth), so I will have to cut and fix that.
First I am going to try to find a beter hood to start with, this one had frozen hinges, and somebody shut it anyway, so it is a little bent.
Old 08-20-2008, 02:39 PM   #110
jonzcustomshop
1961 crewcab
here are some shots I have wanted to get.
parked next to my stock 65.
until I did this, I did not realize that this truck is the same length as a lwb truck! Just the cab and wheels are in different spots. the wheelbase on this is 115, compared to the 127 of the lwb.
Old 08-20-2008, 02:49 PM   #111
Blue'72
Skinned knuckles
Blue'72's Avatar
Hmm, the differences are so subtle, it's hard to distinguish..
I just ran across this and will definitely be keeping up on your progress! I like it!!
'72 C-10 longbox soon to be short step!
'72 Chevelle (sold in January)
'07 Sebring
'01 Ranger (I've gotta long commute..)
If you try to fail, and succeed, which have you done?
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904
Blue'72 is offline   Reply With Quote
Old 08-20-2008, 05:56 PM   #112
original_balzer
Did you raise the front of the front fender in the last pics as well or was I seeing an illusion? Before it looked like the fender line dove down in the front compaired to the rest of the upper body line. Looks like it all lines up almost perfect now. Killer project I wish I had half the nerve and talent you do.
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
Old 08-20-2008, 06:03 PM   #113
original_balzer
Oh 2 more things, 1st the wheel openings. I vote you should change the front to match the GM rear, rather than matrching the rear to the chrystler front. Keep it more GM.
2nd, I wonder if you could use a piece of a 60-61 hood for a mild hood scoop? The top of one of the eyebrows, I dunno it just needs something on that hood.
Just my $0.02
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
Old 08-20-2008, 06:32 PM   #114
jonzcustomshop
1961 crewcab
I think there might be a bit of fish eye to those photos.. and the angle of the drive way plays hell with trying to visualize things.
I haven't changed the front, but it might look different now that the truck sits level, and the bed is down in the back.
I am not fond of the front half of the front wheel openings.
I think the wheel might not be where it should be in the opening,and I don't really like how it comes back in on itself.
I was actually photochopping them this morning!
that hood idea was a solution that I had for my sectioned elcamino, if I couldnt get the hood to clear.
Old 08-20-2008, 09:05 PM   #115
Slmd92DIME
Slmd92DIME's Avatar
Wow man that is some crazy work... mad props for your patience to keep going with it.. Awesome project
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 08-31-2008, 09:20 PM   #116
jonzcustomshop
1961 crewcab
I went with an old 60's trick for the grille, I raided 2 Ace Hardwares for all thier drawer pulls-twice! They were probably wondering why they sold 60+ of that style of knob in a matter of days.
plymouth had a chrome trim that surounded the original grille and hood that I am going to try and find,and I might put one more row up by the hood, depending on how thick the trim is.
Old 08-31-2008, 11:54 PM   #117
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Lovin the grille Jon! nice work. Hope to get up there soon.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 09-01-2008, 01:08 AM   #118
original_balzer
Looks cool Im liking the whole project. I could be wrong but I think the hood trim has some sort of chrystler thing on it but they changed so often its hard to say.
Maybe you can change the front a bit to distract from the mopar parts. It just cant be a HIGHLY modified chevy truck with a chrystler front clip, if ya know what I mean. No offence at all and its your build, I dont intend to tell you how to build it. Sometimes I just dont know when to leave well enough alone LOL.
EDIT: just another idea you could add the 4,5,6, hood line, and the bottom of the front to the bottom of the chrystler hood. You would have to add a bit to the openings to match the curve around the headlights. I couldnt do it very well with MS paint but heres the rough idea anyway.
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
Old 09-01-2008, 01:28 AM   #119
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That grill is sweet. show car style all the way
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-01-2008, 03:11 AM   #120
original_balzer
Plymouth! sorry dunno why im stuck on chrystler I guess its all mopar no matter how you it
rock on dont mind me im just passin through
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
Old 09-01-2008, 07:35 AM   #121
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Keep up the good work Jon. "Git-R-Done"
Alan's Classic is offline   Reply With Quote
Old 09-01-2008, 08:48 AM   #122
jonzcustomshop
1961 crewcab
I had thought of putting the center of the 62-6 hood on there, and maybe just extending the bottom lip of the hood to meet the grille...
the front pan will get extended all the way across to match that 59 bumper as well.
I also have an idea for changing up the headlight rings for kind of a frenched look.
...saw a NOS 61 plymouth headlight ring (1) sell for $204.00 on ebay, so there is no way I am finding/keeping te original ones!
actually, I got a bit of sticker shock looking for 61 plymouth parts that I needed: $94 for a set of park light housings and lenses, and $180.00 for a pair of the chrome trim that runs around the edge of the fender!
Crazy money.. and then I see 3 or 4 grilles sell in the $20.00-$30.00 range! the part I don't need...
Old 09-01-2008, 06:46 PM   #123
kdrodworks316
KOFFIN DRAGGER
I am on the lookout for plymouth parts Jon. I will see what I can dig up down here for you.
Old 09-04-2008, 07:06 AM   #124
jonzcustomshop
1961 crewcab
well, I am getting started.......
here is a teaser shot of the upcoming chop.
I am taking lots of pics of this process, so hopefully if anybody else wants to chop an early truck they can see how to do it.
All I have been able to find so far is pics of "done" chops, but not the process.
Old 09-05-2008, 03:39 PM   #125
kdrodworks316
KOFFIN DRAGGER
I really need to get up there and see this
